Question about Pioneer DEH-P690UB CD Player
Where is that jack
Is that jack in the rear of player and possibly blue and all i have to do is plug the 3.5 cord in?
The 3.5 jack in the rear of player is for a wired remote
the blue square shaped mitli pin plug is for a multi cd changer
Posted on Mar 28, 2008
HP Pavillion dv6700 - won't power up
Hi have you tried to power up without battery?
Feb 16, 2013 | HP Pavilion Computers & Internet
Picture too green
Patch cord Is Reverse,Plug in to the wrong jacks on your tv,Reverse the green end blue plug,It can be done on the dvd player,Or at the TV,
Oct 18, 2012 | Toshiba SD-K620 DVD Player
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
It won't play dvd's in color
Please check the type of disc that you're playing.
Generally, if the NTSC format disc being played in PAL Player or vice versa will cause this issue. Please use the NTSC format disc in NTSC player and PAl disc in PAL player.
Please check if the Player is connected to the display device with the correct cables and to the correct jacks.
Please make sure to connect the Component OUT (Red, Blue, Green cables) to the Component IN (Red, Blue, Green).
If you are using the Compiste connection (Yellow, Red and White), please connect the Video OUT of the Player to the Composite or Video IN on the TV using the Yellow cable and Red and white for audio according to the color codings.
Please try with different jacks on the TV to confirm if the issue is with the Jacks on the TV.
Please try power resetting the TV and check if that helps.
Turn off the Player.
Unplug the Player power cord from the electrical outlet.
Let the Player remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the issue is still unresolved, the Player needs to be Serviced at the Authorized Service Center.
Mar 30, 2011 | Sony DVP-NS50P DVD Player
I have harman kardon speakers and I cannot figure how to connect with my computers, both desk top or laptop. There are two speakers with a cable with a light green plub and another plug that has me...
The green plug needs to be plugged in into either a green jack at the back of your computer or into your laptops earphone jack. And if the second cord is a USB cord then plug it into a USB port. If it is a power cord then plug it into a wall socket.
Mar 12, 2011 | Computers & Internet
55" Philips rear projection HDTV..
that input is called DVI digital video interface it is only for video. there should be some red and white composite input jacks for the audio near the DVI connector. you will need to hookup the red and white cables from the tv to the cable box or dvd player or whatver you are using. good luck
Jan 06, 2011 | Philips 55PW9363 55" Rear Projection...
Where does the Microphone plug in to the Dell Vostro200
Depending on the chassis-style of your Vostro 200 (Slim-line or Tower), you may have one or more options for installing a microphone.
See below for instructions:
A. Slim-Line Model
There are two locations on this model (by default).
Front: You have the power button, then 2 x USB ports, 1 x Headphone jack-out, and 1 x Microphone jack-in.
Rear: There is a block of six audio connectors, looking only at the bottom 3 (red, green & blue).
Red = Microphone jack-in Green = Speaker/Audio jack-out Blue = Audio jack-in
B. Tower Model
There is one location on this model (by default):
Aug 15, 2010 | Dell Vostro 200 PC Desktop
Cig power/3.5 jack problem
You have to be using the wrong cable, my friends cable comes with 4 tips , i believe the 3 tips give you this problem
May 27, 2009 | SanDisk Sansa e260 MP3 Player
Cannot get DVD's to play on our TV.
It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
1) COMPONENT VIDEO (Red, Green, Blue)
If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
2) COMPOSITE VIDEO (Yellow)
If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
3) COAXIAL JACK (Antenna port)
If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
(I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
May 04, 2009 | Televison & Video
Pioneer DEH-P690UB CD Player Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
