Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
How to replace glass on oven door - Dacor Epicure
How to replace glass on oven door - Dacor Epicure 30" dual fuel series
  • Anonymous Mar 16, 2014
    calibrate dacor epicure oven
  • Anonymous Mar 19, 2014
    oven door is off and the hinge is locked, how does itunlock?
    Sergeant:
    Champion:
  • 263 Answers
You need to take the door off. There little hooks on hinges, that you move to up position and then lift up the door and it comes out. After that unscrew allt he screws, that you see.
Hope it helps.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 07, 2010
F3 error. Beeping wont stop.
Hi miketack,
If your Dacor is getting an F3 error code and wont stop beeping this is because of shorted oven temperature sensor or RTD. You can fix this by checking sensor harness and harness connection between oven sensor and oven control. In case that wiring is ok you need to replace oven temperature sensor (RTD). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
May 21, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
Error code F8 keeps coming up. I was trying to run the self clean program and it wouldn't work. Now error code keeps coming up regardless of what mode oven is in
Hi vicktys,
The error code F8 that you are getting from your machine means that there's something wrong with the door locking switch. You need to check if there's any loose wiring as well as the door locking switches. If the wiring is fine you might need to replace the door latch assembly.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Nov 22, 2010 | Dacor Epicure ERD30 Dual Fuel (Electric...
I have a Dacor ERD36, How do I remove and replace the oven door hinges?
most ovens , you open the door half way, then pull straight up the door will come right off, then you have full view of hinges and bolts
Oct 19, 2010 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
May 05, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
I need to clean the inside glass on my maytag oven
Use Easy Off oven cleaner. Avoid getting on paint. Avoid breathing fumes! Let sit a half hour or so. Repeat until clean.
USE GLOVES.
Mar 10, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dacor oven will no heat.
dacorservice.com very likely has your answers. Good Luck and Happy New Year!
Dec 27, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Oven enamel chipping
Never heard of such a problem, you are the first to post it. There is no fix for this.
Apr 03, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
770 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
