Question about Siemens WXLS142GB Front Load Washer
Spinning Siemnens WXL142 washer. spinning problem, the machine recently made a load banging noise and the door came open breaking part of the door catch, I have checked the filter area OK! I have resecured the load senser plate in the base of the machine as it was loose!!! it's 8.5 years old and done tons of washing is it Knacked????
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Siemens Expert
  • 154 Answers
Spring or shock absorber may have come loose
Posted on Feb 07, 2010
When it gets to spin cycle it move all over the placy bang into wall ????
Check to see if the machine is level and all the 4 legs are making good contact with the floor. If the machine is level, check to see if the machine spins freely. Open the door and check the drum. It should be hang straight in the opening. Spin the drum by hand and listen for any strange noises. It should spins quietly without any banging noises. If that check out, remove the lower access cover and look at the wash drum. There are two shock absorbers. If they look damaged, they will need to be replaced.
Oct 04, 2010 | Frigidaire GLTF2940ES Front Load Washer
Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD640 Front Load...
Washer motor turns, drum does not
Please be gentle with me if this is obviously not the problem, but I have made the mistake of running top load washers with the door open (which the washer notices and does not turn the basket. I fixed my problem by loading the washer, adding the detergent while the washing machine was filling and then closing the door. My washer worked fine with the door closed.
Again, please be gentle with me as you rate my helpfulness. OK?
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Hotpoint aquarius wm64 loud banging noise when spinning with full load no noise when spinning empty i have found small pieces of plastic inside drum
Several possibilities here.
First and fore most is the drum support or main drum bearigs are failing., more likely to be drum support
The pieces of plastic you refer to are from inside the outer drum, because what is happening is the inner drum is catching the outer drum, and breaking the plastic inside.
You are going to have to strip it down to determine the exact cause, what I expect you will find is that the alloy 3 legged drom support has corroded away,a nd the drum has come loose.
Hope this helps you solve your problem
Nov 28, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Washer makes loud knocking noise
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Sep 28, 2008 | Roper RAS6233KQ Top Load Washer
Loud banging noise commencing spin operation.
one or two of your dampners are either lose or broken.
Open machine and check all dampeners . replace the roken ones. Dont use the machine as it will increase damage
Jun 22, 2008 | Creda W100FW Front Load Washer
Banging while spinning
slid the machine out away from the wall and tilt back enough to see underneath. just below the door there is a large concrete weight. chances are it is loose and needs to be tightened. if this problem has been going on for a while the bolts holding the weight on will have snaped and the drum/weight or both will need replacing . ( ex hoover engineer)
Nov 13, 2007 | Hoover SE230 Front Load Washer
Siemens WXLS142GB Front Load Washer Logo
300 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
