My Marshall JCM 900 50 watt head (2500) has low out put
I bought this amp on ebay, it didn't work the first few weeks (no output) we found the first problem the impedance select switch was old so i fixed that, it worked for a few months and then the problem cam back, this time, we though it was the tubes cause i put in and old set and it worked so i got some new one and it worked for a week and then it happened again with he low/no output. this time i though it was the volume pot so cleaned it and greased it up and no such luck still has REALLY low output i have looked though this amp with he schematic and my dad and i have decided that there is possibly a lose connection some were in the amp we can't see. i want to see what all of you think before we send it in ANY ALL SUGGESTIONS ARE APPRECIATED!! thanks
  • 506 Answers
Did you replace all tubes preamp and power amp? Just a clarification I assumed so. Some common problems with amps in general are after time the effects loop relay can be going bad. This happened on my 5150. I eventually replaced the relay and all was fine but until I did I used a patch cable to go from send to return. Unfortunately this amp employs the use of opamps in its signal path for the EQ. You may also what to check these. First try the effects loop patch to see if that works for you. Since the problem is intermittent it sounds like that is the problem. If you need any other help let me know, I have pretty good experience troubleshooting/building tube amps.
Posted on Feb 08, 2010
I have the Marshall MG100HDFX 100-Watt Amplifier Head, the fuse was blown and there is no audio coming out of the the spkr jacks. this is how i received the amp and have no further info to diagnose. im...
If the output transistors have shorted, it is LIKELY that several others in the drivers and even farther back have also gone. HOWEVER some Marshall amps use one or more TDA7293 chips. These require installation using heat sink compound. The TDA7293 can be found at:
http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=US&WT.z_homepage_link=hp_go_button&KeyWords=tda7293
They come in two sexes depending on which way the leads are bent for installation. You have to see how yours are mounted relative to the circuit board. Cost about $6.
Apr 24, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
Can i connect 2 jbl 300 watt speakers to the mg 100hdfx 100 watt amp head ?
Yes you can as long as the speaker impedance when paralleled doesn't go below the rating of the amp. Marshall seems to hide their design lowest output impedance. Possibly you can find that in your owner's manual. Then find the impedance of the JBL. If half the JBL impedance is equal to or greater than the lowest impedance the Marshall is rated, you are fine to use it. The speaker Watt rating should always be bigger than the amp rating which it is in this case.
Dec 11, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
No output from my Marshall MG15DFX
could be effects module or sound output i.c. also check send and return jacks
Feb 04, 2010 | Marshall Mg15dfx 15-Watt Combo Guitar...
Marshall JCM 2000 dual super lead 50 watt going out on me
Very nice amp!
First off, is the amp getting sufficient power? An unreliable AC current from your wall can affect the performance.
Have you tried the amp with a different speaker? Checked for a loose connection from the amp to the speaker? Is it the correct ohms rating?
Second, are you experienced in electronics? The problem could lie in a faulty solder connection, a bad component, etc.
If you are not confident in opening the amp and troubleshooting it yourself, take it to a audio repairman. Marshall's are some of the easier ones to fix.....
Nov 22, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
JCM 2000 TSL 601 MARSHALL AMP TURNS ON NO SOUND TUBES DONT LIGHT
If the tubes are not lighting, either the fuse has blown or the power transformer might have an issue.
Be vvery careful as there are lethal voltages present in these.
If the fuse blew, replace it and try just once as there could be other problems and more damage could be done.
Sep 29, 2009 | Marshall Music
Marshall mg 100hdfx fan
Some of the Marshall equipment uses computer size fans and even on occasion the same connection.
Take the bad fan with you to a computer repair shop it will be much cheaper than a marshall part they should be able to help you out
Sep 09, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall jcm 2000 dsl 100 head not powering cabs 4/8ohm outs
Since you are getting some output, the amp section is probably OK. There are circuits designed to handle thge difference impedence outputs. This should be a relatively simple repair for any shop that handles these units. If you don't have one local to you, let me know and I'll locate the service info and get you more specifics.
Dan
Mar 06, 2009 | Audio Players & Recorders
I have a marshall 100w JCM 2000, DSL 100 Head, going into a 1960 A 4x12 cabinet. Which inputs and settings should i use on the rear of the amp in order not to damage it
Most 1960 cabs have an option for 8 or 16 ohm... i dont think there is a 4 ohm option. The Jcm 2000 heads have the ability to do all three ohm setting. Thats all you really have to worry about. Make sure the ohms match up. The 1960 cabs typically have 4 t-75 speakers in them which are 75 watts each so wattage is not a problem. There is some argument about what ohms sound best. It doesn't really change that much in the sound in my personal opinion. I run mine at 16 ohms though cause i think it sounds brighter...
Apr 18, 2008 | Audio Players & Recorders
228 people viewed this question
 Grubhead
Grubhead
