Question about Boss Micro BR Digital Recorder
When I record with the internal mic or the BA
When I record with the internal mic or the BA CS10 stereo mic, I get very very low volume on playback. Why?
I had that problem too. What you need to check is the input level on the right side. Turn the wheel all the way up to 100 and the internal mic should be fine.
Posted on Mar 28, 2010
How do i update the firmware and is this may be the cause of the USB b not recognizing any memory sticks that we've tried?
usb b is for streaming digital media,not memory sticks,
  • High-power dual DSP engine with improved digital effects and output processing including Feedback Ferret®, 28-band GEQ/5-band PEQ, delay and limiter
  • USB 2.0 "A" connection to record directly to or playback from memory stick
  • USB 2.0 "B" connection for streaming digital out
  • 3-band EQ with sweepable mid-frequency and variable low cut filters
  • 2 stereo channels with dual mic/line inputs
  • 48 volt phantom power
  • 6 Aux sends
  • 4 subgroups
  • 100mm faders
  • Double the processing power of the original FX Series
  • All new switching power supply design is more efficient than the original
  • Silencer™ mic preamp XLR inputs
  • Weight Packed: 45.00 lb(20.412 kg)
  • Width Packed: 25"(63.5 cm)
  • Height Packed: 36"(91.44 cm)
  • Depth Packed: 11.5"(29.21 cm
May 19, 2015 | Peavey 32fx USB 32 Channel Mixer
I am getting minimal to almost no sound coming from my mic to my computer.
If you are using the fx/send port to the mic-in port (I have no idea why you would want to do that) but nevertheless, check the red fx dial and make sure it is at 12 oclock and turn the pan dial to 12 oclock also. remember if you are using mic input 1 or 2 with a mic that requires Phantom power the button needs to be locked in the down position. OK im assuming you have checked and set your gain and volume levels on the 802 prior to plugging in your mic. If not do so now.(unplug all outputs and with mic plugged in speak into the mic while turning up gain until you get distortion which is indicated by a rewd light next to the "pan" button...once you see that light turn the gain dial back slightly and you should be set) have volume at 12 oclock on both l"evel1" and "main mix: dials. Now goto your windows desktop and right click on your volume control "speaker" icon. Click on "Playback device" you should see your mic in the list on enabled devices.If you dont see your mic in list right click the screen and click show disabled devices. Enable your device. If it is already enabled right click it and make sure it is not muted. finally go back to list of playback devices and right click your mic and click "configure speakers" run through the tests. close everything.mic should be working now. If it is not I suggest you plug your mic into either the line in from the fx/send or keep it in the mic-in port and plug the other end into the head phones port.Or better yet, get an rca to mini stereo jack and use the cd/tape out jacks to send your signal to the mic port of your computer......keep playing with it...you'll figure it out.There are so many different ways to hook up your perephrials its mind numbing sometimes.
Mar 16, 2013 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
Right channel cuts out when I increase the volume
Blown or defective Headphone Amp IC or alternatively a defective Pot. Either way only AVID can fix it for you.
Outside parts and service is impossible.
Oct 03, 2012 | Digidesign *mbox2...
I plug it directly into my pc and it wont record on my music programs.Does this mean it is broken?Is there something im missing?.And it was purchased new but came with no directions,is that right?Also...
There is no volume adjustment. You would have to use the volume controls in the PC "control panel". Not all PC's will be compatible with this mic, as this mic is monaural, not stereo. You may have to use a 1/8 jack monaural to stereo jack/plug for the mic. Be sure and set the volume levels for both the mic and headset in the control panel AND UNMUTE the mic.
May 07, 2011 | Yamaha Cm500 Headphone With Built-in Mic
Static in background of recordings
There is not enough info here to narrow this down to far. What is the sound source? The internal mic or direct via cable? Also, does the background noise stay the same regardless of the playback mode? Supplying these details will enable me to locate the problem circuit and provide potential fixes.
Thanks,
Dan
Feb 16, 2011 | Marantz PMD660 Professional Solid State...
I have Lexicon alpha, Condenser Mic, phantom power .If i record, the voice goes only to right speaker. I am using cubase le 4, stereo in/out are correctly.
Sorry, but the Lexicon Alpha does NOT have Phantom power and you can't use a condenser mic with it without a Phantom power injector or preamp.
If you mean you have a Phantom power injector then it should be working. Do you have seperate mics for the two channels of the stereo? If you have only one mic, then only one side will record unless you set for mono recording and then dump the recording into stereo voa Cubase. I would recommend you get a small mixer... even a 4 channel one to use ahead of the Lexicon so you can mix and PAN your mics the way you want them. The recording and trying to control the panning in Cubase can be frustrating... The Lexicon really doesn't have anything built in to PAN the mic to the center when stereo recording. Small mixers are inexpensive and often you can find them used or in pawn shops for cheap.
Feb 12, 2011 | Lexicon Alpha Personal Recording Studio
The recording level to my Mbox is very low for some reason. I am running Pro Tools LE and I have a shure 87a microphone. Every time I attempt to record a track, the input volume is incredibly low...
Make sure you turn the Phantom power on the Mbox2 on as the Shure 87A requires it being a condenser mic.Make sure you use XLR mic cables. These are just things to check on.
Jan 29, 2011 | Digidesign *mbox2...
Hi, I cannot get stereo signal from my mic. I used the recording level L/R knob correctly, but when I go to the left side, there's not signal at all. Should I use a different type of cable? Thanks,...
You mention "mic"... to do stereo you need two mics...
If you are trying to "PAN" a single mic, then you should use a WYE cable and have the single mic go to both input channels.
Jan 17, 2011 | Korg Mr 1000 1 Bit Professional Digital...
Boss Micro BR Digital Recorder Logo
195 people viewed this question
Top Boss Music Experts
Michial Gueffroy
Darial Jr Lasaria
Darial Jr Lasaria
Vito Vacirca Jr.
Are you a Boss Music Expert? Answer questions, earn points and help others
