Question about Garden
Coil fly clearance - Garden
    President:
  • 2,220 Answers
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
Card stock is usually 0.0085 - 0.0095"
If you still have no spark after assembly please reply below and I will happily assist you. HTH
Lou
Posted on Feb 07, 2010
What is the coil air gap for poulan sst25c
it is normally an adjustment that cannot be made
The closer to the magnets in the fly wheel the better as it produces a stronger spark
setting around .005" or running clearance is good
any metal filings , dirt etc regardless of the gap affects the coil performance
it is not to touch the magnets at all in passing
Mar 11, 2017 | Poulan Garden
Should the coil and flywheel touch?
Wouldn't have thought so as the fly wheel spins it will wear away anything that it touches. You will need to adjust the position of the coil away from fly wheel.
Oct 29, 2015 | Garden
No fire from spark plug
either spark plug is bad or coil is bad also check clearance between fly wheel and coil
Oct 08, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
Tappet settings husqvarna 324ld
valve clearance should be 0.10 feeler guage
Flywheel 0.25 feeler guage
Jul 28, 2012 | Husqvarna 324LDX Split Shaft Beam Trimmer...
What should the clearance be betwwen mag and fly wheel toro
The gap should be about .010 (Ten Thousandths of an inch), but truthfully, the way I set it is to loosen the coil bolts and place a shiny business card in between the coil and flywheel. Tighten the coil up snug against the business card and then remove it. This should set the gap close enough to the correct setting for you; done. Hope this helps and best of luck to you.
James
Nov 11, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
It has no spark comes out of the wire, suspect ignition coil is the problem
Hi constant12v...
You have not ignition coil on this mower, but you do have an ignition module under the fly wheel, or besides of the fly wheel that you will need to replace.
Also sand the flywheel where the magnets are to insure the surfaces are free of rust or corrosion.When you install the new iginition module be sure to have the clearance between the flyweel and the module the same as the old one..you can also use a paper match book cover to set the clearance.
Please take time to rate me
Sep 01, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
This is a Briggs and Stratton Rototiller, Model 130292-1636-02. I think my Armature might be bad. This is a Briggs and Stratton part # 397358 with electronic trigger (starter). After cleaning my fly-wheel...
the fly wheel is touche you need no more than 5 thousands clearance between the
fly wheel and the coil for the best spark
now on the other hand if you have points on this unit its best to put in new points
and condenser and set the points the same settings as the coil
this will get spark for you
hope this helps you
good luck
bob
May 08, 2011 | Ford Mustang Cars & Trucks
Flywheel to mag. clearance
Ignition module gap
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 21, 2010 | Homelite ZR10926 16" Chain Saw
What distance should the coil be positioned away from the fly wheel
it dont realy matter how far away it is,, but most bikes have the coil just under the fule tank,, thats about 1.5 feet from the fly wheel
the coil wont be upset if its bolted right above the fly wheel as there is nothing in it that the fly wheel can upset,,,,any magnets are all inside the fly wheel and will have little to no efect on the coil at all
Nov 14, 2009 | 2002 Yamaha TT-R 125 L
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
