Question about Zanussi ZWD1470W Front Load Washer / Dryer
My ZWD1471 started leaking during the drying cycle recently. It doesn't leak during the wash cycle. The water seems to be coming from underneath the back of the machine, I think on the righthand side. Any ideas? Thanks.
  • 528 Answers
Open it and see where the leack come from it might be the drain pump and it easy to replace or it might be a hose that got burst...
see if you can open it from the back or the bottom front
Posted on Feb 07, 2010
Waste water leaking from underneath my zanussi jetsystem ZWF16381
Could be slight hole in door boot seal / or circon pump suspect door boot seal
Jul 01, 2012 | Washing Machines
Water leaks out front center of door during the
Check the door gasket for any damage. A rip or a tear could be the cause of the leak.
Jul 20, 2010 | GE WSXH208A Front Load Washer
Kleenmaid top-load washing m/c leaks water and then smokes!
It sounds like you are leaking from the bottom of the unit. If you are leaking at the top then you need to check the water inlet valves, and also the drain pump and all water hoses. This doesnt sound like a seal issue.
Jan 02, 2010 | Washing Machines
Leak with heavy load
Is the machne noisy? If not, it may soon become noisy. Sounds as if the grease seal protecting the basket spindle bearings is leaking. soon the bearings will fail
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water from underneath
check the "drain pan". during defrost cycle it is filled completely.Try to shift the water out of it during every defrosting cycle.
Dec 14, 2008 | Frigidaire FRS26R4A Side by Side...
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
Probably a main tub seal, big job!
Nov 16, 2007 | Maytag MAV7600 Top Load Washer
Water leaks from inside of machine
TAWS850PQ0 WITH SAME ISSUE...found it to be the water pump located bottom front of machine...looking for replacement now...
Nov 13, 2006 | Estate TAWS850PQ
Zanussi ZWD1470W Front Load Washer / Dryer Logo
205 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
