Question about Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free Infrared Gas Heater(18,000 BTU)
We have a very annoying smell thru the house from the heater Model # 018224860 (09/2009). It was just installed by our gas company. They have been out numerous times to fix the regulator, leaks. Now that those are fixed the tech told us to leave a window open bec. we would always have this smell bec. it was reacting to something in the house. We did find a oily soapy liquid in the bottom tray from ? soap they used to check leaks. We have tried to wipe this out but still have the smell. My eyes burn and my head starts to hurt when the heater comes on. Help! Elaine
  • ssncoo Feb 08, 2010
    My Comfort Glow vent free gas heater(Model#018224860 09/2005 is made by DESA. The last time(02/04/2010 gas co.came out they told me to open a window about the smell.
    I am now burning the stove full blast with windows open for 4 hours to see if the smell burns out.
    We do have a carbon monoxide tester in another room. Should it be in the same room? We also run a ceiling fan.
    Thank you!
  • Rinnai Master
  • 43,501 Answers
From what you have written I think that you have a LP heater... Is the tank new?? if so it will take some time to burn off the bad gas and the stuff they use to "dry" the gas in the tank...
With these heaters you should have a window opened a bit at all times anyway. They are unvented so you need to have some fresh air to keep the bad CO from building up in the house...
The flame can also react with some gas inside the home...that is very hard to isolate and could take some time to go away...
You will either have to tough it out and wait till everything levels out or find a different style of heat...
Wish I could give you better news, but I can't...sorry!!
Heatman101
Posted on Feb 09, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Feb 09, 2010
    Hi, Yes, You should have the CO detector in the same room if possible. Running the heater on high may help, but if the problem is in the gas it will not help...
    It is very hard sometimes to tell exactly what it is that is causing the reaction with the gas burning...
    Hopefully you can find a way to get to the bottom of the problem....
    My gut feeling is that it is a tank/gas problem, but you will have ahard time getting your supplier to admit it...!!!
    Heatman101
  • 534 Answers
What you may try is to open the windows and turn on the heater for a couple of hours and let the chemicals burn off the elements where the spilled some of the leak check fluid This fluid is just soap and water they use it to test for gas leaks. Also, have a carbon monoxide test done since you are saying your getting headaches. In fact I would have the monoxide test done asap to insure your safety.
Good luck hope this helped you some
Dave
Posted on Feb 08, 2010
Click on the link below to view related information on a smell coming from your Rinnai heater:
http://answers.yahoo.com/question/index?qid=20090516225626AAqIjdN
Posted on Feb 07, 2010
My gas heater will light then once the house reaches temp on the thermostat the pilot light will go out and you can smell gas
Turn it off and get a serviced person immediately. You should call your gas company before your domicile becomes pieces from the impending explosion. They will find the leak for you and probably recommend several companies that can repair it.
Nov 18, 2014 | Heating & Cooling
Flame & Piolet going out after a short time of use.
To burn Lp gas there has to be a bigger spud (because of the density). Lp gas also has to be changed to a vapor and not liquid. Having a storage tank in the cold ambient can present problems due to its relative high boiling point.
Dec 16, 2013 | Williams Heating & Cooling
Mastertemp 400 NG heater - unused gas smell when firing
Ask the gas company for the conversion kit part part number they used.
Jul 11, 2017 | Pentair Mastertemp Heater
Smell Gas
If you are smelling gas it is advised that you just call the gas company, they come out for free and find out what it wrong. Some heaters will always produce a small amount of gas smell, but most don't. You can check all of your gas lines with a little soap and water and see if you see any bubbles and if you do then tighten that part up.
But you will even need to check your gas valve for possible leaks also
May 16, 2010 | Pentair Minimax NT Heater
I have Wiiliams direct vent wall furnace. I smell gas only when pilot is on and burner is not on. It does not smell when it is fully running (burner is on)
Dear Alex191: I am shocked and amazed that the Williams heater company is STILL knowingly and willingly selling faulty direct vent gas heaters. My problems took place in 1988! I bought a 30,000 BTU Williams DIRECT VENT from The Home Depot. I took the time to remove window sashes and run gas line to the Williams heater that I had placed in the window aperture. I was glad to finally have heat and be able to heat the area of the house where I stayed. Then I began to smell gas when the Williams was OFF. I traced it to the area where the pilot light gas tubing entered the combustion chamber. I removed the Williams unit and replaced it with an identical make and model and the SAME THING HAPPENED!!! I sat on my bed and almost cried. I had the gas company come out and they labled the problem as a "fuzz leak". The warranty repairman came out and had no idea what to do. Tightening the retaining nut did nothing. I called Williams and even back then they said that they were aware of the problem. They called me back and wanted to send me a part and asked me, "Can you work on it?" I returned the Williams and bought a Perfection-Schwank CONSOL heater that burns the air in the room and vents horizontally to a 4 inch vertical gas vent and was very satisfied with it. When they went out of business I bought an "Empire" brand gas heater. I don't know if I'll ever buy another direct vent heater from anyone. I will be glad to write an affidavit should you decide to suit the Williams company.
Feb 20, 2010 | Williams 1403622 Gas Compact Heater
Gas heater smells like kerosene and stings the eyes,
this probably occured after you were vanishing timberin your house and has since stopped
Jul 22, 2009 | Rinnai Vent Free Gas Heater/
Rheem tankless water heater gives error code, flashes 80. Also what do I use to seal the exterior of the vent? Should the vent outside smell like gas?
check to make sure that your flue pipes are together if the have not been put together properly it will not start, it has to pull in cold air while exhaust is forced out,, if it isn't right it will pul exahust thru the cold air intake and shut sown or not start at all,, you might want to call who ever installed it,they are supposed to warraty it for 1 year on labor at a min, to be able to install them thru the company,, rheem,, they are supposed to be quilaifeid and have a card that states they took the class to have the knowledge to do so.
Jun 01, 2009 | Rheem EcoSense by 4.2 GPM Tankless Water...
Bad gas smell when heater is operating
I would call him back out. It sounds like a gas line is loose or the vent is not on properly
Jun 01, 2009 | Rinnai Vent Free Gas Heater/
Smelling co2 around tank, replaced ventilation but still smell co2? need to see if there is a special way to install ventilation (model # whirlpool fg1f4040s3nov) gas water heater
You may be smelling other products of combustion but CO2 is a color-less/smell-less gas. A water heater should be vented thru 4" vent pipe to either a chimney or a wye which joins it with another appliance and a larger(size must be calculated) connector which connects to the chimney. There can be no reductions in size as you travel toward the chimney, and all pipe must slope at least 1/4"/foot up toward the chimney. Single wall vent pipe can be used unless it is less than 6" from anything flammable in which case type "B" vent may be used with a clearance of down to 1". If all this is correct your chimney may be over-sized or obstructed. Proper venting can be very complicated and technical and takes up most of most installation manuals for any fossil fuel appliance.
Pleas rate my answer!
Mar 25, 2009 | Whirlpool Water Heaters
Ventless gas heater smells like kerosene
It is posible that your heater is burning fumes from paint, varnish or stain and some times carpet cleaners or other household cleaners. I work for a utility company. We get called to homes for a lighter fluid/kerosene smell quit often. Most of the time it is from the fumes burning off on a standing pilot gas oven. The odor collects in the oven and is released in the customers face when they open the oven door. This will happen with any open flame appliance when exposed to these fumes.
Feb 05, 2009 | Procom 10K BTU, Vent Free, 2 Plaque...
Heating & Cooling Logo
63 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
