Question about Kenmore Refrigerators
Water dispenser leaking.
The water dispenser is leaking, and it appears that the ice maker's water dispenser is leaking too. The water chute leading to the ice maker is frozen solid.
I'm looking for a repair manual so I can locate the valves to replace them.
  • 311 Answers
The inlet valve will be located in the back of the ref. You have to remove the access panel and the valve will be mounted usually on the right hand side (if your looking at it from the back). To replace the valve you have to shut off the water at the saddle valve probably located in the basement. If you are replacing the valve then I would also replace the saddle valve at the same time its only about 10 bucks, because they usually gunk up w/ calcium deposits which lead to problems with the inlet valve of the ref.
Hope this helps _MJ_
Posted on Feb 07, 2010
Ice maker over flows
Not sure on this brand, but on some ice makers, there is an adjustment for the length of time the water the water runs down the chute. See if the ice maker instruction sheet is in the back of the unit - it may show where and how to adjust the time. Another idea would be to partially close the water valve that goes to the ice maker unit, so less water gets into the ice maker. However, over time, this will mean the valve will leak through when the valve is turned off. Good Luck
Feb 20, 2014 | GE Monogram ZDI15C Automatic Icemaker
Ice maker freezing up at water chute.
It's probably the water fill valve seeping which requires replacing that valve on the back of the refrigerator.
Jul 21, 2013 | GE Profile PSW26P Stainless Steel Side by...
GE Refridge GSH25JFXBB Ice but no water
This is solution to frozen water 'plug' preventing water dispense but ice maker still making ice. I first tried a suggested fix from this site to just leave dispenser light on overnight. I added some aluminum foil sealed over the module with a little tape to hold in heat. By morning still no water dispensed BUT I escalated the suggested fix by 1.) placing a large mug of boiling water in the compartment behind the aluminum foil 'cover' heat seal and 2.) added a small bean bag heating/cooling pad [heated in microwave] to the ice chute in the door from the freezer side. After one change out of the two 'heat sources' (about 30 min)...viola! Water dispensing again; proving it was an ice plug in the water dispenser. NOTE: When first adding the heating bag to the ice chute in the door, I found that a good bit of frost had formed at the top of the ice chute, so it appears this problem arose when someone (maybe even me) didn't close the freezer door completely due to overcrowding in that section of the freezer pushing against the freezer section door.
May 02, 2012 | Refrigerators
I purchased a new whirlpool conquest and have had on for two days. i have water coming out of the water dispenser but still no ice production. There is no water in the chute leading to the ice maker. ...
Maybe it won't call for water until it goes through the cycle. Try putting water in the ice mold and see if it starts working when it freezes and dumps the ice. Make sure the water line is open by swapping the wires on the dual water inlet valve. Then the water dispenser will send water to the ice maker and you'll know the valve and line works.
Sep 01, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Will not release ice and makes crushed ice, even when on cubed.
I believe in your case the ice maker part number WR30X10093 being electronic with the control board in the front is the problem. I think the control board behind the front cover of the ice maker may have corrosion and causing the ice maker to malfunction. You can try disconnecting the set of wires to the coil on the water control valve and see if the water stops or turn off the ice maker first and try disconnecting the coil wires later. It has to be the control board or the water control valve part number WR57X10032
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Our KitchenAid just started leaking. it is coming from the front ice dispenser on door. seems many people are having this problem. there is also "snow" on ice maker and bucket. and the temperature...
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
The excess frost on the ice maker and bucket can be caused by the ice chute door not closing all the way or a leaky door gasket letting air in.
Jul 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Refrigerators Logo
125 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
