Question about Watts Onan Portable Generator - 4000 , Model# 5500
ONAN GENERATOR STARTS THEN ONLY RUNS WITH CHOKE ON
    Genius:
  • 1,036 Answers
This sounds like a problem with fuel settings or dirt in the jet.
If you can find the carb adjustment screws, with it runing on full choke - screw it in fully untill it stalls, then back out to original position, then restart.
Take off choke and adjust setting untill it runs well when warm with choke fully out.
You can then try and make it run leaner without stalling.
Posted on Feb 07, 2010
SOURCE: 6.5KW Onan generator. wont run when the start button is released
Flight systems can test the onan circuit boards. google them they will come up. First class operation my board was was checked out and back to me in about a week, They also sell new boards and deduct the 20 dollar bench fee if yours is bad and you buy a replacement from them.
Posted on Mar 23, 2009
erickg
  • 116 Answers
SOURCE: Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Posted on Apr 17, 2009
mamicheddy
  • 79 Answers
SOURCE: Onan 20K Generator runs constantly in stand by mode
Your remote start wires going into your transfer switch are closed, which means you transfer switch is the problem.
Posted on May 09, 2009
mamicheddy
  • 79 Answers
SOURCE: Only runs if I hold the start switch
The problem is that you are not creating voltage. Remove front cover. Place a volt meter on the breaker. Start genset and you will see no voltage present. The problem could be with the brushes, rings, rotor, stator, voltage regulator, or control board.
  • 134 Answers
SOURCE: Onan generator: Pro 6000e: engine runs, no
Are you getting any kind of voltage output at all?
Posted on Nov 11, 2010
Onan marquis 7000 generator, cranks up runs for about a minute then starts loping, starts to shut off, choke opens, any ideas
Clean the carb and all the orifices inside the carb under the bowl. It will probably run after that.
Sep 22, 2017 | Electrical Supplies
Will not run without manuely chocking
Sounds like the unit has sat, and carb gum, Try draining the carb bowl and re-filling. There is a screw at the base of the bowl. Also make sure when cold choke is closed. And it opens fully after 3 minutes. Check battery voltage on choke coil.
Dec 17, 2013 | Onan 5500 Microquiet Generator
Have a k450 onan gen will only run with choke almost closed
My K450 onan tag along was doing this and an adjustment of the governor set screw ( voltage +/- )cleared it up.
Oct 01, 2013 | Electrical Supplies
Onan 6.5nh manual download
Right here you go. www.cumminsonan.com/www/pdf/specsheets/a-1509.pdf
Feb 17, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan Generator runs rough and eventually dies
Take the air cleaner cover off and look see if choke is opening. Depending on model should be spring choke but could be elect. Onan has good files on their web site.
Mar 21, 2009 | Sport & Outdoor - Others
Feb 11, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
1,571 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Jim London
Jim London
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
