I need a service manual for a Gateway Monitor Service no FPD1976W LCD
  • 3,230 Answers
Well you can please follow the below link to get your service manual -
http://www.eserviceinfo.com/equipment_mfg/Gateway_43.html
or
http://support.gateway.com/support/supinfo/index.asp?pg=2&file=dt_mon005.html
or
http://support.gateway.com/s/Manuals/Monitors/8512558.pdf
Good Luck!!
Thanks
Posted on Feb 07, 2010
My FPD1976W Gateway monitor will display for only 2-3 seconds then go black. I can turn monitor off then back on it will display for 2-3 seconds then again go black. Start button is not blinking. Does this...
You've got it, one of the circuit boards has one or more failed capacitors.
If you decide to take it apart, check for capacitors with either a bulging top or a yellow stain underneath on the board itself.
Befored taking it apart, because you will, even if just slighty, damage the screen case, check your warranties. I had one pop recently, it had a 3 year - return to base warrany.
Jul 13, 2011 | Gateway FPD1976W LCD Monitor
Gateway FPD1976W 19" Widescreen LCD Monitor. The "TOUR" menu and Adjustment menus keep flashing on and off, and do not respond when you press the side button to shut them off
davea47, Your monitor's internal "switchmode-power-supply" is probably having a problem. You may need to do some electrolytic filter capacitor replacement!!! Problem not new one!! You or qualified lcd monitor technician will need to open unit for inspection/evaluation of power supply board. Do some reading in the fixya profiles of "budmrtn" "buddymc" "12fixlouie" (me) and follow links you find there. After investigating your unit let us tech's here at fixya know what you will do to repair unit. 12fixlouie
Aug 11, 2010 | Gateway FPD1976W LCD Monitor
My FPD1976W start botton is blinking blue. Why?
It is either not getting the video signal from your PC, check all the pins at both ends of the VGA cable), or it is in shutdoen mode due to short circuits or failed power supply due to bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 02, 2010 | Gateway FPD1976W LCD Monitor
Gateway 19 inch fpd1976w problem
Power supply will be the first place to look, look for bad caps (bulging tops or bottom seals). Check it out and post back what you find so we can guide you further, see example of failed monitors due tobad caps: http://s807.photobucket.com/home/budm/allalbums
The high pitch you are hearing can be from the bad lamp soldering connection, it is arcing.
Jan 24, 2010 | Gateway 19" Widescreen Flat Panel TFT LCD...
Welcome Screen Blinking Gateway Monitor
I would suggest that you re-install the disc. that comes with the screen.
If that doesn't work, check to see that your video card is working correctly.
May 26, 2009 | Gateway FPD1975 19" LCD Monitor
Screen resolution 1440 x 900 not available
Hi. Does your computer have an on board video board?...and if it does...have you downloaded any video software?....some video boards wont work properly if you have software for a different video board on it. Try going to your control panel..and see if you have more than one video board installed....and then disable it. Let windows decide which one to use.
Nov 11, 2017 | Gateway FPD1976W LCD Monitor
Computers & Internet Logo
David Payne
David Payne
