Question about Compaq Presario Notebook
Will not boot-powers up-no screen-power downs-repeats process until I press reset button.
    Problem Solver:
  • 6 Answers
This behaviour can be caused by an overheated processor. Perhaps the CPU fan has failed. Check the BIOS settings.
Posted on Feb 07, 2010
Reset rca tabl
1. Make sure that the tablet is actually powered off.
2. Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
3. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
4. Next use "Volume Down" button to get to the "wipe data/factory reset" option When in recovery mode the "Volume Up" and "Volume Down" buttons are how to can navigate and highlight what option you need.
5. Once you have selected the "wipe data/factory reset", press the "Power" button to select that option.
6. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is selected.
7. Then press the "Power" button to hard reset the tablet.
Jan 18, 2017 | Tablets & eReaders
Samsung galaxy s5 will not hard reset
Hi Anthony
  1. From your home screen press the Apps icon in the lower right corner.
  2. Find and press the Settings icon.
  3. Scroll down to the users and backup section and press the Backup and reset icon.
  4. At the bottom of the next screen press where it says Factory data reset.
  5. Hit the Reset device to complete the process.
Second way of resetting your Galaxy S5.
  1. Press and hold the power button to turn the device of.
  2. If your device does not respond, remove the battery and put it back after a few seconds. ( Don't turn it back on )
  3. With your device of press and hold the volume up and the home button, then without releasing the two other buttons press and hold the power button as well.
  4. Hold them depressed until your phone boots with the words Recovery mode in the upper left corner .
  5. To navigate the recovery mode screen use the volume up and down to go up and down. Use the power button to select an option.
  6. Press the volume down button three times until the Wipe data/factory reset option is selected.
  7. Press the power button to select this option.
Mar 04, 2016 | Samsung Cell Phones
I forgot the password for my nokia lumia 928 how do i unlock it
Note An alternate reset method is available if the device can be powered on and is responsive.
Ensure that the device is powered off.
Press and hold the Volume Down button (located on the right-edge of the device; above the power button) until instructed to release in step 4.
Press and hold the Power button until the device vibrates (approximately 2 seconds) then release.
Note Alternatively, connect the device to an approved USB charger while continuing to hold the volume down button.
When the restore screen appears (exclamation mark), release the Volume Down button.
From the restore screen, press then release the following buttons to initiate the reset process:
Volume Up
Volume Down
Power
Volume Down
Note Allow several minutes for the process to complete (rotating gears appear on the display to indicate that the reset is in process).
Note To setup the device after the reset has completed, refer to Initial Activation and Setup.
Sep 06, 2015 | Nokia Verizon Wireless Lumia 928 Windows...
Unlock screen on lgl34c
when ever you forget the
pattern lock and can't access the
phone, below is a step by step guide
on how to reset it.
1. Switch off the phone by pressing and holding the power button.
2. Now, press and hold the power button and the volume down button
(Power-on + Volume down button)
together until the phone has power on.
3. On the next screen that shows up, you should see about four ( 4 ) options, scroll down to "Factory Reset" or "Clear Flash" and select it. (Use the " Home button" or Switch button to select).
4. On confirmation, the factory reset process begins immediately. And,
when the process completes, the
phone boots up without the pattern security lock.
TIPS: For navigation purpose to explore
other options on the screen, you can
use the (Volume Down key) to
navigate down, the (Volume Up Key)
to navigate up and the (Home Key)
to select the option you want, you can use (Switch button) to select in some android phones
Nov 01, 2014 | Cell Phones
How to restore to factory default
To perform an External Manual Reset of your handset to restore to factory settings, read instructions below and then perform.
  1. Power off the phone, press and hold volume down button, press power button.
  2. Screen will come up with "Fastboot", press Vol down key to cycle through choices until you get"Android Recovery", then press Vol up key
  3. Wait for the "triangle ! / Android" screen then go on to step 4
  4. Tap on bottom right corner of the screen (may take a few times). a menu will come up
  5. Tap on "wipe data/factory reset", and tap OK. Another Confirmation screen will come. Tap Yesand OK
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. Tap OK.
  7. Phone will reboot to initial setup MOTOBLUR screen.
Tip: Once you've reset your device, you can use your existing account to sync your contacts back to the phone.
(Steps on Gingerbread 2.3)
Remove and remount the battery and power up
If the phone still does not boot up to the MOTOBLUR screen, then perform the following Factory Reset instructions:
  1. Power off the phone, press and hold the Volume down button and Power buttonsimultaneously while powering up the unit.
  2. Screen will come up with "Fastboot" at the top of the screen, press Volume down key to cycle through choices until you get "Android Recovery", then press Volume up key to boot in this mode
  3. Wait for the "triangle ! / Android" screen then go on to step 4 android_recoveryscrn.png
  4. Press both Volume up and Volume down key simultaneously. A Recovery Menu will come up
  5. Tap on Volume down key until "wipe data/factory reset" is highlighted, and tap Power button. Another Confirmation screen will come. Tap on Volume down key until coming to Yes and tapPower button
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. TapPower button
To Perform a Factory Data Reset through settings menu:
  1. From the Home screen, press Menu
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset (Read notes for other options)
  5. Touch Reset Phone
  6. Touch Erase Everything
Oct 20, 2014 | Samsung Cell Phones
How to master reset LG Optimus Fuel LGL34C
reboot the phone. Once you see the LG screen during boot start tapping ONLY THE VOLUME UP BUTTON repeatedly until the phone reboots. This should get you into the recovery. From there you should be able to click the factory reset button.
Sep 28, 2014 | Cell Phones
How do i reset my toshiba satelite c55-a5300?
Yes you should be able to, toshibas use a couple of methods to do a factory recovery. If your tosh came with a recovery disk you can use that, ensuring the boot sequence is from the cd drive, more modern toshibas use a recovery partition.
1. Copy all your files and documents to an external storage device.
2. Shut down the computer.
3. Turn the PC back on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears.
4. Click "Repair Your Computer" if you are not already on it and then press ENTER
5. choose your country and click OK
6. On the "System Recovery Options Screen" click "Restore Application" which is the last option.
7. Follow the on-screen instructions
8. When prompted, click on "Full Factory Recovery"
9. "Next"
10. Click "Yes"
11. you will notice for a while it seems like nothing is happening, give it some time.
12. After some minutes, recovery will complete and you click "Finish"
Or switch off the laptop by holding down the power button for 20s' then press and hold the "0" (Zero) key then tap the power button again to switch on. Keep holding down the zero key until you hear a beep the recovery process should start
Jul 19, 2014 | Computers & Internet
How do i reset my samsung galaxy 3 if it wont come on?
1. If your Samsung Galaxy S II is frozen, Shut the POWER OFF, take the battery out and put it back again.
2. Hold the Volume Down button
3. Briefly Press and release the Power button
4. A menu will then appears that let you allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Quickly Press and release the Power button
7. Select Volume Up for YES and Volume Down for NO
If the above procedures doesn't work. try this another method:
1. Turn the POWER OFF, pull the battery out and put it back again.
2. Simultaneously press the Volume Up, Home and Power button
3. If the Samsung Symbol appears, release the Power button
4. A Boot Menu will then show, Use the volume up/down to choose and home to select.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
Hard reset motorola atrix dual core smartphone
  1. Power off the phone.
    NOTE: If unable to power off, remove and reinsert the battery.
  2. Press and hold the Volume Up + Volume Down and the Power button.
  3. The screen displays Boot Mode Selection Menu; press volume down key to cycle through choices until Android Recovery is viewed. Press the Volume Up key to boot in this mode.
  4. Wait for the triangle ! / Android screen to display, then proceed to step 5.
  5. Press both Volume up and Volume down key simultaneously. A recovery menu displays.
  6. Tap on Volume Down key until Wipe data/factory reset is highlighted, and tap the Power button.
  7. Another confirmation screen displays. Tap the Volume Down key until Yes displays, then tap the Power button.
  8. After user data is cleared, the reboot system now option is highlighted by default. Tap the Power button.
  9. The phone reboots to the initial setup screen.
Wireless
Nov 23, 2013 | Motorola Mobility Nice Atrix 2 4g Hd At&t...
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
