Question about Lowrance GlobalMap 3300C GPS Receiver
Unit turns on by itself - Lowrance GlobalMap 3300C GPS Receiver
I have two Lowrance X 125 that I don't get any Power to.
Posted on Aug 14, 2012
Thoughts about Lowrance X105 units?
Posted on Nov 28, 2012
The next thing that will go out will be your back light. you will also find that lowrance can not fix these problems because parts are N/A.. I had the same thing happen to mine. I called lowrance for repair of my unit and found this out. I ask the rep. how many years do you have part no hand for your products. he said 8-10 years.. this unit is only 5 years old and cant be fix by lowrance { no parts }
Posted on May 24, 2010
  • Chuck Lloyd
    Chuck Lloyd May 24, 2010
    also you should add a on/off switch between the batt. and the fuse on the main power wire to the 3300c unit. this will kept the unit from comming on when your not around. one last thing if your using a battery charger it may be sending a voltage surge and causing you 3300c to turn on.
How can I fix
Hello, try to clean and dry the electronic board, sometimes the humidity make shortcircuits between logic gates.
Oct 24, 2014 | Senville 18000 BTU Ductless Air...
TURNS ITSELF OFF
Sounds like the item may have OVERHEATED [will automatically switch off to protect itself from destruction]. Should re-set itself when the internal temperature returns to normal ... [My TOMTOM does the same] ... ok
OR you could have a FAULTY BATTERY or CHARGER. Both of these will cause most GPS units not to boot up or to rapidly shut down [low battery].
NB: Mobile GPS units of any kind should NOT be left mounted on windscreens in a locked car [particularly in direct sunlight] as the inside temperature can rapidly reach over 100deg AND possibly destroy your unit internally.
Nov 19, 2013 | GPS
AC unit wont work, inside coils are hissing but outside unit not turning on.
If thisnis a central air conditioner and there is hissing at the indoor coil then the compressor is running, it is possible that both fans are not running. The indoor motor may not run if the control board is bad, capacitor is bad or the motor itself is bad. The outdoor fan may have a bad capacitor or the motor itself is bad
Jul 23, 2012 | Heating & Cooling
I turn my unit on with the TV and it runs for about 15 minutes an then the unit turns itself off. I turn it back on and it last about 3 seconds and turns back off. Unit is not hot and is 4 years old.
CAPS (capacitors) on the power supply board are going bad. TV putting itself into fault protection by turning itself off..... If you can give the model number I can better help you.....
Jun 18, 2011 | Televison & Video
Pioneer VSX-45TX turning itself off
check all speakers and wire not short... you can try open each speaker testing....
Nov 12, 2009 | Pioneer VSX-45TX 7.1 Channels Receiver
The unit seems to be turning itself off. no image
check any loose connection in PCB , re solder the component lead.
Jun 28, 2009 | Hitachi 36SDX88B TV
GPS GARMIN 340 turn it off by itself.
Does the unit comes on by itself once power is applied to the unit? If it doesn't come on by itself, then there is a problem with your power supply. The unit is designed to detect when an external power supply is applied and turn itself on. It is also designed design to detect if you unplug the unit from the external power supply. It will say "Lost external power, shutting down in 30 seconds". BTW are using Garmin cables?
Dec 25, 2007 | Garmin StreetPilot C330 GPS Receiver
Unit turns itself on in standby mode
This can be a very irritating problem. Happened to me too. The only thing to do is after you turn off the unit with the remote, go to the unit and physically turn off the power to the unit with the manual Power on/off switch on the left side of the unit. Nothing else works.
Jan 14, 2007 | Koss KD365 DVD Player
Garmin C330 resets itself
The first problem with it powering itself off is a battery problem. Your battery is not hold a charge.
The second problem with it powering itself on with the power cord attached is a power cord issue. The unit is suppose to automatically power itself on if a power cord is attached to it. This is Garmin way of turning the unit on when you start your car. Most auto cigarette lighter will cut power if the ignition is off, and restore power when the ignition is on.
Garmin uses this to turn the unit on and off. If the unit was being powered by the the cigarette lighter then it say unit is shutting down in 20 seconds after the power is cut.
Jan 21, 2007 | Garmin StreetPilot C330 GPS Receiver
Lowrance GlobalMap 3300C GPS Receiver Logo
408 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
