Question about Epson Stylus® 3800V All-In-One Printer
Just changed computers my printer is printing but the ink levels are not showing and in printer maintenance the cartridge replacement is grey so unable to change ink
  • 63 Answers
If you installed from the CD you will need to uninstall and reinstall the latest driver from the Epson web site.
Posted on Feb 10, 2010
Black ink will not show up on paper
It seems print head clogged,this issue not related with cartridge, perform clean print heads 3-4 times & chk, if no result replace the print head (CN642A).. I won't suggest for manual cleaning for this print head unit.. Thanks for listening me..
Jun 20, 2013 | HP Photosmart Premium C309A All-In-One...
I've just installed both cartridges in my lexmark X4650 printer but they show as empty on the maintenance page
Note that a refilled cartridge will not be able to report its ink level. Check if correct ink level is displayed on your printer operator panel. Press Setup button > Maintenance > Ink Level - check your black and color ink levels. If ink levels are correct, then the problem could be on your computer.
The Print Spooler service on your computer may be disabled. To enable the Print Spooler service, follow the steps below:
  1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
  2. Type in "NET START SPOOLER" (this will restart the print spooler service)
Try to check your ink levels again.
Jun 25, 2011 | Lexmark X4650 InkJet Printer
I installed an allegedly compatible cartridge and it didn't work. So I fiited Epson cartridge and the printer works but does not monitor the ink levels. In control panel - printers - printing...
Do the process once again but this time remove the printer and unistall the sofftware. Now reinstall the software, then connect the printer as it will be detected as the new hardware and will be installed.
Now the printer ink level must show properly in the display and it must print correctly.
Comment if this tip worked.
Aug 27, 2010 | Epson Stylus D92 InkJet Photo Printer
When i print a black and white picture from computer it prints pinkish
Have you checked your ink levels? There is a low ink utility with HP printers that should read the ink level of the Black or Grey cartridge.
If the levels are up, then run the maintenance and nozzle check for this printer through the Print menu.
Jan 14, 2010 | HP Officejet 6310 All-In-One InkJet...
Ink level didn't change
s.gif Deskjet 5100 series
  1. Click Start or c01319360.gif , click All Programs , click Hewlett-Packard , and then click Printer Assistant .
  2. Click Utilities .
  3. Click View ink levels .
    • If a cartridge is low on ink, discontinue these steps, replace the cartridge, and then try printing again.
    • If the cartridges contain a sufficient amount of ink, continue to the next step.
  4. Click Printer Maintenance .
  5. Click Clean Cartridges .
  6. Follow the on-screen instructions.
ISSUE: After installing a new HP Inkjet print cartridge, the ink level indicator remains at the previous level. SOLUTION: Continue to print and ignore the ink level indicator. The print cartridge is full of ink, it just is not being measured accurately.
May 29, 2009 | HP Photosmart D5160 InkJet Printer
Cant change ink cartridge on my Epson C91
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head by hand to replacement position.
May 02, 2009 | Epson Stylus Photo 1400 Printer
How do you check ink levels
Introduction This describes how to check the estimated ink level in the cartridge. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, keep a replacement ink cartridge available to avoid possible printing delays. Ink cartridges do not need to be replaced until print quality becomes unacceptable. Checking ink levels Perform the following steps to check the estimated ink levels: NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Figure 1: Estimated ink levels
Nov 23, 2008 | Office Equipment & Supplies
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
All in one printer does not scan or copy
If the Ink Status is showing a ? symbol after you have replaced the tanks, you just need to tell the printer that you replaced tanks ,
To do that , open your lexmark solution centre from the Lexmark start menu group.
Click Maintenence
Click Install New Print Cartridge
Jan 18, 2008 | Lexmark X1240 All-In-One InkJet Printer
Won't print in black
open your list of printers. r/click on the 780 and open properties. fo to the last tab "maintenance" and run cleaning 2 or 3 times then run deep cleaning 2 or 3 times. and see how this helps. If you've never done it before you might want to take out the print head and clean it with alcohol. Take out all the ink like you were changing them then reach in and gently pull out the container that holds the ink. This is the print head. Clean it and replace it, then run clean and deep clean again. run Nozzle check to see how clean it's become and you'll definetly see a difference in your printing. good luck
Sep 13, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Epson Stylus® 3800V All-In-One Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
