Question about Juki MO-644D Mechanical Sewing Machine
Kaye turner where can i get a manuel
Can Not get the screw to turn on needle plate and I need to clean lint out since my first big project on the brother cs6000i was a baby flannel quilt
hello if you are using an open hole turner put a spoon shaft or something like that through the hole it will give you a better pressure to open the screw i hope this helps
Dec 26, 2017 | Brother Sewing Machines
How to release the turner gear?
Usually the handwheel has an outer wheel and an inner wheel. The smaller inner wheel is usually the one that, when turned counterclockwise, will release the needle bar so you can wind a bobbin.
Nov 27, 2015 | Sewing Machines
I am looking for a manuel for my Royal XL6000 sewing machine. Where can I get a manuel?
You must contact the manufacturer, or conduct an Internet search using Google or Yahoo. Also check eBay, Amazon, and Alibaba.
Sorry, no manuals here!
May 11, 2015 | Sewing Machines
Nee Elna Envision 8006 ownersw manuel
see if the link for a manual is the right one for the machine Elna 8006 Instruction Manual
Apr 19, 2014 | Sewing Machines
I have a Riccar Reliant 53 sewing machine,
Very unlikely you will get a manual for a Riccar, the only place with any hope would be www.sewusa.com
Mar 01, 2010 | Sewing Machines
Balance wheel on sewing maching does not turn
hi have you recently refill bobbin seems like you need to reengage clutch tighten inner wheel on hand wheel or slide switch depending on machine refer to your manual good luck
mary h
Dec 27, 2008 | Sewing Machines
Brother sewing machine
I have only a cheap one (VX-1100), but when this is happening on mine, the stop-motion knob isn't fully engaged with the balance wheel. They are held together by one being tightened to the other for sewing, loosened for bobbin winding. Michael
Aug 31, 2008 | Sewing Machines
Juki MO-644D Mechanical Sewing Machine Logo
15 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
