Question about Boating
Ihave a 1982 mercury inline-6-115hp am having carb-boat motor
Ihave a 1982 mercury inline-6-115hp am having carb trouble ,when trying to start gas is coming out of carbs and once I get it started and shut it off gas runs out of carbs.Ihave been told that this is a problem with this type of motor would you have a solution thanks alot
    Top Expert:
  • 47,720 Answers
Floats are sticking in the carbs . rebuilding is the only cure
Posted on Apr 26, 2010
I have a 1999 mercury mariner 5hp 4st motor, there's gas coming out of 2 holes in the top of the carburetor
Sounds like pressure builds up. I would say to rebuild the carb. Very easy job to do.
May 05, 2017 | Mercury Boating
1982 mercury 40 hp outboard dies when put in gear.runs on hose new plugs-cdi clean carb.
When you run a motor on muffs there is no back pressure at the prop. try up the revs to ar900 rpm's
Good luck..........
Dec 07, 2015 | Boating
Why is a 1981 Mercury 115 HP inline 6, hard to start and #1 #3 cyl wont hit till motor warms... good compression all the way thru.
1 and 3 obviously running off different carbs,sounds like problem in distributor,have you checked spark when cold
Aug 16, 2014 | Boating
Mercury 15 leaking fuel wont start
where is fuel leaking from ? give me past history how it came to not starting ! carb clean ? sparking at the plugs ? compressions ok ?
Mar 18, 2014 | Boating
1982 Yamaha Seca Turbo (XJ650LJ) Had the carbs
Mine was stored for 20 years, I ended up replacing the seat and needles, cleaning them thoroughly and when I tried starting it, nothing!! No gas was going to the carbs, it turned out to be my gas pump, it was seized by the old gas remains 'varnish' so I had to clean it numerous times, soaked it in gas cleaner (short period at a time 15 minutes or so, being a very powerful cleaner, you cannot leave it for long without causing greater problems, thus I was able to get the pump going by boosting it with my car batterie, having more cranking amps directly to the pump, the pump was able to release itself from the old crusty varnish.
Aug 29, 2011 | 1982 Yamaha XJ 650
My bass boat sat for about 8 months. I had it on the water this weekend and it was not idling well and had trouble starting. Once started, the boat ran well when i was in the throttle. I ran the old gas...
SOUNDS LIKE THE CARB LOW SPEED JETS ARE CLOGGED , THANKS TO THIS PITIFUL GAS WE GET TODAY ,I USE A ADDITIVE CALLED SEA FOAM IT WORKS GREAT JUST ADD TO FUEL EVEN WORKS FOR WINTER SET UP TOO
HOPE THIS HELPS
Aug 10, 2010 | Light Outboard Motor Boat Bass Fishing...
How to clean boat carburetor. 1984 35 hp mercury outboard sprays gas out of small hole towards top side of carburetor when starting. Motor will start on occassion for 5-10 seconds, but then gas will spray...
Carburetors are tricky, They have to be completely dismantled, soaked in carb cleaner, make sure all the gunk is off, every jet clean and clear, If you can't get a wire through it, you won't get gas through it, make sure you can blow through it, Get some guitar strings, .009 is about the smallest guitar string you will find, you can buy them separately at the music store if you don't have one. Change the filter in the line, when the carbs go back on, the adj all have to be the same, not one wide open and 2 idleing, Float level is also important, they don't sell complete kits anymore, you have to buy the parts individually, gaskets , etc, good luck.
Feb 14, 2010 | Light Outboard Motor Boat Bass Fishing...
I have 15 hp mercury hasnt been ran in two year tryin t sell when i first tryed to start it the motor would start run 1 to 2 seconds and die out thought primer bulb was bad went and bought new one then it...
my uncle told me to take the spark plugs out to check if they were dry and if they were to take a spray bottle and put gas in it and spray inside the pluggs and give it full throttle. The motor started on the seconed try.
Jan 15, 2010 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
608 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
