Question about Garmin StreetPilot C330 GPS Receiver
Street pilot 330 will not turn on when plugged into car power supply. Poosible battery charge needed?
    President:
  • 949 Answers
Does the car charger cord have a fuse in it at the point where it plugs
into the lighter port, a lot of car chargers have a fuse, I can't tell
if your end, the part that goes inside the lighter port has a cap that you unscrew to replace the fuse, and garmin does not show it.
If the car is running, and it does not work, there is something wrong with the car adapter, or the unit at the plug, the battery should not have anything to do with it.
If the battery starts the car the battery is fine.
Posted on Feb 07, 2010
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
My garmin street pilot 330 will not power on
I've had a couple of Garmin C330 units and a C340. They're good quality except for the flimsy power plugs. My first one out of the box had a defective plug which made intermittent contact when I plugged it into the lighter. Tightening the knurled nut on the tip of the plug helped somewhat, but didn't fix it completely. It became a non-issue after I bought a friction mount which came with a better cord and plug. The friction mount also stopped the problem of the suction cup constantly falling off the windshield.
Lee
Jul 08, 2008 | Garmin StreetPilot C330 GPS Receiver
GARMIN STREET PILOT-330 GPS
Hello KTFORE1,
The Street Pilot 330 comes with both a vehicle power cord and a USB cord for connecting the unit to the computer. If I understand you correctly the GPS isn't getting power from the vehicle power cord. Does the GPS charge if connected to a computer using the USB cable? If so the problem is likely the power cord or cigarette lighter socket you are using. If the GPS doesn't charge from USB port on your computer then the problem is likely the GPS itself.
If you determine that the cable is the source of the problem, check and replace the cable's fuse. You will probably also want to check and replace your vehicle fuses as the circuit that powers the cigarette lighter might have a blown fuse. If replacing the fuses doesn't solve the issue then you might need to replace the power cord.
Best Regards.
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot c510 problems
Have you tried charging with your computer? Sometimes this can help.
Mar 03, 2008 | GPS
Garmin 330 street pilot keeps shutting down, only had it 1 year
Have you tried charging the unit on the computer? If not, try doing this for a few hours. Sometimes it can help.
Nov 04, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin 330 street pilot keeps shutting down. Only 3 mos. old and has been connected to cigarette lighter. What is the problem? I need a manual.
Make sure that you age getting power from the plugin.
Test: With the unit OFF plug adapter into cigarette lighter.
The Garmin should turn on automatically. If it does not,
you are not getting power to the unit. Make sure you have
good connection at the holder.
Generally it powers off by itself because it is not receiving
power from the plug.
Oct 22, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot 330
Take the navigator 2 a repair center, because somethin that new, shouldn't happened unless it hasn't been charged for awhle after being in the box on the shelf
Oct 14, 2007 | Garmin StreetPilot i3 GPS Receiver
Street Pilot 330 battery dead?
it would be strange for the lithium ion battery to be dead so soon. what have you done to charge it up? there are ways to kick start the batterys but i need to know a little history on what has occured up to now.
Jul 05, 2007 | Garmin StreetPilot C330 GPS Receiver
GARMIN STREET PILOT C330
take off the front face plate. hit the reset button on the right. charge it. I've got a 320. Same thing happened. On the 320 if you look closely there is a fingernail shaped indent on the inside of the square colored face plate. just pull the face plate towards you and it will come off with very little effort.
Feb 20, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
242 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
