Question about Kitchen Appliances - Others
Started making noise. found fan filter in rear plugged with dust. found noisy fan. It was very dirty. carefully cleaned it up and put 1 drop oil on bearing. Seems much quieter now. are fans replaceable? also what are significance of green and red LED's on control board? Both are lit steady.
    Genius:
  • 1,036 Answers
I think you did the right thing by just cleaning it. The fan is really there to help prevent the motor from overheating.
Overheating is typically the way breadmakers fail, so you've prolonged the life of yours by maybe another 5 years!
Light oil on the bearing and keeping the dust down is the right thing to do.
Well done.
Red and green lights will be simple diagnostics tell-tales. Both are lit - so no worries.
Posted on Feb 07, 2010
Why is the fan in my Gateway model NV53 laptop making a buzzing noise?
Please open the fan and clean all dust and put some oil in your fan and refix it back.
May 28, 2017 | Computers & Internet
Tip
Fixing a noisy fan
As fans in electronic equipment get dirty; the dust and dirt will slowly work its way into the mechanical components of the fan, grinding the smooth plastic surfaces like sand paper. This keeps the fan from moving smoothly and eventually produces a buzzing or whirring noise from the resulting friction. In time, the increased heat and friction will simply burn the motor out and it may stop working entirely.
Some choose to just ignore the problem or simply disconnect the fan to stop the noise; however, the fan usually serves an important purpose cooling the machine. Cases are carefully designed to circulate air and even one fan failing out of several can change the airflow in such a way that pockets of heat can become trapped above chips and under critical components. While many think that washing or cleaning the fan regularly may resolve this issue, often it does not. In fact, it can make it worse by removing oil and grease intended to lubricate the parts and keep them running smoothly. Removing the dust itself will also not replace the lost plastic as normally smooth surfaces will still be scored. Many times after cleaning fans become even noisier.
Because the plastic itself is physically damaged, the best issue long term with a noisy fan is to just replace the fan yourself when it becomes unbearably loud. That said, don't pay to have a fan repaired or cleaned by a repair service unless under warranty. Most computer shops when faced with a noisy fan issue will simply soak the fan in mineral oil or lubricate it with WD-40 and return it to the customer. This only resolves the issue for a short period of time and cheats the consumer given that the computer fan itself can be bought at a variety of part suppliers so cheaply.
Just treat the noise as good indicator that failure of the fan is imminent. Generally it will not cost over $15 and once installed it runs quietly for a much longer amount of time than any fix.
on Mar 25, 2010 | Computers & Internet
Cpu fan noise
open up the laptop, locate the fan
carefully remove the plastic sticker on the center of fan, drop oil (better if car engine oil) just 2 drops into the center, put everything back together.
if still fail, possible its the ball bearing worn out. go ebay and get a replacement
Oct 16, 2013 | Fujitsu LIFEBOOK AH550 (FPCR33571) PC...
The fan in my unit is making excessive noise. Unit works fine and cools properly but the fan has become noisy. Is there any service that can reduce this noise?
I would check fan motor for oil ports and add a few drops of machine oil if they are there. Check fan blades and clean as good as possible. If you can hold on to fan and move motor shaft back and forth more then 1/8 inch then the bearing on yhe motor are worn and you will need to replace the motor. Thank you.
May 28, 2011 | GE APH10AA Air Conditioner
HI, my coolermaster laptop cooler, the U2 with 2 optional fans have been acting loud. only one fan has been acting up. it makes loud noises while the other one is silent. like a grating noise kind of. cant...
Sounds like the fan is going out. I would take it back to the store and swap it for a new one. Alternatively, if you decide to keep it you can try to put a drop of 3-in1 oil in the center of the fan to prolong and/or fix the noisy fan.
May 26, 2011 | Cooler Master NotePal U2 Notebook Cooler ...
My processor fan making noisy sound, how should i fix that?
if that is an intel processor fan, i suggest you to replace rather than fix that.
its cheaper buy a replacement than fix that.
Mar 08, 2011 | Intel Computers & Internet
Cooling fan is making noise i took it off and took it apart and didnt really know what to do so just put it back together and its still does it. what should i do?
sometimes the fans can get dirty & collect a build up of dust etc. so using something to blow into the fan & clear any dust can sometimes help. Unfortunately if this doesn't cure it then try to drop a small amount of lubricant into the motor, usually in most cases of noisy fans the only solution is to replace it.
Apr 25, 2010 | Panasonic Home Theater System System
Air filter dirty
It means the Fan is dirty clean off dirt so fan can run,or fan might be bad. More then likely fan has alot of Dust Bunnys.
Dec 01, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Compaq Presario SR1365CL (4) yrs old, fan making annoying noice
Often you can blow the dust out of the fans and it will help. In your case the bearings have most likely dried up on a fan. First blow the dust out of all the fans. To find the offending fan you will have to block the blades with something. Once the fan is found you can either replace it with a fan of the same size or re-oil the bearings. To re-oil, carefully peal away the label on the fan. There might be a plastic plug over the bearing, carefully remove it. Drop a few drops of 4-in-1 oil or sewing machine oil into the bearing. Stick the label back on and put the fan back into the system. It should be much quieter now.
Oct 20, 2008 | Mesh 80mm Aluminum Fan Filter Fan Kit
About cpu fan prob
A noisy fan us caused by 1. dirt and dust built up -Remedy carefully clean the fan blades ,case and cooling fins, with a soft brush and vacuum cleaner nozzle. and 2 dry bearing. Remedy -carefully peel back the foil label in the centre boss and in the recess place a drip if light oil[3in1 or sewing machine- do Not Use WD40 this is a drying agent- will make things worse. Replace the label. It is possubly best to do all this with the fan off the computer- usually 4 self tap screws into the coolin fins and a 2 pint plug.
Jun 01, 2007 | Asrock 775i65GV Motherboard
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
