Question about Canon PIXMA iP1600 Printer
After refilling an empty cartridge how do i reset the printer to recognize it?
  • 164 Answers
It should automatically recognize it. If it doesn't try the following:
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
I have a Lexmark X9575 all-in-one printer. When I refill the ink cartridge the printer still says it is empty. How can I reset the printer to think the cartridge is full again?
Lexmark Printers will not recognize Refilled Cartridges, The Fuse inside the cartridge blows and makes the cartridges Unusable is there is an attempt made to refill one!
Apr 08, 2013 | Lexmark X9575 InkJet Printer
I replaced the black ink with a refill cartridge and its saying black ink volume unknown. went back and got a new refill cartridge says same thing...please help?
All cartridges are "tracked", which basically just means that when you run the cartridge down on one printer, if you put it in another it will still appear to be empty. With refilled cartridges, your printer may see it as empty because it has been empty once before. If your printer accepts it and still prints, your best option is just to let it go. Print with it and just ignore the message. You'll know when you need a new one because your printouts will start to fade or streak.
If your printer won't accept it or print at all, you can try performing a hard reset to try and trick the printer into thinking it has a new cartridge.
1. Open the cover and take out the cartridges.
2. With the cover open, unplug the power source from the printer.
3. Wait 20 - 30 seconds for the printer to reset.
4. Install the cartridges and close the cover.
5. Plug in the power source.
6. Turn the printer on and let it go through its regular startup process.
The hard reset option is not a guaranteed fix, but it is a good idea to try; it works on many models and brands very well but there are some that fail to recognize the refilled/remanufactured cartridges after a reset.
Feb 25, 2011 | Office Equipment & Supplies
I filled in a Dell 924 cartridge and now the printer does not recognize it and does not print
if the cartridge is chipped, it will still be recognised as empty, since the cartridge uses a backwards counter to estimate the amount of left-over ink. there are tools to reset the chip on an ink cartridge to refill it, which you can normally buy in the shop where you bought the refill-kit (if not already included). please note that the cartridge may not warn you again about being empty. when print quality deteriorates, refill. if print quality stays bad (even after a refill), replace the cartridge with a new (original) one.
Jan 18, 2010 | Dell 924 All-in-One InkJet Printer
Canon mx300 not recognize reffil cartridge color 51,
This cartridges has a memory chip and printer will recognized refill cartridges like empty.You can't reset the ink level on all Canon Pixma printers.Push resume button and hold it for 5 seconds.This operation releases the function for detecting the remaining ink level of the above ink.The printer shows empty cartridges but it will printing.
If this not help there is a minimum chance your cartridge is failed electrically and printer not recognized.In this case replace the cartridge.
Nov 18, 2009 | Canon MX300 Office All-In-One Printer
How I can reset my canon mp270,lamp B is lighting all the time. I have filled black ink and know my printer dont recognizes cartridge. My computer shows that it is empty.
Nov 14, 2009 | Canon PIXMA MP240 All-In-One InkJet...
How do i go about refilling epson T5591/2/3/4/5/6
Before you can have unlimited refilling you must need this devices:
Option 1: The chip resetter which you will need to manually reset the cartridge before refilling to enable the printer to recognize a new cartridge.
Heres the link where you can buy the resetter:
http://cgi.ebay.ph/CHIP-RESETTER-For-EPSON-T5591-T077120-T078120-T0791-INK_W0QQitemZ290276640766QQcmdZViewItemQQptZBI_Toner?hash=item4395d607fe
Option 2: You a new set of empty cartridges with autoreset chips in it. No manual resetting needed, what you need is to refill and monitor the ink level.
Explanation: When the printer detected that the cartridge is empty, the printer sends data to the cartridges and the cartridge understand what the printer says, then the cartridge automatic chip resetter will re trigger the logic circuit built in into it to reset into full ink level.
Here is the link of the autoreset chip what Im taking about:
http://www.made-in-china.com/image/2f0j00wCVtjAmMPlchM/Refill-Cartridge-with-Auto-Reset-Chip-Canon-520-501-.jpg
Oct 21, 2009 | Office Equipment & Supplies
I have the error message that it can not recognize the ink cartridge and it is blocking me from using the macine in any function. I have removed the ink cartrdige and it still says it cannot recognize...
An ink tank which has once been empty is
installed. Replace the applicable ink tank with
a new one.
Printing with a once-empty or refilled ink
tank can damage the print head.
If printing is continued without replacing the
refilled ink tank, press the Stop/Reset button
for 5 sec. or longer to record the use of a
refilled ink tank.
Oct 08, 2009 | Canon MP610 Photo All-In-One Printer
When refilling canon ip4500 cartridge they still show empty
I'm sorry you got that STUPID answer first. The Canon cartridges you use have a chip or small circuit board on the bottom front. You have to either reset that chip or get the reset chips from the place you get your ink. That little chip tells your printer how much ink has been used and once they are empty refilling doesn't help without a new or reset chip.
Jul 18, 2009 | Canon Pixma iP4500 InkJet Printer
No automated fax receiving with refilled cartridge
You need to reset the chip on the cartridge for it to work properly.
Mar 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Epson stylus dx 7450 printer
You have a wide format printer but it has the same basic principle as the desktops. You can buy remanufactured cartridges which were reset for you. Or you can refill them. If you refill them, you need a resetter because Epson cartridges have a chip on them which needs to be reset. Because when they are empty, the printer will recognize it as empty and will not function till you put in a new cartridge. If you bought a remanufactured cartridge, and your printer won't recognize it, you need to go back to who sold you the cartridge and either have them reset it or give you a replacement.
Jun 19, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Canon PIXMA iP1600 Printer Logo
85 people viewed this question
old marine
old marine
