Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a 435 side tensioning and after around 30min of use the side mounting slackens cousing the chain to come off damaging the chain
  • dontbother10
    dontbother10 May 11, 2010
    With a new chain that is not excessive. By side tensioning do you mean tool-less, or is the adjuster between the bar nuts?
    President:
  • 2,220 Answers
With a new chain that is not excessive. By side tensioning do you mean tool-less, or is the adjuster between the bar nuts? You can reply below and I can finsh answering your question. HTH
Lou
Posted on Feb 08, 2010
  • 677 Answers
What is happening is the chain is heating, and expanding.
Make sure you have a full tank of oil, and the recommened blade for your saw.
Also make sure the bolt(s) are not damaged on your adjuster.
Husqvana 435 chainsaw comes loose after 5 minutes nof use ?
if it is the chain that comes loose, loosen of the blade lock nut and adjust it with the screw under the blade
the proper tension of the chain is achieved when you pull the center of the chain up and the clearance to the blade is around 1/16 inch( leaving the inner section of the chain still in the blade guide
retension the lock nut
Mar 28, 2017 | Garden
I have a huscavarna 435 chainsaw and after running a few minutes the chain locks up
You may have the chain tensioner set a little too tight.
Additional things to check:
  • The sprocket on the end of the guide bar is greased, and turning smoothly.
  • The chain brake is working correctly (not dragging or only partially disengaging).
  • The guide bar is straight, not bent or twisted, burr free, and the groove the chain travels in hasn't been squeezed together.
  • The chain tension is set correctly.
  • The chain oiler is functioning correctly (and you have a sufficient amount and correct type of bar oil).
  • Chain is in good condition, and the correct one for the saw. Make sure all of the links flex smoothly.
  • Chain is sharp. A dull chain will put more pressure on the guide bar because the cutting teeth aren't digging into the wood efficiently (and usually a person pushes harder on the saw when the chain is getting dull).
Chain side tensioning
http://husqvarna.custhelp.com/app/answers/detail/a_id/590/kw/chain%20tensioning%20screw/related/1
Mar 21, 2016 | Husqvarna Chainsaw Model 435 16" inch bar
How to remove the chain from a husqvarna 235e chainsaw?
Like this or pretty close.
  1. Cock brake while expanding chain brake binder by pulling brake handle towards left-hand (wrap-around) handle grip, hard, until it locks in place.
  2. Loosen 2 brake-asssembly-and- bar retaining nuts but do not remove yet.
  3. Unscrew (turn CCW) bar adjustment screw on front face of unit in order to shorten bar and slacken saw chain.
  4. Slip chain off bar over bar tip and towards inward side of bar.
  5. Remove two nuts loosened in step 2 and pull brake assembly and bar straight out and off bar mounting studs.
  6. While rotating clutch/brake-drum, maneuver saw chain off sprocket and around drum perimeter to remove from saw.
  7. Repeat/reverse steps 6 thru 1 in that order to reassemble.
25045742-0m3nstwfcb55vn4usb1qox2f-3-0.jpg 25045742-0m3nstwfcb55vn4usb1qox2f-3-2.jpg
Sep 01, 2014 | Husqvarna 14-Inch 34cc Gas Powered...
Removing cover to changeing chains
Remove the 2 side casing nuts.
Slacken off the chain tension screw. (it may be attached to the side casing).
Remove bar and chain.
Replace chain on the bar and reposition back and the saw.
Put the side casing back on and adjust the chain tension for the new chain.
Tighten up the 2 side casing nutsonce bar is in working position.
Apr 14, 2013 | Husqvarna Garden
Adjusting chain tension
There are a number of different types of adjusters, front manual adjusters, side manual adjusters and tooless adjusters, the two latter systems require you to slacken the bar nut/nuts and with a flat blade screw driver turn the screw clockwise to increase chain tention, the chain should touch the bar rails all around the bar with no sagging on the under side of the bar, with a gloved hand you should be able to pull the chain around easily to make sure its not too tight, with the tooless adjuster slacken off the bar nut/nuts and turn the thumb wheel down to increase the tention.
Jun 12, 2012 | Garden
Change the chain instructions
General instructions are, if the machine has a chainbrake make sure this is off, loosen the side cover nut/nuts, wind the bar adjuster screw back to slacken the chain, remove the side cover, push the bar back to the sprocket, the chain should now be lose enough to lift it off the tip of the bar and un loop off the sprocket, now loop the new chain over the sprocket and around the tip of the bar, make sure the cutters on the top of the bar are facing away from the saw ( a pushing chain )now re fit the side/chainbrake cover, if the bar adjuster pawl is in the brake/side cover, make sure this aligns with the adjuster hole in the bar, re fit the bar nut/nuts finger tight, wind the adjuster screw in so as the chain sits snuggly all around the bar, with a gloved hand pull the chain around the bar manualy, it should pull smoothly, lift the tip of the bar up and fully tighten the nut/nuts, run the saw, there will be an amount of initial stretch, slacken the bar nut/nuts and re tention.
Aug 24, 2011 | Poulan Pro Chain Saw 46cc 20"
How do you set the chain tension on a 345e?
The E version is tooless, so flip out the wing in the centre of the big cover fixing nut,slacken the nut off half a turn, now turn the knurled adjuster in the side cover, down to tighten, up to slacken, there are many schools of thought about the correct tention of the chain, but basically the chain should sit snuggly all round the guide bar, and with a gloved hand pull manually around the bar with out too much force, it should never sag on the bottom of the guide bar.
Apr 27, 2011 | Husqvarna Chain Saw 20" Bar
Remove water pump
Disconnect battery earth lead. Do not turn crankshaft or camshaft whn timing beld removed. Remove spark plugs to ease turning engine. Turn engine in normal direction of rotation (unless otherwise stated) Do not turn engine via camshaft or other sprockets. Observe all tightening torques. Remove engine, remve RH engine mounting. Remove auxiliary drive belts, water pump pulley, crankshaft pulley, timing belt upper cover, timing belt lower cover. Turn crankshaft clockwise to TDC on No. 1 cylinder, slacken tensioner bolts 5 & 6. Move tensioner away from belt and lightly tighten bolts. Remove timing belt. Remove water pump and replace with new one. Suggest to replace cambelt as well.
Installation
Ensure timing marks aligned3 & 4. Fit timing belt in anti-clockwise direction, standing at crankshaft sprocket. Ensure belt is taut between sprockets on non-tensioned side. Slacken tensioner bolt 5. slacken tensioner bolt 6. Allow tensioner to operate. Tighten tensioner bolt 6. Tighten tensioner bolt 5. Turn crankshaft on turn clockwise. Ensure crankshaft sprocket timing marks aligned 4.
Slacken tensioner bolt 5. Slacken tensioner bolt 6. Allow tensioner to operate. Tighten tensioner 6. Tighten torque: 20 - 26 Nm. Tighten tensioner bolt 5. tighten torque: 20 - 26 Nm. Apply thumb pressure to belt at middle. Approximately 5kg. Belt should deflect to 1/4 of tensioner bolt head width 7. Belt tention can also be set using burroghs (BT-33-73F) tension gauge 10 at middle. Turn crankshaft 90 ° anti clockwise. Check belt tension is 9.5 16,5kg (engine must be cold). Install components in reverse order of removal. Fit cranckshaft pully. Tighten crankshaft pully bolts 8. G4-J: Tightening torque: 12-15Nm.
G4-N/G4-k: Tightening torque: 10-12Nm
G4EA: Tighten crankshaft pully bolt 9. Tighten torque: 140-150Nm.
Nov 04, 2009 | Hyundai Excel Cars & Trucks
Is there an adjustable chain tensioner
The rear wheel hub is eccentrically mounted and held in position by a pinch bolt. Simply slacken off the pinch bolt rotate the hub using the C spanner supplied in the tool kit, retighten, check tension in accordance with the sticker on the chain guard and you are in business.
Jul 03, 2009 | 2001 Honda VFR 800
I am replacing the water pump of my 1995 3.0 v6 infinity (same as altima) but my son removed the chain with out marking it, now I need to set the timing. How do I do this? There's marking on the valve...
This should be the same engine as the Maxima. If that is the case, there is no reason to remove timing chain or get it out of time. The pump is driven by the timing chain, but is not "in time".
The pump is under its own cover. The chain tensioner is under its own cover. The pump is removed after the tension is released on the chain, the tensioner pinned in its retracted position to take tension off chain, and the crank is rotated about 20 degrees counter clockwise to slacken the chain at the pump sprocket without coming off the cam sprockets. Then, the pump is remove by removing its mounting bolts and then screwing in three long M8 bolts as jack bolts into 3 holes (carefully and evenly) to jack out pump. The pump is sealed from the engine case by two o-rings that must be replaced. I think the pump mount bolts are sealed with silicone when replaced. I would get a Haynes or other reliable manual.
If you truly have to reset or check timing, definitely get a book.
Jan 12, 2009 | 1995 Nissan Maxima
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
85 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
