Question about Refrigerators
Water in bottom of refrigerator and no water in
Whirlpool refrigerator has water in bottom of refrigerator and no water in recovery pan under refrigerator. Unit is 10 years old and this is first problem with it. It is not equiped with ice maker unit.
  • 3,740 Answers
Hi and welcome to Fixya. I am Kelly.
Water buildup or pooling in a refrigerator is a good indication that the chassis / cabinet drain is obstructed. This can be caused by debris or ice build up in the drain. Your checking the recovery pan for any signs of water was a wise choice. The recovery pan should show signs of some water most of the day. It does dry however dry up.
I see you did not provide a make or model number but....here is what you can do. Follow the drain tube to the freezer section and locate the drain funnel in the rear and bottom of the freezer compartment. Some times you can see it other times you will have to remove the shelving and the rear evaporator coil cover to locate the drain funnel.
Once you gain access to the funnel check for debris or ice build up. Any debris in the funnel can cause pooling during a defrost cycle that will freeze in the funnel after the defrost cycle is completed. Your probably going to have to thaw the ice in the drain funnel before you can remove the debris. A hand held hair dryer works great for thawing the drain funnel. It takes longer than you might think and you will have to sponge up the pooling water so the ice that is deeper in the funnel will also thaw. Once you think you have the drain thawed check to see the passage is clear with a toothpick. (DO NOT drop the tooth pick getting it out of the drain is NOT fun.) If the toothpick immediately hits a dead end there is still probably ice in the funnel and the thawing process will need to continue.
Once you are sure that it is completely thawed out clear the debris if there is any. Then pour about a shot glass sized amount of water into the drain. (you might have to improvise a funnel for the water) The water should rapidly exit the drain and arrive in the recovery pan. If you don't see the water in the recovery pan then the drain tube still has an obstruction somewhere. Most of the time if the drain funnel in the freezer compartment is known to be clear there is a build up of gunk on the very end of the drain tube where it dumps into the recovery pan.
I am pretty sure that by you following these instructions you will sucessfully return your refrigerator back to normal.
Again thanks for using Fixya and if you need anything more just reply here and I will respond.
Posted on Feb 07, 2010
  • 572 Answers
Ur drain is clogged
  • hitechapp Feb 07, 2010
    ur drain is clogged
I have a whirlpool designer 20 refrigerator, it is collecting water at the bottom. What is going on? How can I fix it?
In the freezer, under the cooling coil, is a drain pan that collects water after the coil defrosts. The drain opening from this pan is probably plugged with debris. If you can find the drain line under neath the refrigerator and blow through it, this will usually clear it.
Oct 09, 2014 | Whirlpool Refrigerators
My refrigerator water dispenser leaks water in the water pan. The unit is about 10 year old. It just started leaking.How do I stop it from leaking?
If your water filter is located behind the grille at the bottom of the refrigerator the O ring seal is leaking. Happened to me. Get a new one.
Feb 21, 2014 | KitchenAid Superba Architect KSCS25INSS...
Water at bottome of refrigerator
Under the draws in the back, there should be a drain hole that drains water down to the drain pan under the unit. Check to make sure it's not blocked with food or frozen water.
Jul 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking onto the floor directly under the freezer of my side by side g.e. refrigerator. Water is frozen in bottom of freezer floor. Is this a costly fix? Refrigerator is 10 years old.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator is one year old. There is a bad
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} You may have had something drip and somehow get under the fridge. I know blood dripping from meat will smell. It could have dripped down through the defrost drain tube to the pan underneath. You can access the pan from the rear by removing the cardboard cover. If the smell seems to be coming from the pan, it's difficult to remove so I would just pour some bleach in it to kill any smell and you may can wipe it out from there. The drain tube may also have the smell in it so you can pour some bleach into it from the inside of the freezer at the bottom of the rear panel. You can move the fridge to see if anything is pooled on the floor that might smell.
Jan 06, 2010 | Whirlpool Refrigerators
Whirlpook ET21NK--Water collecting in crispers
Self-defrosting refrigerators turn themselves off to defrost once in each 24-hour cycle. There is a 'drip pan' under the refrigerator that catches water from this automatic defrost cycle. The pan is not very deep, so if the unit is leaning very much, water will run over the top of the pan. For this and other reasons, you should try to keep the unit as level as possible.
Aug 21, 2009 | Refrigerators
Water in the bottom.4 years old,upper freezer
You probably have a defrost condensate blockage somewhere between the freezer and the condensate pan under your refrigerator. here is a link to a page full of different reasons for leaks. Just choose the part that most resembles your situation, Thanks, Sea breeze
click below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | Whirlpool Refrigerators
Defrosts/refreezes
IF YOU TAKE THE BACK PANEL OFF INSIDE THE FREEZER YOU WILL FIND A PIECE OF METAL UNDER THE EVAPORATOR COILS IN MIDDLE OF THIS METAL PAN IS A HOLE THAT LEADS THE WATER TO THE BOTTOM OF THE REF FOR EVAPORATION THE HOLE IN THE PAN IS PROBABLY PLUGGED TAKE THE ICE OUT AND CLEAR THER HOLE
Aug 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water collecting under crisper drawers.
When the refrigerator goes into defrost mode there is a drain tube that allows water melted off the evaporator coil to go into the drain pan that you found empty. That drain tube is clogged.
May 02, 2017 | Whirlpool ET1MHKXM Top Freezer...
Condensation forms on the top inner ceiling of the refrigerator
Very common problem I have repaired many times , The drain is frozen or plugged.
remove the back panel in the freezer section to get to the evap./cooling coil , then check the pan under it , there is a small 1" drain hole at the bottom that may have ice in it or its clogged with something else.
Use hair dryer or similar to remove ice then get a wire or something similar that is firm to use to snake out and clear that drain hole you want to get about 10 inches down into it.
Pour bleach into evap pan and let it sit for a bit. [10 minutes]
Then to know its cleared well pour a cup of water into the evap pan then check the pan under the unit at bottom behind kickplate to ensure the bleach and water has made it to this pan.
If unit is now draining here , wipe remaining water off top of ref. compartment and by the next day it will usually stop.
Let me know if you have any other questions.
Phil
Apr 14, 2009 | Sharper Image Ionic Breeze GP (SI730) Air...
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
