I bought new humax IR twin today ,, it is working with my 2 crads , but when i press the fav key or ok to check the chanles list a note come out said upgrade the subscrible chanles and then the receiver freez ,, is it problem with the receiver ?
  • 3,230 Answers
Well YES it's the receiver problem you need to call your operator to solve this problem........ Please post comments for more help or information........
Good Luck!!
Thanks
Posted on Feb 07, 2010
My Samsung surround sound will only work with HD channels on my Humax 1100s. Any advice please.
SOURCE: http://www.naijatrace.com
Try turning off the volume ontv and place your sorrund sound on AUX that should help. Ok
Nov 24, 2017 | Samsung Audio Players & Recorders
600t appereance on the diggital screen humax irhd-5oooC. now have no tv picture. The remote also does not work and all connections are good as well as the batteries. What to do?
To check the remote, use a digital photo camera, not an iPhone, because it has an IR filter, to see it transmits codes, when you press a button. When the remote does work, you have to fear the Humax is defect. Just check if the Humax gets power. Power form the mains, but also if the cable is still firm in the socket.
Mar 10, 2015 | Humax Televison & Video
How to rest Humax IR-ACE SII ?
1. Go to the "STB Status" in Main menu
2. Press "Red" key -> "Green" key -> "Yellow" key -> "Blue" key ->
"White" key -> "0" key using the RCU in sequence.
3. Pin code will be reset to "0000" automatically.
To reach a 'manufacturer' hidden menu, in the STB Status menu, press
[red] [green][yellow] [blue] [white] then select one of the following options
0 - Reset pin Number
1 - Loader Download
2 - Application download
3 - Eeprom data download
4 - Channel data download
Best Regards
Essam Nabih
Mar 13, 2011 | Televison & Video
I want to set my remote to only the chanels I recieve
you can press the guide button, when your guide comes up look under list or fav list and press teh guide button till you see ALL SUBS. and you good to go!
Oct 16, 2009 | DISH Network IR Remote Control
I have HUMAX IR-ACE SII receiver,want 2 use nilesat
Very simply throughout the "Menu" :
01- Press Menu button on remote control.
02- Select "Installation" , input safety password - normally from
factory ( 1-2-3-4) .
03- Select "Antenne Setting" , press "OK"
04- In "Edit Satellite Data", Press "<" , then ">" , now press "Add"
05- Select Satellite , press "OK"
06- In Satellites menu select "User Define"
07- When "Do you want to rename Satellite" shows up press "OK"
08- Input (Nilesat 102) by clicking letters/figuers in sequence , then
press "OK"
09- Set Parameters as defaulted, then press "OK"
10- Now in "Edit Satellite Data", press "<" ,then select the new
sat you've just entered (Nilesat 102), and press "OK"
11- Go Back to Installation Menu by pressing "<"
12- Select "Automatic Search", press "OK"
Hope I was helpfull, best of luck
Aladin Essa = alaaalaa1900@yahoo.com
Apr 03, 2009 | Audio Players & Recorders
Setting humax foxsat hdr remote to control panasonic tx32lxd60 tv
Had the same problem with my panasonic - it would appear that none of the codes will actually turn the TV off because they need a longer signal to turn off. I eventually found that code 0650 works for mine - input the code as instructed in the manual and then selected OK - holding down the standby button on the humax controller then turns the TV off. Try all the codes and see which gives most control functions. Hope this helps.
Jan 01, 2009 | RCA 3-Device Universal Remote with...
Viewsat
This is what worked for me:
Manual Code Search and Entry
1. Manually turn on the TV
2. Press and hold the TV button The illuminated ON•OFF key turns on and remains on.
3. While holding the component key down, press and hold the ON•OFF key. The illuminated ON•OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
5. Release both keys. The illuminated ON•OFF key remains on. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next
code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
TIP: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON•OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
8. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality.
Good Luck
Jul 31, 2008 | RCA RCR311B Remote Control
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
