Question about Logitech R-20 Computer Speakers
Speakers not working on computer/ they did before
Computer was cleared and the speakers worked find until then. they work on my i pod touch now please help
    Guru:
  • 239 Answers
Don't panic..cool Well it seems ur default output device is not the same Go to control panel\sounds \ playback Pls set ur default device here
Posted on Feb 07, 2010
My bose pod is not working
hi, First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
goodluck
Jan 20, 2011 | Bose Companion 3 Computer Speakers
Connection to I Pod touch from PC desktop computer Unable to connect
1.- You must verify that the desktop computer works without problem in wireless way with the D-Link device.-
2.- The I Pod touch device is an external unit to the desktop computer, so you have be shure of the first condition.-
3.- If the destop computer don`t work in wireless conditions, the fail is in the configuration of the LanWireless, you must check both, D-Link device and computer configurations.-
4.- If the computer works ok, the problem is only in the I Pod touch only.- You muts to check fisical connections and I Pod hardware.-
Sep 02, 2010 | D-Link DI 514 Wireless Router (DI-514)
I Pod 8G built in speakers won't work; can only hear with ear
I had this problem too. Try restarting it. Hold down the lock and home buttons until the apple logo appears again.
Sep 18, 2009 | Apple iPod touch
Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Aug 12, 2009 | Bose Companion 3 Computer Speakers
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
Jan 29, 2009 | Bose Companion 3 Computer Speakers
Altec Lansing Vs3151 Control Pod
The green connector on the control pod broke. Where can I get a replacement? The orange and black connectors still work and everything else work.
Jan 12, 2009 | Altec Lansing VS3151 Computer Speakers
Strange problems with Z-2300's
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Nov 12, 2008 | Logitech Z-2300 Computer Speakers
Bose Control Pod won't work
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
Oct 03, 2008 | Bose Companion 3 Computer Speakers
5500 d Control pod
Hi Hlth501
So far, is better to get a new control pod. Call the company and see if work for buy it
Nov 25, 2007 | Audio Players & Recorders
Logitech R-20 Computer Speakers Logo
110 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
