Question about Sharper Image Air Purifiers
I don't know which setting to use...on the top is a button that has press blue on the left and press green on the right, which do I use? Also, it has ON, OFF, or GP, What is GP? Thank you for your help.
  • 11,896 Answers
ON is just the fan suction, but GP activates the magnetivity which attaches more dust particles to the filter.
Posted on Feb 07, 2010
Does the ionic breeze blow air
They only move the air slightly. They are not like a conventional fan.
They do not rotate.
They do work effectively for mold spores and dust. If yours has not been cleaned in a while remove the front element from above and spray the stainless bars down with an acidic claener like "Formula 409" and wipe them down after rinsing. On the unit itself unplug it and remove the front and rear grill br pressing a small tab at the bottom of the grille and push upwars. Be careful with front grille as there is an ionizing wire there towards the inside of the unit. If the unit has come from someone else, with an emery board and gentle pressure just make one pass witht he wire gently between board and your finger. drawing towards the spring loaded end. Do the same to the two wires inside the unit housing if present, Witht he rear grille removed, remove the bulb and wipe it down with a cleaner if needed- it should be clear. as it is a UV bulb.
Dust out hte base area with a small paintbrush and remove as much dust as you can from it. If need be a slighly damp rag cna also be used.
With the front of the Ionic breeze unit facing you, there are 2 conductive rubber strips that also need to be wiped down with a lsightly damp rag. They should be removing some black dust. Also wipe down the inside of the front being mindful of the two stainless wires.
Let unit dry off and reassemble.
With left knob turned to left- no light should appear. Turn knob to the right and the UV tube should light and the Boost button should light up blue when pressed once- and green when pressed a second time and then off if pressed a third time. It will only light when the left knob is turned to right.
The right knob adjusts "Low," "Medium" and "High" intensity of the high voltage applied to elements.
Alow unit to dry before powering it on.
A working system should raise the hairs on the back of you hand or give you some other sensation of moving air
Sep 29, 2012 | Sharper Image Ionic Breeze 3.0 Air...
No power
mine was having the same issue. its been broken for 2 years now. i jsut fixed it a few minutes ago. there is a button sensor behind the top filter. if its not pushed in all the way it wont turn on. my filter was in correctly, but the button doesnt appear to be depressed all the way. when fastening the back cover it locked in good, but was still slightly loose. those two things together means the sensor wasnt being triggered.
with your unit correctly assembled plug it in. while plugged in simply press the top of the back cover (where that sensor is) and the light should go green. i then taped it tight with a thin electrical tape as to not limit the airflow. it now powers on and works great.
hope that solves it for you
Mar 08, 2012 | Honeywell HHT-145 Air Purifier
Unit turns on, but none of the lights work (like to indicate the level of square feet it is set to), and pressing the buttons don't seem to make any difference (such as increasing or decreasing the...
The plug in the back may have come loose that connects the buttons & lights to the circuit board. Have you ever taken the machine out of the wood carcass? You will need to do so to re-connect the plug.
Jul 17, 2011 | Ecoquest Breeze AT Living Air Purifier
Replace air filter warning light to reset?
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Sep 30, 2010 | Filter Queen Defender Air Purifier
Press power, buttons light up and thats it
Try pressing the clean cell now button & check pre filter button at the same time hold buttons down at the same time for about 5 seconds with the air cleaner turned of and blue screen lit
Jan 30, 2010 | Kenmore AC2044-1 Air Purifier
Blue flashing light on lumipure air purifier
I read on another site to hold the power button down for 5 seconds. Dont know what the blue light is but this stopped it from flashing!
Jun 13, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Ionic Breeze Professional GP series.....question regarding lights
red light will not go off what do you do or is it still working or not and the red light is just on
Apr 04, 2009 | Sharper Image Professional Plus Ionic...
Ionic Breeze - Press Blue - Press Geen button
The blue means the germicidal lamp is operating. Re: green light - Normal operation at all power levels involves a pre-programmed cycle of altering high and low air movement. Press the the green to override the regular power control setting and run the unit at maximum power for five minutes. Your previously selected power level will resume after the five minutes has elapsed.
Dec 11, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Air Purifiers Logo
    32 people viewed this question
    Top Sharper Image Air Purifiers Experts
    Daniel Dollive
    Daniel Dollive
    Mike Squire
    Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
