Question about GE GTS22WCP Top Freezer Refrigerator
Freezer works o.k.,but fridge does not get very cold
Defrosted it and it works for about 3 or 4 months then coils in freezer freeze over and have to defrost agian.
    Genius:
  • 1,036 Answers
There should be a defrost heater that that takes care of this if it is supposed to be "frost free"- but obviously this isn't working properly. It could be the heater, thermistor (thermostat) or the control.
Just check that the door seals are still ok and not split, as this can cause excessive build up of ice.
Posted on Feb 07, 2010
Fridge portion doesn't get cold
The defrost circuit is not working, there are usually 3 things that normally go bad, defrost timer, defrost heater, and thermal switch. Would have serviceman check it out as cooling fins on coils will cut you like a razor.
Jul 24, 2017 | Whirlpool Centralpark 25.6 Cu. Ft....
Why do freezer coils ice up on my Stainless Steel Whirlpool refrigerator (model GB2SHDXTS)?
On your model your cntrl board has a relay that can stick causing the compressor to always run even when the unit is turned off or in defrost. turn the fridge off, move the temp of the freezer to it's warmest setting and it should display a line in the freezer and fridge temp display. listen to hear if the compressor is running in back of the unit. if it is you need part number: 12868513
Mar 15, 2013 | Whirlpool Refrigerators
The coils in the freezer department keep icing up completely. I manually defrost and then it works for a time (a couple of months) until the coils freeze again.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 09, 2011 | Refrigerators
The freezer gets really cold but the vent that runs from the freezer to the fridge freezes up and the coils also. when i clean the coils and the freezer vent it works great for 2 weeks then it starts to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | Maytag MSD2656G Side by Side Refrigerator
The self defrosing fridge freezer is freezing and leaking inside of fridge, 3 weeks ago I melted ice in freezer and drain with hair dryer, worked for 3 weeks, now freezes agin?
You have a problem with the defrost system. There 3 components... heater, thermostat, and timer or adaptive defrost control depending how old your refrig is. Check heater and thermostat( located on the evapotator coils) with an ohm meter. The heater will have some resistance and the thermostat will be closed(must be cold). If these check good replace timer or adaptive control.
Mar 24, 2010 | Refrigerators
Sid By Side Freezer Icing and Fridge not Cold
most fridges in s.a the defrosting is done by the thermostat if the fridge does not have a pc board
Jun 16, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
Freezer to cold refrigerator not cold enough
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Jan 28, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
GE GTS22WCP Top Freezer Refrigerator Logo
132 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
