PROBLEM WITH PREACTOR I HAVE A RUN TIME ERROR . IT SAYS THE FOLLOWING 11:DIVISION BY ZERO FUNCTION NAME: CREATE LOTS ANY ONE HELP ME
  • 110 Answers
Read solution From here!!
Hope You get your solution there!!!!!!!!!!!!!!
Regards
Vikas Agrawal
MCA
Posted on Feb 09, 2010
How do i factor numbers on a ti-30xs calculator
This calculator does not have a key that you can use to find the prime factor of an integer.
You can however use the calculator to find the factors
1. If number is even divide it by 2
Keep dividing by 2, while keeping track of how many times you divided by 2.
If you divided 5 times by 2 before getting an odd number, then your first factor is 2^5
2. Now try dividing by 3, keep track of the number of times you divided by 3 before you could not divide by 3 any more. If you divided 0 times by 3, your second factor is 3^0, or 1 and 3 is not a factor.
If you divided 4 times by 3, your second factor is 3^4
3. Divide by 5, until you can't any more. Keep track of the number of times you divided by 5.
4. Divide by all other prime numbers 7, 11, 13, 17, 19, 23, 29, 31, 37, 41, etc. For each prime number, keep track of how many times you divided by it, until you could not any more.
Example: 23100
Division by 2
23100/2=11550 ---------> 1 division by 2
11550/2=5775 ----------> 2 divisions by 2
Note that 5775 is not divisible by 2. No more divisions by 2.
First factor is 2^2
Division by 3:
5775/3=1925 ----------> 1 division by 3
1925/3=641. 66667 Not an integer. No more divisions by 3.
2nd factor is 3^1
Division by 5 (number ends in 5)
1925/5 =385 -------> 1 division by 5
385/5=77 ----------> 2 divisions by 5 and no more (quotient does not end in 0 or 5)
3rd factor is 5^2
Division by 7
77/7=11 --------> 1 division by 7, and no more
4th factor is 7^1=7
Division by 11
11/11=1
5th factor is 11^1=11
Assembling the factors 2^2, 3^1, 5^2, 7, 11
Prime factorization of 23100 is
23100=(2^2)(3)(5^2)(7)11
Dec 18, 2013 | Texas Instruments TI-30XA Calculator
D link adapter losing signal
Wireless Zero Configuration is a Windows service on Windows XP and Windows Server 2003 that is used to configure and manage wireless network connections on a wireless adapter. The service name for Wireless Zero Configuration is WZCSVC. On Windows XP, the display name for the WZCSVC service is Wireless Zero Configuration. On Windows Server 2003, the display name for the WZCSVC service is Wireless Configuration.
The Wireless Zero Configuration service is normally started at boot time. The programming interface for the Wireless Zero Configuration service can be used only if the Wireless Zero Configuration service has been started. If the Wireless Zero Configuration service is not started, then the Wireless Zero Configuration functions will return an error.
To enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
The Wireless Zero Configuration can also be started and stopped from a command prompt. To start the Wireless Zero Configuration, run the following command:
net start wzcsvc
To stop the Wireless Zero Configuration, run the following command:
net stop wzcsvc
Apr 10, 2013 | D-Link Computers & Internet
I want to know how to solve the Cubic equation on TI-89 Calculator
There are a lot of ways to do it. One is to write a program using the cubic formula. If you just want the roots, use the solve() or zeros() functions.
For example, to find the zeros of x^2-6x^2+11x-6, enter
solve(x^3-6*x^2+11*x-6=0,x)
or
zeros(x^3-6*x^2+11*x-6,x)
Note that solve() has "=0" in it while zeros() does not.
solve() will give you an answer of
x=1 or x=2 or x=3
while zeros will give you an answer of
{1 2 3}
which plainly are the same thing, just expressed differently.
May 09, 2011 | Texas Instruments TI-89 Calculator
Explain 1 divided by 0
In mathematics, a division is called a division by zero if the divisor is zero. Such a division can be formally expressed as a / 0 where a is the dividend. Whether this expression can be assigned a well-defined value depends upon the mathematical setting. In ordinary (real number) arithmetic, the expression has no meaning, as there is no number which, multiplied by 0, gives a (a?0).
In computer programming, an attempt to divide by zero may, depending on the programming language, generate an error message or may result in a special not-a-number value (see below).
Historically, one of the earliest recorded references to the mathematical impossibility of assigning a value to a / 0 is contained in George Berkeley's criticism of infinitesimal calculus in The Analyst; see Ghosts of departed quantities.
Sep 03, 2010 | Computers & Internet
How do i make my mpk49 pads work with samples, in other words, when i press the pad once the loop will play or the sample will play all the way threw, but right now when i press the pad, it only plays how...
Have a look in your manual at the sections on Note Repeat and Time Division.NOTE REPEAT] – Holding this button while
striking a pad causes the pad to retrigger at a
rate based on the current Tempo and Time
Division settings. The Note Repeat feature can
be synced to an internal or external MIDI Clock
source. [NOTE REPEAT] can function as a
latching or momentary button
19. [TIME DIVISION] – This button is used to specify
the rate of the Note Repeat and Arpeggiator
features. When [TIME DIVISION] is activated,
you can press one of the 8 switches to specify a
time division. [TIME DIVISION] can function as a
momentary or toggle button.
Please note that while [TIME DIVISION] is active,
the 8 assignable buttons will not function as MIDI
CC or Program Change switches until [TIME
DIVISION] has been de-activated.
20. [ARP ON/OFF] – This button enables and The manuals and updates can be downloaded here:http://www.akaipro.com/mpk49 Please let me know if this helps.
Nov 30, 2009 | Akai Music
What does "Running time error 11 / division by 0 mean?
This is what computer.hope.com list this error
"Problem with a math formula in the program or the programs code. Verify no software updates are available for the program causing this error."
Link to computer.hope.com
http://www.computerhope.com/issues/ch000380.htm
So in your case its more likley that it is an software problem caused by the GPR
Good luck
Dec 09, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
C program
See the Following Program
Leap Years
Def: A year is a century year if it is divisible by 100.
Def: A year is a non-century year if it is not a century year.
Def: A year is a leap year if it is a non-century year that is divisible by 4, or a century year that is divisible by 400. Nothing else is a leap year.
In a source file named leapyears.cpp, write a program that will prompt the user for the starting year and ending year for a range of years and print to the screen all leap years in that range, 5 years per line. You must write a separate function called isLeapYear that takes a year as a parameter and returns whether or not that year is a leap year. Your main function will call the isLeapYear function in a loop for every year within the range delineated by, and including, the starting and ending years.
Help with Code Tags c Syntax (Toggle Plain Text)
  1. #include <iostream>
  2. using namespace std;
  3. bool LeapYear(int y)
  4. {
  5. return ( y % 4 == 0) && (y % 100 != 0) || (y % 400 == 0);
  6. }
  7. double isLeapYear(double x)
  8. {
  9. if( x > -10000 && x < 10000)
  10. return x;
  11. }
  12. int main()
  13. {
  14. int x;
  15. cout << "Please enter start and end of a range of years: ";
  16. cin >> x;
  17. if (isLeapYear(x))
  18. {
  19. if (LeapYear(x))
  20. cout << x;
  21. }
  22. }
The One More Sample Of the Program
C program to check whether a year is a leap year or not.
Code: C /*
** C program to check whether an entered year is a leap year or not
** @author: Pradeep
** @date: 02/12/06
#include<stdio.h>
int main(void)
int year;
printf("Enter the year: ");
scanf("%d",&year);
** The logic is that the year is either divisible by both
** 100 and 4 , OR its only divisible by 4 not by hundred
if(year%400 ==0 || (year%100 != 0 && year%4 == 0))
printf("Year %d is a leap year",year);
else
printf("Year %d is not a leap year",year);
return 0;
If Not Satisfied Just put the Program name in Google and Search
Sep 10, 2008 | Computers & Internet
Error 158
FDirSync: Err Msg: Error [158] Requestor Not Registered View products that this article applies to. function loadTOCNode(){} Article ID : 99268 Last Review : October 30, 2006 Revision : 1.1This article was previously published under Q99268 SYMPTOMS loadTOCNode(1, 'symptoms'); When a Foreign DirSync, Directory Synchronization with Foreign Mail Systems, message comes into the DirSync directory server, these error messages may appear:
In DIRSYNC.LOG: "3/23/93 11:00:03 | Error [158] Requestor not registered :
PCM:" -or- "3/23/93 11:05:03 | Error [158] Requestor not registered : PCM:NETWORK/POSTOFFICE" In ADMIN's Mailbox: "Requestor not registered :
From: NETWORK/POSTOFFICE/USERID" CAUSE loadTOCNode(1, 'cause'); If the NETWORK/POSTOFFICE are a foreign DirSync postoffice, one of the following may cause the error: • The NETWORK/POSTOFFICE was not defined on the directory server using ADMIN:CONFIG:DIR-SYNC:SERVER:REQUESTORS:CREATE. Without this, the directory server does not accept requests from a requestor. • The REQNAME field in the DirSync message has a typo for the NETWORK/POSTOFFICE name or the directory server has a typo defined for the FFAPI gateway postoffice. • The REQNAME field does not contain a NETWORK/POSTOFFICE. For example: REQNAME=PCM: The Directory Synchronization with Foreign Mail Systems Manual does not clearly explain the need for the network and postoffice name for Microsoft Mail Software Development Kit (FFAPI)-based gateways. Other gateways require only an entry containing one of the predefined types. These types are listed in the "Foreign DirSync" manual. APPLIES TO • Microsoft Mail for PC Networks 3.0
Jun 25, 2008 | Audio Players & Recorders
Pc relocator program
Dear Sir/Madam,
CAUSE loadTOCNode(1, 'cause');This issue may occur if one of the following conditions is true: • The user account that you use to install the game does not have administrative rights. • You have programs running in the background that are interfering with the setup. • .NET Framework is not installed on the computer. • The Windows Installer program that helps you set up the game is not installed correctly.
RESOLUTION loadTOCNode(1, 'resolution'); Locate and then close the files loadTOCNode(2, 'resolution');To resolve this issue, locate, and then close Idriver.exe and Msiexec.exe.
To do this in Microsoft Windows XP, follow these steps: 1. Open the Task Manager. To do this, click Start, click Run, type taskmgr, and then click OK. 2. In the Processes tab, in the Image Name column, find idriver.exe and msiexec.exe. 3. Select each instance of both processes, and then click End Process. 4. Click Yes on each Task Manager Warning popup window that you receive. 5. Close the Task Manager.To do this in Windows Vista, follow these steps:
Windows Vista loadTOCNode(3, 'resolution'); 1. Click Start and click Control Panel. 2. Click User Accounts and Family Safety. 3. Under User Accounts, click Add or remove user accounts. 4. Click Create a new account. 5. Type in the account name. 6. Select the account type: Standard or Administrator. 7. Click Create Account. Select the account you just created. 8. Click Create a password. 9. Type in a password for the user account and an option password hint. 10. Click Create password. 11. Log off your current account, log back in using your new account. 12. Start the installation. Perform a clean boot procedure
Jun 04, 2008 | Eisenworld Alohabob PC Relocator Ultra...
Computers & Internet Logo
David Payne
David Payne
