Question about Hitachi Director's Series 57XWX20B 57" Rear Projection Television
The set is a Hitachi Ultravision Digital Model #57XWX20B. The picture "Ghosts" red. When runnung the Magic Focus, it stops on the 5th red line and goes no further. In low light scenes, it blacks out in a blinking manner.
  • 668 Answers
The Convergence IC's need to be replaced. They are located on the Board to the right, mounted on a large heat sink. They should be replaced with STK392-150's. The original IC's are probably STK392-110's.
The Stk392-150 is a updated replacement. Be sure to use Heat Sink Compound between the IC's and heatsink because these IC's do draw alot of current and heat up alot. Also look for any heat stressed Resisters.
I hope this helps,
Sky Assoc
Posted on Feb 08, 2010
We have a Hitachi 57XWX20B Rear Projection TV. We moved this week and now the TV picture is very dark. We have tried the magic focus and adjusted the brightness, yet the picture is still very dark. Any...
one of two things on this model==clean the lens on top of the chassis--the round large black ones.
Second: there is a resistor in the power supply that changes value and will cause this----also with set unplugged and back off since set was moved carefully look for any plugs not fully seated etc.
Apr 10, 2012 | Hitachi Director's Series 57XWX20B 57"...
Set 51uwx20b, how do i fix magic flash to reset factory settings
Convergence board needs repair, google you model # and see if you can purchase a repair kit.
Nov 22, 2011 | Hitachi 51UWX20B 51" Rear Projection...
My TV is the Hitachi model 51UWX20B and tried using magic focus to line up red color. Picture looks like 3D with red off center. When using magic focus it gets to the red phase and it shows the number 5...
You need to replace the STK ICs which are Convergence ICs STK392-110 use 120s or 150s
also check the small ohm resistors around ICs . They are Big Black ICs and will have part number on them ,should be located on the Right hand side of Chassis .
Mats Eletronics has Parts 1-800-628-1118 Convergence IC Kit.
Jul 04, 2011 | Hitachi 51UWX20B 51" Rear Projection...
Picture looks funny and the magic focus is not working
Model indicated cannot have magic focus--it uses a lamp---Confirm actual model number and let me help you. I am here to help.
REGARDS, SD TECH
Sep 10, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
I have a hitachi ultravision and the blue is off center.
your convergances amps ics have failed and need to be replaced alone with the 2 burnt resistors you will find then run magic focus
Nov 30, 2009 | Hitachi 53UDX10B 53" Rear Projection...
42 inch Hatachie Ultravision model 43UWX10B and
The magic focus will stop if there is a bad sensor and or a problem in the convergence circuit.
This set uses two STK-392-110 convergence chips--both along with any of the resistors that protect them need to be replaced and the set adjusted--I have repaired hundreds of these sets----
Confirm model number----and if you go into the customer menu and either red or blue will not move in any or some direction--the chips have to be replaced---LET ME KNOW WHAT YOU FIND AND I CAN GIVE YOU FAIRLY DETAILED INSTRUCTIONS ON WHERE TO GET THE PARTS AND WHAT IS INVOLVED IN THIS REPAIR.
I am here to help people--
REGARDS, SD TECH
Oct 10, 2009 | Hitachi 43UWX10B 43" Rear Projection...
''Magic Focus'' doesn't fix ghosting problem
YOU HAVE CONVERGENCE PROBLEM THE PARTS NUMBERS STK392-110 YOU HAVE 2 OF THEM THEY ARE BAD
Aug 28, 2009 | Hitachi Televison & Video
How do I adjust the HD quality for a crisper picture? I have tried Magic Focus, but need to know where the sharpness or contrast can be tweeked .
The magic focus function is to electronically align the red, green and blue beams. So all it can cure is colored ghosts. The contrast, brightness and sharpness adjustments are in the customer menu settings. With the remote just push menu and select video or picture adjustments. Those adjustments are in there.
Jun 11, 2009 | Hitachi 57F500 57" Rear Projection...
61 Hitachi Ultra Vision has double image
Replace both of your STKs big black ics If they are STK392-110s upgrade to 180s better ics Electronix has them call 1-800-223-3205
Dec 18, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi Director's Series 57XWX20B 57" Rear Projection Television Logo
292 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
