Top load washer not spinning
Have a kenmore top load washer model 110.20702990. doesn't want to spin all of the time. if i start to move the basket it will spin then. it aggitates every time though. what could this be
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Washing Mach... Expert
  • 154 Answers
Transmission may be going bad or you may have a sock or something stuck between the inner and outer tub
Posted on Feb 07, 2010
Im able to start a load, water fills, washer agitates and rinses just fine. However, once the spin cycle starts, the washer starts to make an extremely loud noise (similar to when it is off balance) and my...
If you can move your basket up and down your spinal is broke at rear of basket..You would need rear tub and inner basket for that repair......If this helped please vote need more help please ask...
Feb 03, 2011 | Kenmore 24032\24036 Top Load Washer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis washer model # 110.2703 shows code F-50
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
May 25, 2010 | Kenmore Oasis 27042 Top Load Washer
At the end of the spin cycle, my Kenmore Washing Machine makes a grinding noise like an out of balance brake drum. What could be the problem
If your washer model number starts with 110. it's a whirlpool washer. Whirlpool use a spin tube with two notches in it. There is a block assembly that holds the inner basket down on to the spin tube. This can be accessed by removing the top of the agitator and take out the 7/16 screw. Lift the agitator to expose the top of the spin tube. The tube is stripped on top where the basket sits. When the washer stops spinning, the inner basket keeps moving. That is the noise you hear. Replace the spin tube and possibly the block.
Oct 03, 2009 | Washing Machines
Drum in kenmore top loaded washer is moving freely, loud in spin
YOU HAVE RUBBER WHEELS THAT RIDE ALONG THE BASKET HOW OLD IS THE DRYER MAY NEED TO REPLACE ESPECIALLY IF IT IS A OLDER MODEL
May 03, 2009 | Kenmore 24632 Top Load Washer
Kenmore Elite Oasis HE top loading washer model #110.27082602 gives me error code F50 and doesn't spin. Other blogs tell me that it is possibly a main control board. What do you think?
Mar 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 Series Washer Spin Cycle Only issue.
It sounds like one of two things 1,A worn clutch .or 2.motor coupler is about gone,
May 20, 2008 | Kenmore 24032\24036 Top Load Washer
Washer will not spin
Could be a bad clutch or transmission. I would either call a tech or get a new washer (these newer GE models don't seem to be very reliable, go for a Whirlpool/Kenmore model next time). Here are breakdown diagrams for your washer: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=230151 Hope this helps, APP Tech
Aug 07, 2006 | GE WJSR2070B Top Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
