Question about Fuji FinePix F20 Digital Camera
Fuji Fine Pix Z5 battery won't charge
My camera works fine when the charger is plugged but the battery won't charge. I bought a new battery assuming that was the problem and it will not charge either. Also, the charging light does not go on on ther camera when the charger is plugged in. Any ideas?
  • Anonymous Jun 16, 2008
    my camera will not charge when plugged in. The battery's in correctly, but no charging light appears.
  • Anonymous Aug 15, 2008
    Ditto, and got a replacement battery, and still no go. Looking for a solution. Camera a present for my 10 year old daughter, dissappointing to say the least
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
Posted on Sep 26, 2008
Yeeah i had th same problem! my mum has th same camera brand so i tried to put hrs in. didnt realise both times i put it in th wrong way.
ways of knowing ths ; wont turn on unless charging . charging lights don't come on. battery comes up full when on charge.
hope i helped (:
just flip th battery over and try again.
Posted on Mar 12, 2010
    New Friend:
Eureka.
I have a Fujifilm FinePix F-20 which charges via build-in inside the camera. Now, it won't charge and red LED only blinks (instead of steady red which means charging). Bought new battery and still the same. Changed to different USB charger and still the same.
Then, I took out a cutter knife - not to cut but just to scratch the 3 copper terminal contacts inside the camera. While I was at it, I also scratch the battery contacts also so I cannot say for sure which one was the problem. Good news is now red LED is on steady when being charged. Then, I unplugged the DC plug to the camera and it actually showed the battery is charged - not like the empty battery icon like before.
Problem solved!
P.S. I also have a Fujifilm Finepix J20 which the battery can go in anyway you insert except that only one way will create contact and work. It is a stupid design. When you insert the battery, the edge with only one contact (instead of a double at the opposite side) should be close to the outer edge of the camera.
Posted on Apr 23, 2013
My factory reconditioned F20 outfit won't properly properly charge the battery in the camera. Everything seemed to be working but the battery would take very little charge and expired in minutes. Charging in the camera isn't that bright an idea anyway, so before I fought it out with Fuji over the warranty, I decided to see if everything else worked OK. I got a $10 external charger for the NP70 battery on EBay. While I was at it I got 2 spare batteries to keep charged, these were like $6 each and boasted higher capacity. Fantastic success. I may still fight out the issue with Fuji but I can use this great little camera in the meantime. I may never need the spares though, the original battery is just fine and has lasted longer between charges than I expected. Maybe this will work for your camera. Another thing I would look at is the battery contacts in the camera. If these have been bent or are not making contact you would have exactly that problem. The battery is fairly heavy and a good bump on the bottom could bend the contacts.
Posted on Aug 24, 2008
3 Suggested Answers
SOURCE: Fuji Fine Pix Z5 battery won't charge
My sister's Z5 was having the same problem. I realized she had the battery in upside down. There are no guides on the battery to insure that it goes in the right way.
If the battery is in correctly, and it is still not charging, I would call Fuji to get it repaired.
Posted on Apr 12, 2008
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
Camera won't charge
sometimes the charger can become loose in either the camera or the plug so try buying a new plug and if it still doesn't work then it is a problem with the camera and you will have to ask the people you bought it from
Jun 18, 2013 | Kodak EasyShare M853 Digital Camera
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
I Have a Fujifilm Finepix J37 that wont turn on, I assumed that the battery had run down so put it on charge and no lights came on, usually it lights up on the back of the camera when its charging! Faulty...
hmm i have the same problem with mine.i got a replacement battery and it worked fine for a few days but then went back to the way it was. so i'm thinking the problem is with the camera itself. how long have you had the camera for?
Sep 08, 2010 | Fuji Cameras
My camera, having worked perfectly for a year, failed
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 04, 2009 | Fuji FinePix S1000FD Digital Camera
My camera will not work with regular batteries
as far as it is working with re chargeable's then it is ok what is wrong with it , it needs more power i mean MAH so give it , to sell it go to ebay check the similar model price how much ppl are selling and post ur product
Feb 20, 2009 | Fuji FinePix A310 Digital Camera
Ni-mh
yes ther is no problem using Ni-MH batteries, as they do not have a memory effect they will be better (subject to your charger), you can get the Fuji Finepix NH-20 batteries (wj=hich are NIMH) here - Fuji Finepix F420 battery
Dec 26, 2008 | Fuji FinePix F420 Digital Camera
New memory card
Hi I have bought a new memory card, Olympus XD M 1GB. For my Fuji fine pix A330 camera, and I can't get it to initialise, or format properly, can you help me many thanks TRENA
Jun 03, 2008 | Fuji Cameras
Mar 31, 2008 | Fuji FinePix Z5fd Digital Camera
Rechargeable Battery won't charge
I think this is a general Fuji design fault in the camera circuitry. I have an older F455 which has exactly the same problem and I did the same - bought new batteries only to discover that didn't help. The only solution is to spend even more money for a stand alone battery charger.
Sep 07, 2006 | Fuji FinePix A340 Digital Camera
Fuji FinePix F20 Digital Camera Logo
1,570 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
