Scrambled BIOS Setup on MS-6570 MSI K7N2G-ILSR Motherboard
Having once setup SATA RAID 1 (mirrored) I then had a number of problems caused mainly by using XXCLONE which setup a dual boot partition which was not compatible with RAID.
I tried to resolve this myself by uninstalling XXCLONE but this left behind the XXCLONE partition and half a RAID.
The result is when I switch on most of the BIOS Setup does not show and I am unable to get into any control, DEL,F8, F12, etc. Just nothing. until it reaches the partition choice (which is disabled) and after the 20second count down it continues into an unstable XP.
I appreciate that this is a horrible pot mess but all I want to do is wipe the slate totally clean, setup the BIOS again and do a clean install
  • raf_penguin Feb 09, 2010
    Thanks Mike, I followed your advice but all was in vain because the uninstall was successfull with regard to all traces in Disk Manager, completely empty. There is still the dual boot shown during boot up but only the boot into XP functions and then only after the count down time for choice. Press Enter has no effect. I am still open to any advice. Cheers
    President:
  • 2,351 Answers
If you are using windows XP for you're operating system you can use MS disk manager to delete the XXCLONE partition. Click the start button, click run and type in; diskmgmt.msc
Once in disk manager use the help button as you're guide.
Cheers'
Mike
Posted on Feb 08, 2010
Testimonial: "Thanks a lot for sticking to my problem, I am unable to work on it for a few days but will let you know how it works out when I do so. Regards."
  • Mike Peluso
    Mike Peluso Feb 10, 2010
    Ok, lets see if this will work for you. Shut down you're system, unplug the power cord from the power supply. Open you're manual to page 2-31. Follow the instruction to, Clear CMOS Jumper: JBAT1. Wait about a 45 seconds and re-seat the jumper back to pins 1 and 2. This should set the bios back to its default settings.
    Re-connect everything. Boot you're system and press the F5 key every two seconds. This is what should load;
    Choose Safe mode. Once in safe mode. At the root of C:\ find the boot.ini file, right click on it once - from the pop-up windows click on properties. Remove the green check mark from the box, Read-only. Than open the boot.ini file by double left clicking on it.
    Copy what I have listed below into you're Boot.ini
    (Replacing you're Boot.ini):
    [boot loader]
    timeout=30
    default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
    Save as: Boot.ini ( If you're windows is home edition replace the a
    the word, Professional with Home Edition).
    Now if all this doesn't fix / remove the XXclone partition I'm left with one other choice. Download the HDD manufactures tools software.
    Example: If you're drive was made by Seagate or Maxtor, download;
    Download SeaTools for DOS now For Western Digital SATA drives; Data Lifeguard Diagnostic for DOS (CD)
    With these software programs you can create a bootable floppy disk or bootable CD to boot to you're HDD, (While is a Dos like mode). "You can delete unwanted partitions in you're case", but these programs can do so much more when setting up a new drive. Link to you're motherboard; http://www.msi.com/index.php?func=prodde...
    Lastly, if it comes to wiping the drive completely use the manufactures software. If you have a UBS mini drive to backup file than back up these folders;
    C:\Documents and Settings\ User name\Application Data\Microsoft\Address Book
    C:\Documents and Settings\ User name\Desktop
    C:\Documents and Settings\ User name\Favorites
    C:\Documents and Settings\ User name\Local Settings\Identities
    C:\Documents and Settings\ User name\My Documents
    This includes 99.5% of all you're data.
    Good luck raf!
    Mike
Bios reset on ms 6570 k7n2 delta ilsr with jumper
Hi, you can download a manual here:
http://www.msi.com/product/mb/K7N2-Delta2-Platinum.html#/?div=Manual
Unzip the file before you can read it.
The bios can also be resetet by removing the cmos battery:
The manual shows how to do it with the jumper settings.
Sep 25, 2011 | MSI K7N2 (MS-6570) Motherboard
Cannot post after overclock
On the motherboard look for a jumper labeled JBAT1. it should currently be jumpered across 1 and 2. Witht the power off move the jumper to cover 2 and 3. Wait 1 minute. Then move it back to cover 1 and 2. DO NOT TURN THE POWER ON UNTIL IT IS JUMPERED TO CROSS 1 AND 2.
THis will clear the BIOS and you should be back to original settings.
Jan 30, 2010 | MSI K7N2 Delta-ILSR (MS-6570-030)...
MSi Motherboard suddenly stopped seeing My IDE drives/ CD/DVD
Could quite simply be that its the IDE plug on the motherboard that's gone. If that's the case, you'll probably need a new motherboard.
As far as I can see, you've done pretty much everything that can be done to make sure it's not the motherboard.
Good Luck
Sep 23, 2009 | MSI K7N2 Delta-ILSR (MS-6570-030)...
New sata hard drive fitted, now says no audio deviec ,so no sound
If you just added the sata and reformatted the drive with a new copy of the Operating System you will need to reload the sound drivers located at MSI's web site in there drivers and download section.
May 22, 2009 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Sata hard instalation
Do you have an IDE hard drive fitted as well.
If so remove it as I have found out that unless setup properly IDE and SATA do not mix
Nov 03, 2008 | MSI Microstar KT6 Delta (MS-6590)...
Won't Boot up
you need to locate the JBAT1, CLRCMOS,CLRCLK, or similair terminals to clear the cmos settings or try removing the cmos battery, althogh you may need to do both as this will set the clock speed back to default
Oct 11, 2007 | MSI K7N2G-ILSR (MS-6570G-020) Motherboard
Fitting New SATA Harddrive
Hi, google msi, click mainboard, click download, click manualy download, click AMD, click ARCHIVE, you will find your mobo here listed as "MS657" everything you need will be there. Goodluck mistyman
Sep 02, 2007 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Windows Setup cant find hard disk ?????????????
Does the BIOS on your system see the drive and show it's model information? Is this the only drive on the system? If the answer is yes for both, then you can download free utilities from the web to wipe the drive clean. This will result in the loss of all existing data on your drive. You can search for "Wipe Disk" and will get several hits for free software. Once you have cleaned the drive, try instlling XP. If the BIOS does not see your drive, the XP can't see it. You may want to try other SATA ports on your motherboard, or try changing the IDE configuration in the BIOS. Let me know if this works.
Aug 29, 2007 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Computers & Internet Logo
824 people viewed this question
David Payne
David Payne
