Question about Acer Aspire 5315 Notebook
Can't get computer to recognize memory upgrade
Have an ACER 5315-2153 Laptop. I just upgraded to 2 GB but computer system info still says only 1 GB. Do I need to do something to get my computer to recognize the new memory?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 157 Answers
Hello macvalland,
Here's a 12-step memory upgrade procedure from the tigerdirect.com website:
Upgrading Your Memory to Improve Performance
Compiled By Our Editors
http://static.tigerdirect.com/html/installingmemory.html
12 Quick, Easy Steps to Installing Desktop Memory
Increasing your computer’s memory is one of the most powerful ways to improve performance.. The following 12-step guide illustrates how you can install your desktop memory upgrade in 10 minutes or less with the use of a demagnetized screwdriver. But before you begin, make sure you are working in a PC-e environment. If you handle your circuitry improperly you can inflict permanent damage. Your PC’s biggest enemy is static electricity. Static electricity can damage your module and other computer parts. You need to ground yourself to avoid "shocking" your computer. Grounding yourself removes any static electrical charge your body might be carrying. To ground yourself, you can wear antistatic wrist straps or you can do the following: With your computer turned off, touch an unpainted metal part of your computer case with your hand. Plant your feet and do not walk around (because walking can produce static electrical build-up. Now you’re ready to proceed with our 12-step program for installing memory:
1. Make sure your PC has been turned off PC! You’d be surprised how many people forget this common sense first step.
2. Remove all the power cords from your computer system.
3. Remove all the screws that secure your computer case and put them in a place where you can
easily find them..
4. Remove the computer case. Usually you can simply lift the case off once you have removed all the screws. However, if you have difficulty removing the case, consult your computer’s user manual.
5. Locate the memory slots on your motherboard. In some PCs you will find then beneath a power supply or drive. If so, you may need to remove some additional parts in order to gain access.
6. If you need the replace an existing memory module, undo the module clamps and gently lift the memory module out of the slot.
7. Take your memory module out of its anti-static bag and hold it gently by the edges. Line up the notch on the bottom of your new memory module with the empty memory slot and press the new module down with your thumbs until the pins rest snugly inside the slot. You may have to exert some pressure! When will hear a click when the memory module is installed correctly.
8. Secure the new memory module by attaching the module clamps.
9. Put the computer case back on.
10. Replace the case screws to secure the case.
11. Attach your power cord.
12. Now that your new memory has been installed, turn on your computer!
Once your memory has been physically installed, the computer must install it electronically. Once your PC is turned on, you may have to go into computer BIOS to enable your system to detect the new RAM you have just installed. Refer to your computer us
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Posted on Feb 08, 2010
I have acer travelmate 2355nxc with 40 gb hdd. want to know how to increase its speed and capacity.
Hi, how are you?
To upgrade your laptop, you will have to verify the capacity for upgrade of your laptop.
The Acer Travelmate comes with:
  • Intel Celeron-M 360 Processor 1.4GHz
  • 256MB DDR SDRAM -
  • 40GB Hard Drive
  • DVD/CD-RW Combo Drive - To read DVDs and CDs and write CDs
  • 15" XGA TFT Screen
  • Intel 852GM 64MB shared graphics
  • Operating System: Windows XP Home Edition
  • Based on this information, you can upgrade your memory depending on what type of memory your motherboard supports and how many empty slots for memory does your laptop have.
    The hard drive can be upgraded also depending on which hard drives does the BIOS will recognize.
    I will suggest to contact ACER and ask for the options and upgrades capacity.
    God Bless You!!!
    Hope it helps.
    Remember to rate solutions, to keep fixya.com working for you!!
    Feb 21, 2011 | Acer Computers & Internet
    Can i put ram from packard bell easynote into an acer aspire 5315.thanks
    RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
    2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
    2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
    2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
    Dec 21, 2010 | Acer Aspire 5315 Notebook
    I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
    512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
    Yes its possible
    Yes but the memory its going to run at slow speed 533Mhz
    Sep 26, 2010 | Computers & Internet
    I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
    Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
    So your upgrade options here are:
    1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
    2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
    Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
    Can i upgrade the hard disk of my old (2005) Acer travemate 2420 laptop?. form present 40 GB to a new 320 GB. Will it work? How much it coasts for the up gradation? also memory upgradation ..to 1 GB how...
    Price actually depends on where you make your purchases, do some research to locate the best price and yes you can upgrade your hard drive and memory, I am unsure of the type of memory your laptop needs however the hard drive you need is a 2.5 inch sata drive
    Mar 02, 2010 | Acer TravelMate 240 Notebook
    Acer Aspire 5601 4GB memory upgrade problem
    Acer systems are picky about the type of memory you use.
    What is your RAM Speed on the old chips compaired to the new chip
    You may have to reorder the same type of speed memory
    Try this website it will tell you what will work with your system
    http://www.ec.kingston.com/ecom/configurator_new/mfrmod.asp?root=us&LinkBack=http://www.kingston.com
    Aug 22, 2009 | Acer Computers & Internet
    Sir,i would like to upgrade my memory(256MB DDR2)for acer travelmate 4061nwlci pls inform if 1GB is compatible.pls help
    Your System memory is upgradeable:
    256 or 512 MB fitted as standard upgradeable to 1 GB of DDR2 533 memory, or 2 GB using two soDIMM modules.
    Regards,
    Mike.
    Feb 23, 2009 | Acer Computers & Internet
    Can't upgrade an Acer Aspire 3000 notebook to 2 gb
    Thanks for choosing fixya.com
    Your not alone in this type of problem. When it comes to computer (laptop especially) they usually have a "Max allowed ram" most times its listed in the back of the manual in small print. Its a way to keep people buying new computers (if your into the conspiracy theories)
    Chances are even a bios upgrade would not fix your problem. Mostly BIOS upgrades add support for new boot options, plug and play support, and fixes to bugs in older versions.
    You can check aspires/acers website for updates www.acer.com
    If they have an update it will comes with documentation as to what the update does.
    Hope this helps you out.
    Jei
    Dec 15, 2008 | Acer Aspire 3000 Notebook
    Acer Aspire 5315 Notebook Logo
    415 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
