I'm running Windows XP Home Edition. How do I back up my system and files
  • 1 more comment
  • thaeni Feb 07, 2010
    I don't seem to have a backup utility listed in "system tools"
  • thaeni Feb 08, 2010
    I'm not trying to go to a different computer. I just want to be able to backup my files but I can't
    find the backup utility.
    Thank You
Windows XP Home Edition: Add the Backup utility If you're using Windows XP Home Edition and you want to install the Backup utility, first locate your original Windows XP CD.
Add the Backup utility manually to your computer from the CD by following these steps:
  1. Insert your Windows XP CD into the drive and, if necessary, in My Computer, double-click the CD icon to display the Welcome screen.
  2. On the Welcome to Microsoft Windows XP screen, click Perform Additional Tasks.
  3. Click Browse this CD.
  4. In Windows Explorer, double-click the ValueAdd folder, then Msft, and then Ntbackup.
  5. Double-click Ntbackup.msi to install the Backup utility.
Note:If you bought a computer with Windows XP Home Edition and you don't have the original Windows XP CD, contact the computer's manufacturer or visit the manufacturer's Web site for more information. You can also use separate backup software that you purchase online, at a store, or the Windows Live OneCare beta.
--> Making backup copies manually Regardless of what version of Windows you use, you can manually make a backup copy of any file or folder by following these steps:
  1. Right-click the file or folder that you want to back up, and then click Copy from the menu.
  2. In Computer, right-click the disk or external hard drive where you want to store the backup copy, and then click Paste on the menu.
After you've copied all the information you want to back up onto your chosen storage format, don't forget to keep it protected.
http://www.microsoft.com/protect/data/backup/about.aspx
Posted on Feb 08, 2010
    President:
  • 1,188 Answers
I figure that you are trying to move your settings to a new PC or just formatting your harddrive for re-installation.
Follow these steps to perform a full system back-up:
  1. Start the Backup utility and select the files and folders that you want to back up.
    1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Backup.
    2. Click Advanced Mode.
      Note If the Backup and Restore Wizard starts, the utility is running in Wizard mode. You can click to clear the Always start in wizard mode check box, and then restart the Backup utility. If you continue to use the Backup and Restore Wizard, your steps will vary slightly from what is listed in this procedure.
    3. Click the Backup tab.
    4. On the Job menu, click New.
    5. Select the check boxes next to the drives that you want to back up. If you want to select specific files or folders, expand the drive where these files or folders are located. Then, select the check boxes next to the files or folders that you want to back up.
  2. Select the System State check box that is located under My Computer in the navigation pane.
  3. If the Backup destination list is available, click the backup destination that you want to use. For eg use your D: drive.
    Notes (optional)
    • If you selected File in this step, type the full path and file name for which you want to back up data in the Backup media box or in the file name box.
    • You can specify a network share as a destination for the backup file. Typically, backup files have the .bkf file name extension. However, you can use any file name extension that you want.
  4. Click Start Backup to open the Backup Job Information dialog box.
  5. Under If the media already contains backups, do either of the following:
    • If you want to append this backup file to previous backup files, click Append this backup to the media.
    • If you want to overwrite previous backup files with this backup file, click Replace the data on the media with this backup.
  6. Click Advanced.
  7. Select the Verify data after backup check box.
  8. In the Backup Type box, click the type of backup that you want to create. For a description of a backup type, click a backup type and the description appears under Description. You can select any of the following backup types:
    • Normal
    • Copy
    • Incremental
    • Differential
    • Daily
  9. Click OK, and then click Start Backup.
  10. When the backup is complete, click Close.
If you are migrating to a new system like Vista then you cannot use backup from XP as such. Please reply back for further instructions before rating this solution.
Posted on Feb 07, 2010
  • Adnan Bhatti
    Adnan Bhatti Feb 08, 2010
    You can install the backup utility from your XP Disc as follows:
    1. Put the Windows XP Home Edition CD in the CD Drive.
    2. Right-click on the CD icon and navgate to the folder: CD drive:\VALUEADD\MSFT\NTBACKUP.
    3. Double-click the Ntbackup.msi file in the following location to start a wizard that installs Backup
    4. When the installation wizard is finished, click Finish.
Laggy computer, running windows xp home
I would download Malwarebytes and run it, and kill anything it finds.
Jul 14, 2014 | Microsoft Windows XP Home Edition
Yes expert ntldr missing
It means that your computer is missing a file that windows xp needs to run boot properly or is missing a program that your home edition xp needs. Repairing the OS or windows xp home edition by means of your xp instalation cd will do the job. Just insert your xp installation disk to your cd/dvd rom and select install windows xp home edition. Then select ( repair ), and so on let it finish repairing . Once your system rebooted, let it run without pressing enter or space bar. Just watch and let your computer do the job. This will probably solve your boot problem. But before doing all of this, please check your IDE or SATA cable and also the power cable that is connected to your hard drive. Try to unplug and plug again to ensure a good connection. If this won't work, you can proceed repairing Your windows xp installation or reinstalling a new xp operating system. Have a nice day and i hope i was in any help to you friend.
Aug 18, 2011 | Microsoft Windows XP Home Edition
When I shut down windows xp it restarts I stopped auto restart and got a blue screen with this disciption on it Stop: c000021a [Fatal system error] 0x00000000 (0x00000000 0x00000000). any idea
Click on my computer.
Right Click on the C: drive.
Choose Properties.
Tools tab.
Error checking: Check now.
Choose automaticly fix file system errors.
Start, Yes, OK, Reboot the PC.
On boot a blue screen will launch and run for 5 - 20 minutes.
It wll reboot into windows when completed.
Sep 27, 2010 | Microsoft Windows XP Home Edition
I cannot install ethernet driver of hp compaq d530. Where can i find it?
Hello: I hope the following information is helpful.
If you are trying to install the driver for the Broadcom ethernet NIC that was pre-installed (NOT an ethernet card that you purchased and installed yourself), there is a softpack (updated driver installation) download available from HP/Compaq. It will install the driver automatically for you, just download it from the link below and run the ".exe" file.
IMPORTANT: Check to be sure that your current Operating System, and model of the network device you are trying to install, are BOTH listed below BEFORE you download!
This is a software / driver update for the HP Compaq d530 ultra-slim desktop: All Models
Supported network devices:
BCM5906M Broadcom 10/100/1000 5782 based NIC Broadcom 570x 10/100 Integrated controller Broadcom NetXtreme Gigabit Ethernet 5782 Broadcom NetXtreme Gigabit Ethernet PCI-Express NetXtreme(tm) 10/100/1000 Gb NIC
Supported Operating Systems: Microsoft Windows 2000 Microsoft Windows 98 Microsoft Windows NT 4.0 Microsoft Windows Vista Business 32 Edition Microsoft Windows Vista Business 64 Edition Microsoft Windows Vista Enterprise 32 Edition Microsoft Windows Vista Enterprise 64 Edition Microsoft Windows Vista Home Basic 32 Edition Microsoft Windows Vista Home Basic 64 Edition Microsoft Windows Vista Home Premium 32 Edition Microsoft Windows Vista Home Premium 64 Edition Microsoft Windows Vista Starter 32 Edition Microsoft Windows Vista Ultimate 32 Edition Microsoft Windows Vista Ultimate 64 Edition Microsoft Windows XP Home Edition Microsoft Windows XP Professional Microsoft Windows XP Professional x64 EditionINSTALLATION INSTRUCTIONS: 1. Download the file by clicking the "Download" or "Obtain Software" button and saving the file to a folder on your hard drive (make a note of the folder where the downloaded file is saved). 2. Double-click the downloaded file and follow the on-screen instructions.LINK where file can be downloaded:HP/Compaq Support-Broadcom Driver download
Again, I hope this information is what you neededto install your network device. Should this not answer your question, please come back, provide more details of your problem, and we will be happy to help!Best of luck to you!
Jun 23, 2010 | HP Compaq d530 Ultra Slim PC Desktop
I have a problem with my PC: When I try to turn off the windows XP home edition SP3 the pc don't stop he restart, but i think the HDD C: where windows is install stop and then restart all sistem (like in...
It Seems Some System Files are Corrupted or Deleted By Antivirus Application in the Process of Removing Virus from your System ....
Method 1:
1. Put your Windows XP CD in your CD-Drive
2. Open RUN Dialogue Box From Start Menu
3. Type "SFC /SCANNOW" -- Copy and Paste the Command exactly
With out Quotes
4. Wait Until It Completes everything...
5.Restart and Check your Problem ....
Method 2:
1.Login to your Windows XP
2. Put your Windows XP Home CD in your CD-Drive
3. Click Install Windows XP From Autorun Window.Start Windows XP Autorun Screen if its not opened, by Clicking on the Windows XP CD Drive icon under your My Computer ...
4.Select Same Drive as your Windows XP Now Installed then Select Upgrade Method to Install...
5.Complete Installation and Restart your System ...
Note: in Upgrade You'll never lost your Installed Programs and Files ...
Feb 20, 2010 | Microsoft Windows XP Home Edition
Tsbyuv.dll is missing in windows xp home edition
http://www.fix-all-dll-errors.com/tsbyuv.dll/
You can get find it here..follow the link. :)
Oct 30, 2009 | Microsoft Windows Xp Home Edition Sp2...
My daughter (aged 12) has loaded a copy of Vista (which were discs from a computer her grandmother no longer owns and has been scrapped) onto her laptop which had Windows XP installed. She does not have a...
Hi.
If she did not format the hard disk, then the Windows XP startup option will be present in boot option. When computer startup you will get a choice like this:
1 Microsoft Windows Vista Home Edition.
2 Microsoft Windows XP Professional SP2
In that case you can restore XP, starting on XP and editing the file winboot.ini, that is an hidden system file located on C:/ drive.
See:How to edit the Boot.ini file in Windows XP.
If instead Windows XP does not start, or if you do not get the boot option, that means that Windows XP system file had been deleted.
In that case the only way to get back Windows XP is reinstalling the system from scrap, using a Windows XP install disk, and the number listed on the licence sticker.
Regards.
Oct 23, 2009 | Microsoft Windows XP Home Edition
Windows XP Home Edition - No Drivers.
vswright is right, you have to make a restore disk when you are happy that that system is running properly (this called system back up and restore) go to the HP support website (HP now own Compaq)
and enter the make and model of the pc and download the device drivers you need, if you experience any problems, get back to us
regards
Nov 22, 2008 | Computers & Internet
Msls31.dll file missing
OK,
U can Find & Download This DLL File form Following Web Link......
http://www.dlldump.com/dllfiles/M/msls31.dll
After Download this file follow the blow steps-
1- Copy & Paste this File in "C:\windows\system32"
2- On Desktop Click on "Start" & Click on "Run"
3- When Run window appear, type the following command
       regsvr32 msls31.dll
NOTE: Give a Space Between regsver32 & msls31.dll
4- After type the command hit ok, a popou window appear again hit ok
That Done Now Ur EZ Soft should Run Properly....
If after this any problem persist, send me the error (as given by window). I will happy to help U.
Tip:- U Use XP Home Edition, It is Good But I Suggest U that U should Use XP Professional SP2 Edition it is Better & Having more Softwere Competibility.
Nov 08, 2008 | Microsoft Windows XP Home Edition
Slow in opening file or program
what model computer do you have?
cpu
ram
hd
do you need avg and mcafee? they might conflict
Nov 13, 2007 | Microsoft Windows XP Home Edition
35 people viewed this question
k24674
jasbo
jasbo
