Question about Coleman Camping, Backpacking & Hiking
Where can I purchase replacement batteries for Coleman Rechargeable Flashlight, Model 53870701?
4 Suggested Answers
  • 75 Answers
SOURCE: How to replace witch assembly in rechargeable Maglite?
1st, remove the battery via the **** end of the barrel.
2nd, carefully remove the little RUBBER CUP that covers the depression off/on switch. Gently maneuver it out by lifting the edge of it then pulling it out. Do not cut or puncture it. This little rubber cup keeps water and dirt out of the switch.
3rd, Remove the HEAD (light assembly) off where the charging rings are, just behind the switch. Hold the barrel with one hand and with the other twist the head until it begins to unscrew from the barrel and until it is free. Upon completion of this step, set the barrel aside. If you have a digital camera you can photograph each step of this so that when you reassemble, you can simply refer to the photos for reverse order assembly.
4th, Unscrew the LENS CAP and set it aside. At first it may seem as if it is not unscrewing but keep going as it will come off. Upon completion, set the lens cap aside.
5th, Hold the BULB with a tissue and pull straight out with out twisting. Do not hold these types of bulbs with your bare hands as the moisture and oils of your skin can damage the bulb when the switch is turned on. Upon completion secure the bulb and set it aside.
6th, You will now be left holding the BEAM ADJUSTMENT HEAD which also contains the OFF/ON SWITCH.
7th, Firmly hold the ADJUSTMENT HEAD (the large portion) in one hand, then place the small end in the palm of your other hand and push the small portion through and out of the large portion. Set the head aside. You will now be holding the short barrel which contains the bulb holder and the OFF/ON SWITCH.
8th, Now look at the OFF/ON SWITCH. You will see a white plastic cylinder looking up at you. When you push it down you will hear and feel it 'click as it is engaged in the 'on' position. This and the assembly it is contained with-in must now be removed from the short barrel containing it.
*CAUTION* When you finally ( In step #9 below) remove the SWITCH from the short barrel, the assembly containing the switch itself will want to 'spring' apart into two halves because it is under slight pressure due to the spring which puts tention on the OFF/ON button. Hold it firmly until you have it completly removed from the short barrel. Pay attention as you do this so that you can remember how to put it back together at reassembly time.
9th, Using a small common tip screw driver, depress the WHITE plastic OFF/ON button as far down as it will go. While you are holding it down with the screwdirver use the thumb of your other hand and push against the BULB HOLDER, this will cause the SWITCH assembly to move forward about 1/4inch and to the point where you can release pressure on the switch with the screwdriver. At this point DO NOT continue pushing.
10th, look down into the barrel where the white plastic switch is that you had depressed in step # 9. You will see a BLACK plastic housing which holds the WHITE OFF/ON SWITCH. Using your small blade screwdriver, slide it behind the BLACK plastic housing and gently apply a prying pressure which will force that housing containing the SWITCH assembly, to move forward and exit the short barrel containing all of this. REMEMBER! It is at THIS point that the two-part housing holding the switch assembly will want to 'spring' apart. Pay attention and go slowly. When you reassemble this part of the flashlight, know that in order for the switch assembly to go back into the short barrel the WHITE PLASTIC OFF/ON button has to be DEPRESSED, do it with the screwdriver, enough to clear the interior side of the barrel. Depress it and gently push the assembly back into the barrel until it is back where it began. Be sure to line up the male notch on the exterior of the switch housing with the female grove of the interior of the small barrel. If you have the notch lined up and the switch button depressed all the way it will slip right into place with a happy clicking sound.
Upon completion of that step, reassemble the rest of the components in reverse order.
There you have it. Good luck. :)
Posted on Apr 24, 2009
CarlGlas
  • 283 Answers
SOURCE: ® XRF Xenon Rechargeable Flashlight: Where can we find the batteries for Xenon Cyclops ...
I am not familiar with that particular model flashlight. Most of the Cuclops flashlights use the 3.0 Volt CR123 Battery. However, here is the URL for Cyclops Solutions website. www.cyclopssolutions.com/index.html
Posted on Jul 07, 2010
dcramer531
  • 1654 Answers
SOURCE: How do you change the batteries on a Coleman
All The info I can find nothing tells us how to change the batteries. Is this a rechargable light, if so the batteries are not available for replacement. If not then the top has to screw off, or the bottom plate must screw off, there isn't any other way. What I have read is that these on this light are very hard to remove, at least that is what folks are complaining about. this light has also been discontinued and no longer availabe. if your afraid of breaking the light then I would contact Coleman for their advice since there seems to be none to be found on any bulletins they have put out.
Posted on Apr 28, 2011
Replace batteries on flashlight
Maureen, Coleman Graphite Flashlight replace batteries. Remove bottom cap, it will be on tight, if you do not have good strength in your hands use a pair of pliers or channel locks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change the batteries in Mag Lite
Aug 26, 2016 | Coleman Graphite Flashlight
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
How do you open a Coleman flashlight
You need to specify the model of the flashlight. However, for most of them you simply unscrew the bulb head or the battery end cap, empty the old batteries and insert the new ones with the positive end of the batteries always pointing toward the bulb end and the negative end of the batteries toward the spring in the end cap.. Be sure to discard the batteries properly. Contact your local trash disposal company to determine where and how to dispose of them.
Jan 02, 2015 | Camping, Backpacking & Hiking
How can I fix my rechargeable portable spotlight/flashlight after no charge for 1(one) year?
I replaced the battery in mine(coleman powermate) for 10 bucks but you have to be careful in how you disassemble it and put it back together. Batteries sulfate after awhile like a car battery.
Dec 12, 2014 | Vector Camping, Backpacking & Hiking
How do you open the Sylvania model no 72032 rechargeable flashlight to replace the battery and light bube?? Thanks
This is from the Sylvania site
  • Dimensions: 2.4" long x 1.7" diameter
  • Light Source: 0.4 watt non-replaceable LED
  • Internal Battery: Sealed Ni-MH 3.6V 110mAH rechargeable battery
This look like it is not replaceable - amazon sells them fairly cheaply
Oct 04, 2014 | Camping, Backpacking & Hiking
How do I remove the battery?
This is not intended to be a user replaceable battery, although I have found a replacement battery on-line.so that means that SOME people have replaced them. the cost is $9 +s&h. I don't think most camping outfitters would be able to help you with it, But it would be worth a try.
My suggestion would be (if you have one in your area) take it to a Batteries Plus store. They are quite good at replacing batteries that are NOT meant for user replacement.
Best of luck to you.
May 12, 2014 | Coleman Camping, Backpacking & Hiking
Battery and charger
You can get aftermarket 18V rechargeable batteries that may interchange with your Coleman battery and may even use the same 18V charger
May 11, 2013 | Coleman Cable Coleman 18 Volt Combo Drill...
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
May 15, 2010 | Cyclops ® XRF Xenon Rechargeable...
The coleman rechargable blender not blending
Subject: Rechargeable Portable Blender Model No. 850-870
I was given one of these blenders for Christmas. I charged it through 3
cycles, used it once and the battery was dead. Charged it through another 5
charge cycles and used it once only to then have another dead battery. I
have put it through at least another 8 charge cycles, and it indicates a
DEAD battery. I have managed to blend two (2) 3/4 full pitchers in total. On
trying to start it now the green light 'flickers' quickly on and shuts down.
This is a totally useless device.
I would like to return it for a full refund, including shipping.
Dec 21, 2009 | Coleman 850-870 Single-Speed Blender
Camping, Backpacking & Hiking Logo
174 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
yobo007
yobo007
Ted Maxwell
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
