Question about GE (PSS26MSRSS) Side by Side Refrigerator
Change the thermostat...
How do I change the thermostat (temprature control)? I can do it if I know where it is-- I have the part.
  • GE Master
  • 8,220 Answers
DIRECTIONS
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 07, 2010
Testimonial: "I found it on my own, but thanks for the giude--it will be helpfuf in the future!"
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
1987 ltd crown victoria in alaska. Did oil change and added coolant at an autoshop, caused the heat to come back on. 1 week in -20 degree wheater later car starts after waitin 10 min+. Engine would do 1...
did you use normal coolant or a glycerol based anti freeze, this prevents your coolant from freezing in sub zero temperatures, the other big thing is the viscosity of the oil, that means how thick the oil is at different tempratures, colder ambient temprature lower the number, etc.
Dec 03, 2013 | Cars & Trucks
How water temprature not going above 55.
Unknown what product you have.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Add a comment and describe product in detail
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 07, 2013 | Water Heaters
I have model gx5fhdxvq the tempratur in frezzing area fronm -16to -24 i cnt change more
hi.cant understand your problem .going to assume u mean u cant change the temperature or choose.sounds like control panel pcb board faulty.good luck Ali
Jun 27, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Honeywell Thermostat won't stay at the temp that I set it at!
You are likely running a schedule. When you go to tstat and change the temp it is a temporary setting that will expire in a given amount of time. 1, 2 3 hours etc. "HOLD" can sometimes bypass the schedule, "RUN" returns to the schedule. Not sure what model tstat you have but you have to exit your schedule.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 18, 2017 | Honeywell Heating & Cooling
I can not set the temprature differantial of my honeywell beutler thermostas
well back when i worked on honeywell controllers, you don't set differentials on thermostat you set the temperature and it has its own differentials like + or - 1 or 2 degrees to the set temperature they don't let you play with this setting, you set your temperature and it will maintain around that temperature you shouldn't need to change the differentials around that temperature as controller does what the heater needs to get to the temperature you require setting the differential closer to set temperature will make the unit cycle a lot more and coast you more and having it to far away can let the conditioned area start to get back out of comfortable range so they set these in factory and you shouldn't be able to change them as they are set to how it should work to wrok properly so i wouldn't change them even if you could!
Nov 25, 2010 | Honeywell Programmable Thermostat Heater
Nissan path 95, boiling near to over heating
It certainly can cause the condition, but so can TONS of other items: coolant level, bubbles in the coolant (air bleeds), reaiator restrictions.
You could test the thermostat, pull it and put into measured temprature water and observe it as you raise the temprature...
May 30, 2010 | 1995 Nissan Pathfinder
Can not alter temprature from fixed setting
to decrease or increase temp we use a button or switch and this switches reach order for control board as a general basis so if the tow functions - & + faulty together then i think it is the control board need to change
Jul 09, 2009 | Neff B4540 Stainless Steel Electric Single...
Where is the coolent temprature sensor situated and are they hard to change
Located usually on the intake manifold, or block. Depends on the maqke and model of the vehicle. Some are located in the thermostat housings as well.
Mar 26, 2009 | 2000 Volkswagen Golf
GE (PSS26MSRSS) Side by Side Refrigerator Logo
96 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
