Question about Teac AG-V8060 Receiver
Fan is not getting power - Teac AG-V8060 Receiver
  • 506 Answers
More than likely the fan is controlled by a comparator circuit. This circuit uses a thermistor to sense the temperature of the amps heatsink. The thermistor changes in resistance over temperature. When the voltage divider on the comparator reference is met the fan will kick on.
If for some reason the fan is used as an all the time function then I would say there is a bad 5 or 12 volt regulator that supplies the fan with power.
Posted on Feb 11, 2010
Have a dell tower and want to know how to fix the fan
buy a replacement power supply fan
or
buy a replacement power supply - dearer option but power supply may be faulty if fan is not running and you fix two problems however be careful with AC input voltage that it matched the power point voltage. or smoke and broken power supply ! take old power supply to computer shop to ensure correct power supply is purchased.
or
if it is the cpu fan
buy a replacement cpu fan and thermal paste.
Possible cheaper options if fan choked full of dust
get a can of compressed air and blow the dust out of the power supply and cpu fans outside your dwelling not inside your your office/ home.
Power supply fan may need a drop of machine oil if noisy or its bearings are worn out..
Oct 26, 2016 | Dell Computers & Internet
My radiator cooling fans have no power and the 40 amp fan fuse is good, what's wrong?
There are many things that can cause your radiator fans to not get power. However, the most common cause is the fan control module. Some people call it a "fan control relay", (including many aftermarket parts retailers) but it is actually a solid state control module, not a relay.
Check for power in and out of the module. It is best if you have access to a scan tool that has system test capabilities so you can command the fans to turn on with the computer. Otherwise, you will have to get your engine really hot and see if the power is being sent from the control module to the fan motors.
The fan control module is located on the inside of the left frame rail (driver's side) just behind the radiator. You will have to get under the vehicle to see it. It looks like the picture below.
May 04, 2012 | 1998 Chrysler Town & Country
Heater fan does not turn on
check for power to heater fan. run a wire from battery to fan, then use a piece of wire to ground it. if the fan works but will not work from switch, check the fan resistor, if ok. make sure you are getting power to fan motor. use a 12 volt test light to check for power at the fan motorwith fan selecter on.. good-day !
Sep 28, 2011 | 1997 Jeep Grand Cherokee
On startup my fan on my dx2200 run very loudly
Which of the fan? Is it Power fan or processor cooling fan?
POWER FAN: check if the casing of the power pack is touching the fan or wire if not then prepare to change power pack or the fan.
Processor Cooling Fan: If there is no wire in the system touching the fan then know that the ball bearings are getting bad. Then plan for replacement.
Oct 13, 2010 | HP Compaq dx2200 PC Desktop
The cooling fan does not spin.
If that is the only thing that isn't working then the fan itself might just need to be replaced, if you take the make and model of the pc to any computer repair shop they should be able to get you a replacement fan for not much of a cost. They are really easy to change too,fyi.
Apr 07, 2010 | Toshiba (K000016310) Cooling Fan
Lot of noise from the fan
no need to replace the power supply just open the power supply and replace the fan if not possible then insert some oil drops in the fan sound will definetly end
Feb 26, 2010 | Dell (C3760) 305-Watt Power Supply
Processor fan wont work.
Hi tenfive64,
Try another fan in the cpu power slot, to see if there is no power getting to that source. If the fan turns on, well! Something ain't right with the fan. If it doen't then you'll need a power extension connector to reach for another fan power source on the board. DON'T hook it up to a non-fan power source, you will fry the fan, if not the board.
Good Luck,
Mark
Dec 16, 2009 | Compaq Computers & Internet
My fan is not turning
Could be a fuse, relay, sensor or the fan..
Check fuses - if all good - then With a tester - verify if the fan is getting power..
If it is getting power - I would replace the fan..
If NOT getting power - check the other components mentioned..
Hope this helps !!
Positive feedback please ;o)
Jul 12, 2009 | 1998 Chevrolet Malibu
When is the Hipro HP-A2007AE power supply cooling fan to be on?
The fan should run constantly. It needs to be replaced. Otherwise the power supply will shut down when it gets hot. It can usually be replaced, but if the supply is cheap, just go out and get a new one.
Mar 17, 2009 | Computers & Internet
Fan
Hi replace the fan by opening the power supply with a new fan if your power supply is under warranty period still get it exchanged.
May 19, 2008 | Okia 250w UL Approved ATX Computer Power...
Teac AG-V8060 Receiver Logo
207 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
