Question about Sanyo VPC-E760 Digital Camera
Camera doesn't come on, charged battery and still nothing,
  • marcoacosta4 Feb 21, 2010
    my camera doesn't come on,,charged battery and still nothing
Insert battery properly.
Posted on Feb 08, 2010
I have a Samsung TL100 camera and it will not take a charge
If you haven't used it for the last 8 months and before it was all fine then the most common reason would be the battery. Your battery is absolutely dead but then again if you plug it to AC then it must show some sign of life. But give it a go by replacing new battery. To check get it from a friend and then test the camera on it.
If the battery replacement doesn't work then take it to an authorized dealer for inspection.
Oct 30, 2012 | Samsung TL100 Digital Camera
Alright so i wanted to know if i can charge my Casio Exilim Zoom EX-Z700 Digital Camera without the actual charger but just plug it into my computer and it'll charger that way. i've tried this...
No. You need to plug the camera into the cradle and plug the cradle into a wall outlet. Connecting the camera to the computer merely drains the battery faster, as the camera has to spend juice communicating (or trying to communicate) with the computer, even if only to say it has nothing to say.
Aug 23, 2011 | Casio Exilim Zoom EX-Z700 Digital Camera
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
My camera has been plugged into the computer for 24 hours now and the battery still isn't charged. How long does it take to charge and how will i know when it is done charging? i have a Vivicam X029
The manual merely says "a few hours." The LED on the back of the camera lights up while charging and goes off when finished. Not all computer USB ports put out enough current to charge batteries. If you're using a hub, bypass it and connect the camera directly to the port. If that doesn't do it, try another port if available. If that doesn't do it, use the supplied AC adapter and plug it into a wall outlet.
Aug 05, 2011 | Vivitar Cameras
My camera wont charge, when i plug in the camera the green light will blink several time and then disapear
It's probably a worn out battery. The batteries are good for 150-300 charges. Every connect is a charge. Doesn't take long.
Jun 18, 2011 | Nikon Coolpix S4000 Digital Camera
Recharging battery camera-computer
The camera doesn't charge batteries. Connecting the camera to a computer merely drains the batteries faster, as it must expend juice to communicate with the computer (even if only to say it has nothing to say). You need to use the supplied battery charger or a compatible.
Apr 21, 2011 | Panasonic Lumix DMC-FX01 Digital Camera
I am on a working trip. My camera will not charge from the USB port. I do not have the charger with me.
The D10 doesn't charge the battery through the USB port. Connecting the camera actually drains the battery faster, since it has to communicate with the computer (even if it's only to say it has nothing to say).
A well-stocked camera store should have a battery and/or charger. Another possible source is a battery store, such as http://www.batteriesplus.com
Apr 15, 2011 | Canon PowerShot D10 Digital Camera
My M753 doesn't seem to want to turn on. I have charged it,nothing. Any idea's what can be wrong.
Try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak Easyshare M753 Digital Camera
Sanyo VPC-E760 Digital Camera Logo
63 people viewed this question
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
