Question about Amana ACS3350 Gas Kitchen Range
Oven not heating up. range functioning, buttons functioning, oven not functioning.
    Sergeant:
    Champion:
  • 263 Answers
Kenmore electric range model 790 oven stopped functioning, both broiler and bake. however, oven light still comes on.
I believe there is a thermal fuse (also called a TCO or Thermal Cut-Out) located either on the back of the oven, or between the top of the oven and the cooktop that has opened up. Did this happen after running a self-clean cycle?
Sep 09, 2014 | Kenmore Kitchen Ranges
Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 07, 2010 | Frigidaire FEF355 Electric Kitchen Range
I have a maytag MER6772 Gemini Electric Rage it gave the F1-2 code. What must I do to Fix This Problem?
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Jan 16, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Oven takes too long to heat up on Jenn Air gas oven
you need to look at the oven igniter to see what color it is. if it is orange it needs to be replaced. it should glow white hot in order to ignite. hope this helps.
Oct 13, 2009 | KitchenAid KGST307 Gas Kitchen Range
Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Aug 11, 2009 | Kitchen Ranges
Oven showing f7 on lower oven
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning . F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control. you can get the required parts at www.repairclinic.com thanks.
Jul 11, 2009 | GE Profile JB968 Electric Kitchen Range
Double GE wall oven - F7 code
from repairclinic.com:
Apr 27, 2009 | GE Ovens
Kenmore range
If this range has electric elements in the oven, you may have blown one of the heating elements. Do any of the oven functions work? If you were attempting to BAKE when this occurred, have you attempted to turn on the BROILER to see if it works? If the BROILER still heats up, you may just have a bad heating element. If both features quit working, the problem may be with your Electronic Range Control (ERC) board. Post back with comments and let me know.
Feb 18, 2008 | Kitchen Ranges
Oven not heating after self-cleaning cycle.
That did it for me too. You saved me a $200 service call!
Nov 05, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Oven Heat
THE OVEN SWITCH IS BAD ITS STAYING CLOSED.FAIRLY EASY TO REPLACE AND NOT THAT EXPENSIVE.ANY APPLIANCE STORE CAN ORDER THE PART OR YOU CAN FIND IT ONLINE.
Aug 28, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Amana ACS3350 Gas Kitchen Range Logo
198 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
