Question about Gateway FPD1976W LCD Monitor
I have a Gateway Monitor service no. FPD1976w. It blacks out after 2 seconds, the backlight goes off. The power light remains solid blue. By switching inputs it will come back on momentarily, but for 2 seconds, then blacks out.
  • Steve Lacey
    Steve Lacey Feb 07, 2010
    I doubt if it is the computer. I have it connected to two different computers. One connected to the VGA input and the other one connected to the DVI input. Both computers work when connected to other monitors. This problem manifests itself the same no matter which input it is connected to. Could you recommend where I could get a service manual for this monitor? I am an electronics tech. I used to work on monitors, TVs, VCRs, etc.
  • Steve Lacey
    somewhat
    President:
  • 2,923 Answers
Try connecting the monitor into a known working computer to see if it's a monitor or video card problem.
If the problem is isolated with the monitor, then I could say that the power supply board inside the monitor could have gone bad.
Good luck and have a great day!
Posted on Feb 07, 2010
Black screen blue light blinking
LCD backlight is faulty. Need repair.
Oct 25, 2013 | Gateway HD1900 19" Monitor
My FPD1976W Gateway monitor will display for only 2-3 seconds then go black. I can turn monitor off then back on it will display for 2-3 seconds then again go black. Start button is not blinking. Does this...
You've got it, one of the circuit boards has one or more failed capacitors.
If you decide to take it apart, check for capacitors with either a bulging top or a yellow stain underneath on the board itself.
Befored taking it apart, because you will, even if just slighty, damage the screen case, check your warranties. I had one pop recently, it had a 3 year - return to base warrany.
Jul 13, 2011 | Gateway FPD1976W LCD Monitor
I have a gateway FDP2275W desktop monitor. the monitor will power up and display the Gateway logo in the middle of the screen, then goes black. The monitor is still getting a signal from the computer as...
This is a common problem with many LCD monitors. The
printed circuit board that provides a stable voltage for the monitor to operate
from starts to fail. The PCB can be replaced, when/if they are available, or repaired
in most cases at a much lower cost. for more information on this email me at
Sprint6@zoominternet.net
Dec 26, 2010 | Gateway FPD2275W LCD Monitor
Gateway Monitor FPD2485W
posibly a burnt out CCFL light , more likely an overloaded or burnt out CCFL power supply
JOAT
Oct 16, 2009 | Computers & Internet
Gateway 22 inch LCD monitor suddenly goes black...blue on light works but pic only stays on for 3 secs when computer is turned on.
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | Gateway FPD2275W LCD Monitor
Black screen after a couple of seconds
The monitor needs to be replaced. I had an LG LCD that did this luckily it was still under warranty. Contact the maker and have your receipt handy. Otherwise buy a new monitor. Monitors tend to be replacement only
Apr 11, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Black screen with high pitch squeel
Hi...there,
YEah...sure! You need to replaced or repaired your backlight inverter....
Oct 11, 2008 | Gateway FPD2275W LCD Monitor
Gateway fpd1760 monitor loses picture after 2 seconds...
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
May 11, 2008 | Gateway FPD1760 17" LCD Monitor
RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Sep 21, 2007 | Acer AL2017 20" LCD Monitor
Gateway FPD1976W LCD Monitor Logo
200 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
