Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Zoom not working - Canon PowerShot SD500 / IXUS 700 Digital Camera
The zoom lever is not working moves but doesnt change
If the zoom lever is not working then I would recommend buying a new pair without a zooming mechanism. Zoom binoculars are more trouble than they are worth. Sorry!
Feb 20, 2010 | Minolta Classic II Binocular
Flash zoom function not working
have you checked that the diffuser is pushed fully home in its slot until you hear a click - this diffuser is for close-up work only and dissables the zoom flash
Feb 02, 2010 | Nikon Speedlight SB-800 TTL Flash
Setting the ''digital Zoom''
The digital zoom works fine on mine. It sounds like your have encountered a couple of defective models.
However, even once you get the digital zoom to work, it gets really grainy, so I don't use it.
Nov 30, 2008 | Video Cameras
Canon Speedlite 430EX zoom issue
You're gonna kick yourself, but here goes, you know that clear plastic wide beam shield on the front, make sure it's fully inserted or else the auto zoom won't work while it's in use, (or the flash thinks it's in use)
Aug 07, 2008 | Canon Speedlite 430EX TTL Flash
Sony DSC-P3 Zoom stopped working
i had that same problem. check your image size, the camera cant zoom if the image size is set to 3.1M or 2.8M(3:2)
how to change image size:
turn on camera and leave it in camera mode (picture taking mode)
press the delete/image button
change image size until camera zooms again
VGA gives the biggest zoom range
i hope this helps
it worked on my camera
Jul 27, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Camera Zoom Feature
Awesome ! ! ! That works ! ! ! ... Turning off, removing battery for 30 secs., putting it back on, and reboot. Thanks ! ! !
Jul 03, 2008 | RIM BlackBerry Curve 8310 Smartphone
Digital Zoom Stopped Working
first of all why do you want to use digital zoom? it distorts your pictures! but if you insist, check the settings because it is possible to turn digital zoom off
Dec 25, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My zoom is broken
Hello, there is no way to bypass the zoom or to manually work the zoom. Please contact me at LIVE Expert Assistance. Best regards, Arpi
Jul 09, 2007 | Sony Handycam CCDTRV118 Camcorder
Digital zoom not working
Digital zoom is in the menu and must be turned on to activate it. When you use the zoom it takes 2 opperations to function. First opperation is to zoom all the way in then the camera should stop. This is the limit of the optical zoom. Then you let off the zoom button, and hit it again and then the digital zoom will start. Digital zoom is just a gimic if you learn how it works its not doing anything different then you can do in photoshop. All digital zoom is doing is like cropping.
Apr 24, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
