Question about Mitsubishi WD-52528 52" Television
TV will not come on. I pull out the power plug
Mitsubishi Model WD-52528. TV will not come on. I pull out the power plug and when I plug back in the green light (timer light) blinks rapidly for about a minute and goes off. About a minute later it repeats same thing over and over as long as TV remains plugged in but it never allows me to turn on the TV. I've tried the reset button many times still will not come on. Trouble started when I replaced the projection lamp.
  • 1 more comment
  • cspaul1234 Feb 07, 2010
    Could I have "blown" this power source by doing something wrong when replacing the lamp? It seemed like a very easy procedure. When I put in the replacement I may not have pushed in far enough to make the power connection so I put the old one back in and the screen came back on as before but the TV had lost all of initial settings. I just made a few random slections on the menu because I didn't want to take the time for the detailed setup. It was after that that I could never get the TV back on even with the old lamp. Did I do something that could have effected the way the TV "boots up" as with a computer programmed to read the hard drive first?
    Cannot get to the service menu because the power will not come on.
    Tried resetting the TV with your suggestion about holding in the power button for 5 seconds and plugging back in after a half hour. Same results..power will not come on. I've tried another bulb. No good. I guess I'll have to call the service man to get his assesment. You mentioned the possiblity of blowing a fuse..so there is a fuse inside?? Would it be worth me trying to remove case to try to change it?
  • cspaul1234 Feb 08, 2010
    Sounds like you've covered the most likely problems.
  • 11,896 Answers
Your power supply aka high-voltage transformer is shot. Very Very common in mitsubishi tv's. They seem to have the most problems.
You can possibly order one from tigerdirect.com or partstore.com or shopjimmy.com
It will have to be difused with a difuser to draw out any remaining power left in the supply/transformer, then it will have to be soldered off and the new soldered on.
It is common because parts are made cheaper and quicker now days. Have had to replace many of these lately.
Posted on Feb 07, 2010
  • Nate Stansfield
    Nate Stansfield Feb 07, 2010
    The tv's don't have any hard drives or anything like that. No optional bootup options. The bulb may not have been full inserted and could have burnt out the ballast or blown a fuse. I recommend replacing the bulb with new bulb. Then reset the lamp counter hours:
    This all probably comes a couple years too late, but when you
    install a new lamp, you’ll want to reset the hours on the counter your
    television has. Doing this will allow you to avoid getting any
    messages about the lamp needing to be replaced despite you having a new
    lamp inside your set.
    If you need to get into the service menu, you can do so by following these directions:
    With power on, hold down VOL minus button on projection display and
    hold down the PIP or SPLIT button (try both) on the remote
    simultaneously for more than 5 seconds.
    This should set the lamp hours counter to 0:00
    If you need to reset the tv, unplug the tv and and when it is unplugged, you MUST press and hold power button for 5 full seconds to drain out any remaining power, then wait half hour and plug back in.
  • Nate Stansfield
    Yes I would remove the rear panel. If you do have a fuse in this model, it would be next to the power supply/high-voltage transformer (the box that the power cord attaches to) this supply/transformer VERY commonly goes bad in todays newer electronics.
Timer light keeps blinking
you probably had a power bump, unplug tv for 1 hour turn back on and hit the reset button, if the green light quits blinking your good to go. If not you might have capacitors gone bad not cool.
Apr 03, 2010 | Mitsubishi WD-52528 52" Television
4 year old Mitsubishi wd 52528 has had flashing timer light then turns itself off since power outage. After turns itself off, can't get it back on, even with reset.
Need to unplug for computer to power down then plug back in, light will blink for a few then go out and you should be able to power on!
Feb 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Tv does not turn on. Timer light blinks
Have you tried to hold the menu and input/device buttons on the front panel in together for 5 seconds to see if it will blink a two digit error code? Try that then let me know the code that the led blinked
Aug 05, 2008 | Mitsubishi WD-52528 52" Television
Blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
First check error codes to do this search threads or goto ctechnicians.com
Dec 31, 2007 | Mitsubishi WD-52528 52" Television
Mitsubishi WD 52528 tv
I had the same problem last year - it was, indeed the bulb. At the time the tv was still under warranty and Mitsubishi sent me a replacement bulb.
Dec 27, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WD-52528 52" Television Logo
121 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
