Question about Car Audio & Video
Have a 1991 Gmc Jimmy trying to find a adapter 4 the radio harness that comes out of truck and the harness that comes out of the radio
  • odonnell_law Feb 07, 2010
    its a radio not a video i tried autozone no luck
  • 102 Answers
Hi you can buy them at an auto parts store like Autozone. Or on Ebay.. Thank you for using Fixya.com
Posted on Feb 07, 2010
  • michael whitman Feb 07, 2010
    Hi your looking for the plug in adapter for your factory sterio wire harness to hook up a after market sterio in your gmc jimmy so you dont have to cut your factory wires correct? it can be purchased at most auto parts stores or it is on ebay just type >
    Car Radio Wire Harness Stereo Wires GMC 1988-2005and it will come right up its $6.99 with free shipping.. Thank you for using Fixya.com....
I have a 1995 gmc jimmy stereo sound doesnt work
Are you sure you are listening to a stereo program (e.g. FM radio or CD/Tape)? Have you tried adjusting the fade and balance controls? If sound is not coming out of all speakers, you will probably have to replace the radio.
Feb 23, 2015 | 1995 GMC Jimmy
How to adjust carburetor in 1991 GMC Jimmy. Poor gas mileage and seem to be running rich.
its fuel injected try some injector cleaner lucas worked real good for me
Feb 06, 2015 | 1991 GMC S-15 Jimmy
Cant find the hook up to plug in the adapter for my trailer lights on my 1995 gmc jimmy
Hi Stoker, I'm not very sure what it is you can't do. Are you looking for the connector for your trailer? If so and you can't find it, maybe you need to install one? It's not such a tough job but it will take time, a voltage test meter and a few other tools. Uncover the electrical harness with the cables for the rear light units. Identify each circuit and the pins on the trailer for those lights and connect into those circuits and making sure you match the pins. Test the connections, not forgetting to attach the earth cable. Regards John
Jul 03, 2012 | 1995 GMC Jimmy
I changed my turn signal switch and now my rear speakers do not work how can i fix this or does the harness for the turn signal switch hook up with the stereo harness?
No the turn signal is seperate from the stereo,what happen is that accessing the turn signal wire the power to the radio was interrupted, the solution did you blow a fuse?Can you push the radio and rear speaker come alive it just something that got interfered with the speaker wire cannot connect to a constant power as a turn signal but must be from radio controls and radio out let only
Apr 23, 2011 | 1997 GMC Jimmy
Where is the fuel pump relay for a 1991 gmc jimmy?
  • COMPONENT LOCATIONS RESULTS
Relay - Fuel Pump 1991 GMC Truck S15 Jimmy 2WD 4.3L TBI 6cyl The Relay - Fuel Pump Under hood, driver side, upper firewall, mounted in relay block
Jul 02, 2009 | 1991 GMC S-15 Jimmy
Washer pump for winshield doesn't work
This should just push into a grommet in the washer fluid reservoir. I hope this helps!
Jan 30, 2009 | 1991 GMC S-15 Jimmy
Fuel pump not pumping
You can Hear fuel running? Where in the tank? If so then it sounds like the fuel pump dettached from the supply line inside the tank.
Jan 11, 2009 | 1991 GMC S-15 Jimmy
REAL HOT EXHAUST
Sounds like the catilitic converter is plugged.
Jan 09, 2009 | 1991 GMC S-15 Jimmy
FUEL PUMP NOT WORKING 1991 GMC JIMMY
check the relay, then check the wire harness. and last check the fuel pump it self and that's in the fuel tank. but first check the fuse before you really get you haveds durty.
Good Luck
Jul 25, 2008 | GMC Jimmy Cars & Trucks
WIRING HARNESS FOR 2001 GMC JIMMY
You should have a wiring harness already there. There will be a plug with 3 female and one male connection. White is ground, Green is right turn, Yellow is left turn and Brown is tail lights. If you are installing a brake controller. You will have to run a 10 or 12 gauge blue color wire.
Jul 05, 2008 | 2001 GMC Jimmy
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
