Question about Sony STR-DE597 Receiver
Can I connect a active subwoofer to my SONY STR-DE597 Powerful 6.1 channel AV Receiver
  • info27310 Feb 07, 2010
    Thanks for your answer. Please take me through it step by step. On my receiver should I plug one cable into my receiver and then the two split cables should go where on my active sub?
    Brigadier General:
  • 8,546 Answers
Yes, it only supports an Active Subwoofer. That's what the Sub Pre-Out is for.
Your sub will take that input, possibly split to two RCA connectors, and its internal amplifier will do the rest. Its own manual will give the specifics.
Posted on Feb 07, 2010
  • David Dunn
    David Dunn Feb 07, 2010
    Yes.
    Specifics depend on the subwoofer. If it has a single RCA input, use one cable, otherwise split the single cable to join to both its inputs.
    If you don't have the manual for your receiver, there's a Quick Start guide available on retrevo.com that shows the connections.
Why is there low humming in the receiver sub channel(only?)
Sounds like a shorted capacitor in the sub out circuit.
May 04, 2015 | RCA Audio Players & Recorders
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up. Thanks.
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
Feb 15, 2015 | Sony STR-DE597 Receiver
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up? Thanks.
The Jensen JS650 does not accept line level input so you need to use the Front B speaker output from your Sony receiver and not the RCA subwoofer output. Even though your subwoofer is active, it does not support line level (RCA) signals.
Just connect the subwoofer as you would a pair of speakers. Once connected, you make sure the front panel speaker switch on the Sony is set to A+B so you get sound from your existing speakers (A) and subwoofer (B).
I hope that works for you.
Sony STR-DH510 Multi-channel AV receiver connected to cambridge soundworks ensemble IV w/ passive subwoofer: no sound from center channel during viewing, or during speaker level test- all other speakers...
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
Aug 03, 2010 | Yamaha DSP-A1 Receiver
Do you have a diagram for connecting components to the STR-DE597 Amp?
here's the link to the manual in pdf form:
http://www.filestube.com/bd599e16dd6d300403ea/go.html
would go over the connections but depends on what you are connecting and there are 7 pages of connections in the manual.
Cheers!
Feb 14, 2010 | Sony STR-DE597 Receiver
My subwoofer and surround speakers don't work. However the main speakers work.
sony... its in stereo mode. hit the movies, music or afd buttons for the receiver
Nov 02, 2009 | Sony STR-DE597 Receiver
I HAVE A SONY RECIEVER SRT-DE597 6.1 CHANNEL AND I ITS ON PROTECTED MODE CAN YOU HELP ME UN PROTECTED
Amp output is damaged and needs repaired. Protect mode cannot be deactivated. When amp is repaired and operating normally protect mode will not be displayed.
Aug 29, 2009 | Sony STR-DE597 Receiver
Programming my DishNet remote for my Sony AV System
Hi, the manual for the vip622 (the model I have... not sure what you have) says to use the following codes for Sony Tuners / Amplifiers.
639 645 650 687 728 729 730
(located in the Appendix)
See Chapter 10 here:
http://www.dishnetwork.com/support/documents/receivers/vip622/default.aspx
for instructions on how to program the AUX setting on your remote and how to set your remote to adjust the receiver volume while controlling the Dish receiver.
Mar 28, 2009 | Sony STR-DE597 Receiver
Sony STR-DE597 6.1 Channels
Repair time ...circuit board to front channel has a fuse prob or capacitor
May 24, 2008 | Sony STR-DE597 Receiver
Spot working
Hi..
It's broken internally..Yup.
Find someone local to look at it. A TV repair shop even.
NOT Sony.
Get an estimate first.
Jan 01, 2008 | Sony STR-DE597 Receiver
Sony STR-DE597 Receiver Logo
272 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
