Question about Welding Tools
I have a henning hansen mig welder and theres no wire feed i got issues and its driving me nuts
Mine had a Bad Feeder motor board.Need alittle attention.Take to someone who works on Electric motors.
Posted on Feb 16, 2010
    Genius:
  • 1,036 Answers
Check the continuity of the torch switch - as this turns the feed motor on.
If this is ok, then check the feed motor is not burned out, and works with a supply directly to it (without wire)
If the motor appears to be running ok, check tension of the drive rollers, and easiest of all - keep your wire dry and fit a new liner. Rusty wire or fouled liner are the biggest cause of feed problems.
Best of luck.
Posted on Feb 07, 2010
Cebora mini mig on trigger no wire feed ,power on?
Cebora mini mig on trigger no wire feed ,power on? - Fixya
www.fixya.com/.../t25810314-cebora_mini_mig_trigger_no_wire_feed
3 hours ago - Question about MIG Welders ... Weld corp mig 100 turn machine on andwire keeps feeding without ... Welder running but wont feed wire etc.
Aug 05, 2015 | Welding Tools
Why wont the wire come through my cosmo gas gasless welder
Most mig welders have reversible feed spools. There is a good chance you have the spool in the .030 wire side. Remove the spool retaining clip and flip the spool to .023 wire for example. I don't know what size wire you are using. Also there is an adjustment for the drive spool. Tighten the tensioner spring thumb screw to increase the feed tension.
Apr 28, 2014 | Welding Tools
Having problems with wire feed of Mig 175 any tips to correct issue please?
Need more info! Slipping not enough tension!
Balling up wire in welder: Pinched liner in gun!
Jerking: Tension of spool too loose!
Here are a couple things to check for!
May 16, 2010 | Welding Tools
Will not arc
Check ground connection at welder along with your ground clamp. Bad connection could be the issue. Also check settings on your welder.
Apr 23, 2010 | Hobart Welders IronMan 210 MIG 500304A...
The gun on my welder is broken and need to fine a new one the wire feedes thru gun to weld it is a cambell hausfeld mig welder
You could try Canadian Tire where you bought it.
If not there, check to see if the gun is replaceable by contacting the manufacturer through their website..
Mar 02, 2010 | Campbell Hausfeld MIG / Flux Core Wire...
Got a Campbell Hausfeld gasless 80amp welder. The
Check the tension on the drive wheel, you also might need a liner, they are fairly inexpensive
Aug 07, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
Wire feed stopped after tack welding on set-up jig
i had the same problem. its probably a bad solder on the wire feed pot. not hard to fix ,but you need a solering iron .BE CAREFULL 1 unplug welder.
2 remove pot and the nut underneath.
3 remove case from welder and remove controll box.
4 run the soldering iron over the joins , then put it all back together, should work fine.
Jul 22, 2009 | Hobart Handler 140 Mig Welder
Wire burning betwen rool and feed drive
When you pull the trigger the entire spool of wire and anything metal that touches it becomes electrically hot. If the tail end of the spool is hanging loose and touches something on or connected to the chassis it will do that, and could have welded the connection so it's solid.
May 13, 2009 | Hobart Handler 140 Mig Welder
Wire does not feed on MIG welder
my lincoln mig welder did the same exact thing!! I thought what you did, drive motor bad. But it wasn't, on mine there is a reset/breaker button, it's like a 25 amp fuse that can be reset, it was bad! so I took the 2 wires that went in and out of it and jumped them together (not advised) to see if it would work then. BINGO!! now I have to find replacement. Look inside for a fuse or some thing like that.
hope this helps, oh yeah, when I ask the mechanic at the welding store he said that drive motors rarely go bad!!
Hawk
Apr 10, 2009 | Welding Tools
Welding Tools Logo
1,587 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
