Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
I have a Whirlpool Dishwasher, I had a problem with the garbage disposal, so it was replaced, I hurt myself at the time and my wife had someone install the Garbage Disposal and now you run the dishwasher and no water is brought in to the dishwasher. It does drain, because I put water in and ran that part of the cycle and drained, it does turn on, it does dry but not bring in water is there something basic the guy forgot to do? Any suggestions, thank you.
  • 572 Answers
He turned the hot water faucet under the sink for the dishwasher
Posted on Feb 07, 2010
Testimonial: "That was part of it but it still will not take on water any suggestions."
Whirlpool dishwasher WDF520PADM5 won't drain. It will run through a cycle, but leaves a few inches of water at the bottom.
If the garbage disposal is clogged, the water from the dishwasher cannot drain. Most of the time the dishwasher drain hose is connected into the garbage disposal. Check to be sure water flows freely into the garbage disposal. You should hear it running into the bottom of the disposal when the dishwasher drains. The line connects to the garbage disposal at the top of the disposal with a hose clamp. If you undo it take the hose off and make sure the punch out inside the disposal tube is all the way punched out and there are no restrictions in their..ie stuck food particles or something else. Unplug the disposal when working on it. Just to be safe.
Hope this helps.
Dec 30, 2017 | Whirlpool Dishwashers
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
My dishwasher isn't draining. The garbage disposal is hooked up separately.
Is sink drain line clogged?
Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains.
Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
Oct 13, 2012 | Whirlpool Gold Dishwasher with Quiet...
We just replaced our garbage disposal and now the dishwasher won't drain. I order a drain pump and it still won't drain.
Make sure that the air clear on top of the sink is clean and clear all the way through. Sometimes in replacement silt and other garbage clog this up and keep it allowing water to drain properly.
Dec 23, 2010 | Whirlpool Dishwashers
We bought a new dishwasher because the old one wasn't draining all the way. Same problem with the new one?
The pump is a motor which runs in one direction to spray water in the dishwasher to clean and the opposite direction to drain the water. The problem could be from a clog or kink in the drain hose. Several years ago the drain line would connect to the sink garbage disposal. If the garbage disposal is not draining or the dishwasher connection to the garbage disposal is restricted or clogged the dishwasher will not drain. Under the sink, look at the garbage disposal to see if a rubber hose is connected at the side of the disposal unit. If a hose is connected to the side of the disposal, remove the hose clamp and check for any restrictions from garbage in the inlet or hose. You can use a screwdriver to clean the fitting to the garbage disposal and a wire hanger to free any restrictions in the hose. If the dishwasher does not connect to the garbage disposal it should connect to the sink trap. This is more common with new dishwashers because they have built-in disposals. Disconnect the drain hose from the sink trap and the dishwasher and look for a clog at the sink connection. The dishwasher inlet should have an angled piece of plastic or metal facing downward to prevent the waste from the dishwasher from spraying up into the sink. Do not get to aggressive with the cleaning in order to prevent breaking the angled piece of plastic or metal. Look for any kinks in the hose and try to run water through the hose, but do not use the sink which you removed the drain line from or it could leak under the cabinet. If you see a bad kink replace the hose with a new one. I hope this works and you find the problem without a great deal of time or trouble.
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Wont drain water out, have replaced filter. machine beeps and wont empty out old water. Whirlpool dishwasher, model adg7440
New garbage disposal? It's happened many times in my career- customer installs a new disposal then the dishwasher won't drain so they buy a new dishwasher to find the disposal didn't have the knock out knocked out. Check the easy stuff first.
Ken
Jan 08, 2010 | Whirlpool 24 in. ADG7540 Built-in...
WATER IN MY DISHWASHER
my dishwasher did the same thing last week and it was the garbage disposal. I had to run the garbage disposal and clear it out and then reach my hand in the dishwasher to check for any items blocking the drain. I had nothing and clearing out the garbage disposal did the trick.
Oct 12, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
My Whirlpool Quiet Partner III is collecting dirty water after the garbage disposal has run. Is this problem the dishwasher or garbage disposal?
The drain hose under the sink needs to be tied up,above the point where it enters the drain pipe or disposal,water is feeding back into the unit,run the disposal more often also this helps prevent this from happening.
Aug 19, 2009 | Whirlpool Dishwashers
Whirlpool gold quiet partner 3 wont drain.
The new garbage disposer comes with a plastic cap in the drain port. Disassemble the drain pipe assembly and remove the cap/plug.
Jan 13, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool model shf 5800 will not drain completely
Did you remove the knock-out in the disposer...if not that's why you are not draining.
Jun 02, 2008 | GE Dishwashers
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
190 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
