Question about Vizio VX37L Television
The edges of the screen have a distorted "fun house mirror" effect, very distorted
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you might have a backlight issue with this TV set. It could also be due to the inverter circuits for the backlights. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 07, 2010
How to replace outside side power mirrors in original housing? 2008 Ford Edge
Google replacement mirror glass for Ford Edge 08.
They make a replacement mirror glass available that uses double sticky tape. This has worked great for me. The heated function still continued to work!! In my case I replaced a scratched mirror leaving the old mirror in place. If yours is broken included is a link for a procedure to replace a broken mirror.
Confirm the dimensions before purchasing. Some car manufactures have more than one design for different model cars same year..
26182860-kzssal3k2qlm4jsc53ab1s2h-2-0.jpg This is an easy repair.
How to Repair and Replace Broken Side Mirror Glass DIY
May 02, 2016 | 2008 Ford Edge SEL
Why am I getting pictures with curved edges edges
Hi Ian
What you are suffering is something called barrel distortion which causes images to appear spherised or "inflated". Barrel distortion is associated with wide angle lenses and typically occurs at the wide end of a zoom lens. The use of converters often amplifies the effect. It is most visible in images with perfectly straight lines, especially when they are close to the edge of the image frame
the way to solve it is to try not use the end of the of the zoom of your lens. Above 20 mm you should be fine. If this is not possible then you can correct the effect in programmes like Photoshop
Hope this helps
May 09, 2014 | Sony Cameras
Picture is squished short, curved, and too wide
This sounds like either a convergence or pincushion problem.
Mar 29, 2014 | Televison & Video
Distorted picture lcd tv
It will look a little funny if your not level with the tv. If its wall mounted just tilt it down. If not try to find a solution to get it eye level with you.
Feb 01, 2014 | Televison & Video
RED BAND ACROSS SCREEN WITH MIRROR EFFECT,WHEN DOING PERFECT FOCUSGREEN OK ,BUT RED JUST DOESN`T GO IN TEST MODE...
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 25, 2011 | Samsung PCL541R 54" Rear Projection...
I need to reattach the rear view mirror to the windshield cannot remove the button from the mirror or disconnect the plug for mirror lights.
Just finished this job 5 mins ago. To disconnect the lights, use a small screwdriver to lift the locking tab on the plug. It's on the top of the plug. You should now be able to pull the plug from the socket. First check for locking screws on the housing. If there are none, take a scrap piece of 2x4 and place on edge. Place the pivot arm of the mirror on top edge of 2x4 with flat side of mounting plate facing down. Gently tap the plate out of the housing using a screwdriver and small hammer.
Jul 31, 2009 | 1998 GMC Sonoma
White dashes across top left of TV screen
That is what I was going yo suggest. You can also adjust the picture size. "Just" will show all of the picture even the distortions on the edges. "Full" will in effect overscan and trim those edges off.
Apr 27, 2009 | Panasonic SC-DT100 System
Gradually lost picture; Mitsubishi VS-50501A
you need to buy a new lamp and replace the old one thats your only problem its about $200 for the lamp
Mar 27, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Arched picture on Sony KV-34XBR800
Your TV has problem in Pin-Out area. I know its technical term but I have no other words to explain it. TV needs qualified technician to fix it.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Distorted Screen
It sounds like the the power supply or the horizontal circuit is faulty, it is very likely you must take your TV to a professional repairer.
Mar 13, 2008 | Sony KV-27V55 27" TV
Vizio VX37L Television Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
