Question about HP Media Center m7060n PC Desktop
Ell Inspiron 530S reboots on its own while in sleep mode.
    Genius:
  • 1,189 Answers
  • Hi, from the Start Menu, go to Control Panel, next, Hardware and Sound, select, Power Option; from here you can make changes... when the computer ("Sleep, Awake, Hibernate..."). You can also ajust the Display setting on the Monitor. "Did this solution help? Helpful Ratings Feedback, appreciated, thank paul7of9
Posted on Feb 08, 2010
Dell Inspiron 530s Desktop fan motor keeps running
It\'s NOT the fan. Check the power save settings on the computer ITSELF. Check your BIOS settings as well. Inspirons ALL do the same thing with waking up.
Nov 05, 2013 | Dell Inspiron 530s Desktop Computer
My dell Inspiron 530s goes to power save mode screen is black can't see anything fan is on what can I do
Do you get a screen if you boot from the CD/DVD drive using the Windows installation CD/DVD disc. If not, you probably dis-lodged
a cable or plug when installing the drive.
Sep 25, 2012 | Dell Inspiron 530s Desktop Computer
Inspiron 530 auto goes into power save mode
Click Start/Control Panel/Power Options and change the length of time or set it to NEVER.
There might also be settings in the Bios or System Setup that you can tweak. When you reboot your machine, watch the screen for which key it says to hit to get into the Bios or System Setup and hit that key when you see the message.
May 13, 2012 | Dell Inspiron 530s Desktop Computer...
My computer is stuck in sleep mode and it says to touch any keys or move the mouse, i did and nothing is happening, i have restarted and same thing. just a blank screen. please heklp
turn off computer and remove power cable
and reconnect power on
by pressing F8 go in to SAFE MODE REMOVE ANY TEMP FILES RESTART MAY FIX UR PROBLEM
Mar 01, 2012 | Dell Inspiron 530s Desktop Computer...
I start up the Dell computer and when I get to the log in screen, the monitor states "auto adjustment in progress" and then shuts down. Where should I go to fix this?
boot the computer into safe mode by pressing F8 as the computer boots up. then in safe mode adjust the resolution and/or refresh rate. then reboot and tweak to your liking.
Aug 27, 2010 | Dell Inspiron 530s Desktop Computer
I have a Dell Inspiron 530S desktop. My card reader simply stopped working. Doesn't read any card I insert. I checked the drivers....all seem to be installed and working. Couldn't find any problems. Help!
Found another solution online that worked...tried it, and it worked for me. Checked for drivers that needed updating or reinstalling. Reinstalled the driver. Shut down computer...rebooted and it worked. Don't know if it will continue to read cards, but for now...yea!
carly
Dec 08, 2009 | Dell Inspiron 530s Desktop Computer...
Dell optiplex boots directly into sleep mode
Try hitting F8 key to access the windows boot menu, Choose safe mode. If you can not get in to windows that way, you will need to reinstall windows.
Aug 17, 2009 | Dell Inspiron 530s Desktop Computer...
I have a Dell Inspiron 530S, and it exhibited the same symptoms as rguggemos's & Wilburollie's.
I can put it to sleep, but when I try to wake it, it won't. The screen will stay black. I can hear the drives spin up, and the fans go on FULL blast, and the blue power LED stays flashing, but the computer will stay like that - no picture or anything. Then I'd have to press & hold the power button to force it off, then power back on. Not ideal.
The solution that worked for me?! On boot, at the "DELL" logo, hit F2 to enter the BIOS setup, go to Power Management, and change the standby mode from S3 to S1. The difference? S3 is a "deeper" sleep, w/ more components powered off, which is better, energy-wise, but it is more difficult to wake from. S1 is a "light" sleep. Give it a shot! Maybe it'll work!
- Mike
Stolen from another forum:
S0 (Working) is lit. The CPU functions in entirety; the conservation of power is on a basis of by-device.
S1 (Sleep). The CPU is stopped; The RAM is regenerated; the system functions in reduced power.
S2 (Sleep 2) The CPU does not have any power; The RAM is regenerated; the system is in lower mode of the S1.
S3 (Standby) The CPU does not have any power; The RAM regenerates at minimum; the power supply unit is in mode of reduced power. This mode is also called “Save to RAM”.
S4 (Hibernate). All is powered off, but the memory was saved like temporary file on the hard drive. This mode is called “Save to disk”.
S5 (Off) Everything is shutdown. Means you need a full reboot.
Dec 11, 2008 | HP Media Center m7060n PC Desktop
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
HP Media Center m7060n PC Desktop Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
