Question about Jensen's VM9312 Car DVD Player
Yellow wire came out of plug in the back of radio how do i get it back in and why when i put it in it does not work no more
    Problem Solver:
  • 13 Answers
U fried the radio
Posted on Feb 08, 2010
Which radio wires go where? 2003 Chevy Cavalier
red=hot/power, black-ground/negative,orange or yellow usually = remote wire for an amp or interior as far as the speaker wires go,strip the wires on the new radio and just touch different wires from in the dash to ONLY the speaker wires on the back of the radio,thats not the best solution ever given but it's what i have always done in that position.
Jan 28, 2013 | Car Audio & Video
Hi im putting in a JVC cd/radio in a 1997 ford escort TD,Ive removed factory fitted Ford radio cassette,leaving 5 wires connected to a yellow plug,I have 3 wires coming out of JVC marked yellow memory back...
hi...well i know this might not be of any help, but you can buy a connector that plugs straight into the ford plug, and then you plug the jvc plug/s into that, not cutting wires no messing up the original connector just incase you want to sell the car with original system in it... http://productfinder.autoleads.co.uk/productinfo.aspx?&m=FORD&f=ESCORT&id=463&pID=6889
thats the link for it...if you tell me what colours are on the ford plug i could tell you what goes where...thanks
Feb 04, 2011 | 1995 Ford Escort
Wharfedale ICS182 keeps forgetting stations in a Citeron Xsara
Swap the battery and accessory lead positions in the ISO header plug. This is easily done by pressing the pins out from the plug side using a fine bladed screwdriver.
_MANY_ cars have these 2 wired the "wrong" way in their radio socket. It's far easier to move the radio's wires than the cars.
Dec 02, 2010 | Car Audio & Video
Im installing a JVC KD - A315 radio in a 2003 alero, when i took out old radio all the wires were cut and turned into speaker wire running all over the place the factory amp is in the back i went ahead...
There may be extra wires you don't need. The basic set of wires on the radio is 4 pairs of colored wires--one black-striped and one plain for each speaker. Yellow is usually accessory power, red is hot, and black is ground. Some additional wires may be one for a power antenna, one for an external amplifyer, and one for facelight (in case it will run on dimmer)
The car should have the following corresponding wires:
Radio 12v--- orange
Radio Ground--- black
Radio Ignition--- yellow
Radio Illumination--- brown
Dimmer--- gray
Power Antenna--- pink (if you have one)
LF Speaker +/- tan - grey
RF Speaker +/- lt green - dk green
LR Speaker +/- brown - yellow
RR Speaker +/- dk. blue- lt. blue
The car or radio could have additional connectors, such as for a subwoofer, CD changer, etc.
Aug 28, 2010 | 2003 Oldsmobile Alero
The yellow wire doesnt work
probally have a bad fuse in the fusebox. check there first.
Feb 07, 2010 | Kenwood KDC-X493 Car CD/ MP3 Player
2005 coupe g35 radio and climate controls not working , only works when fuse is put back in but drains battery?????
try swopping the red wire connection for the yellow wire and yellow wire to the red wire on the radio, put the fuse back in and the battery should not drain
Jan 29, 2010 | Bose Car Audio & Video
The wires came of the plug of my Cobra Road King 58 mic. I need the wire diagram to put them back on.
if you have a cobra radio with four pin input and a turner road king 56 it goes like this. pin one shield and red wire,pin 2 white,pin 3 blue,pin 4 black and tape up the yellow wire it isn't used. the numbers should be on the plug if not look inside your jack on your radio. hope this helped
Dec 17, 2008 | Radio Communications
Digital clock
Here is a wiring diagram of the radio by wire color:
Radio Constant 12V+ Wire: Green/Yellow
Radio Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Green
Radio Illumination Wire: Light Blue/Red
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Blue
Radio Amp Trigger Wire: Blue (Same as Antenna Trigger)
Front Speakers Size and Location: 5′ x 7′ Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers SIze and Location: 5′ x 7′ Rear Deck
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Aug 14, 2008 | 1988 Ford Mustang
Ok i am putting in a alpine head unit in a 99 neon i can get it to hold the memroy i have to put the red and yellow wire together and do the same on the wiring bracket and when i put all for together the...
The yellow wire must be connected to a constant voltage source. You have the red and yellow connected to a voltage source that only gets power when the car is turned on. The yellow wire is for the memory. Check the fuse box for a fuse that has voltage on it when the car is off and the key is not even in the ignition. That is the type of connection the yellow wire needs. The red wire can stay connected to the place it is at now.
Are you using a harness that is made for installing a radio into a 99 neon? They sell them at most all places that sell car stereos. Go in and ask for an installation harness for your car and then you connect it to the harness that comes with your radio by matching the colors of the wires and you have a nice and easy install. It plugs right into the factory harness with all the connections you need.
Jun 17, 2008 | Car Audio & Video
Wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Jensen's VM9312 Car DVD Player Logo
94 people viewed this question
Top Jensen's Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
Tre Elkins
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
