Question about Philips 32PF7320A 32 in. LCD Television
Philips 32PF7320: The main menu comes on by itself. Getting worse. Currently comes on a few seconds after being turned off - for the 100th time. Forced reboot does no good.
  • Philips Master
  • 19,396 Answers
Hi.
If the rest of the functions are not affected, then it is probably the IR receiver. First try removing batteries from remote, and ensure no other IR devices are around. Here the part 932220716667.
If the TV is also freezing when the menu is popping up, then it is probably a faulty controller board.
There are four different Philips 32PF7320 versions, ensure with the seller that the part is compatible with your model. I think the IR boards for this models are all the same.
Parts also here.
To get a technician, or to check your warranty status, call Philips at the number listed on the user manual.
Regards.
Posted on Feb 07, 2010
LCD TV backlight goes off but still sound is present. Sometime it happen within few minutes and sometime take 30 minutes plus. Is that inverter Problem or CCFL? how I can rectify?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 12, 2016 | Philips Televison & Video
Philips Flat Panel model 32PF7320/98 error code.
4 blinks is according to the manual... POR bit / +8 V protection
In other words the 8 volt DC power circuit is going into shut down, so you would need to troubleshoot that part of the power supply
Dec 01, 2017 | Philips 32PFL3403D/27 32 in. LCD TV
Having problems turning on 2 year old Phillips
Philips TVs tend to have issues with bad capacitors in their power supplies. Failing capacitors tend to have slightly different ESR (equivalent series resistance) values when they have been left off, versus after they are warmed up and charged up. Either a new power supply board or replacement of the faulty capacitors will fix the problem.
Oct 20, 2009 | Philips 42PF9630A 42 in. Plasma Television
Phillips 32pf7320 TV - Menu screen won't go away
i have the solution for this problem it is a software update that you have to upload to your tv if you have more questions email me at caypianan@yahoo.com
Jul 06, 2009 | Philips 32PF7320A 32 in. LCD Television
Problem with OSD Main Contorls unlocked/locked
Philips say "To unlock the OSD Controls press the “MENU(OK)” button for more than 10 seconds while there is video input from PC."
Jan 29, 2009 | Philips 190B6CB/27 19" LCD
Zigzag lines in picture when first turning on the tv
possoble cold solder connections breaking when unit is cold they expand when hot thus making connection.
Oct 11, 2008 | JVC AV-27530 27" TV
Philips 170S5FS monitor
hold in the menu or ok button on the monitor for 10 seconds, that should hopefully solve it.
May 31, 2008 | Philips 170S5FS 17" LCD Monitor
Philips 107C55
no its not a virus the problem is your monitor itself.try to contact an expert technician of monitor.i think there is a part of your monitor that is already defective.
Feb 16, 2008 | Philips Brilliance 107 17 in. CRT Monitor
Philips 32PF7320A 32 in. LCD Television Logo
192 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
