Question about Sony Playstation 3 (PS3) Console
Well when i sighn in to the network it wil hardly ever work and when it does work the signal bar wil be the lowest it can be when playing call of duty and then after 10 minutes it signs me out. i tried reconecting internet and diferent things but nothing seems to work .
  • 1 more comment
  • simonburgess Feb 07, 2010
    my internet connection is fine because when i test it the internet succeds but the playstation r network wont work, i have tuired moving it closer
    i tried tht it wont work, i dont know what is wtong with it the conection is ful because when i test it it is 100% but it sayd the playstation r network will not work.?
    hi, my playstation wont work, but when i do the internet conection test it works and has a 100% signal but it says that my playstation r network wilk not work i do not know why ?
The problem probably has to do with the router. In order to find out, disconnect your PS3 from the router and plug it directly into you modem. If your modem is not near your playstation 3 then move it closer. The modem plugs directly into your cable line so that there is a good chance that the television you play your PS3 on has a cable connection. One you have connected your PS3 to your modem press the reset button on the modem. Turn your PS3 on and go directly to your network settings. Click on Internet Connection Test (do not bother trying to set up a connection manually, if you do this chances are you will mess something up). If you are getting a connection then you are ready to go. There is a good chance you may never get a connection interruption again. Another thing is if alot of people are online at the same time playing that game it slows down the EA servers causing serious LAG
Posted on Feb 07, 2010
  • Sony Master
  • 11,800 Answers
Move the console closer to the router ; or use a better antenna on it.
What are sighns of a bad water pump
Usually noisy, and leaks at the pulley shaft seal. I have seen the impellers corroded and almost gone due to the wrong PH level antifreeze due to corrosion. This wil cause poor circulation. The best way to test, is to remove the belt, and see if you have play in the pulley shaft.
Dec 01, 2011 | 2000 Jeep Grand Cherokee
Only get 1 bar on my i phone 4 cloe to the router
What you can do here to correct this problem is to access the router setup page and play around with its wireless settings that will provide a stronger signal for your wireless network , the most possible settings that you can change to improve the signal from the wireless router is to change the wireless channel of the router and see which channel works fine with your wireless network and with your IPHONE.
Mar 04, 2011 | Linksys WRT300N Wireless Router
How to sing up new yahoo messenger?
go to this link and on the top right you will see sighn up and sighn in then click on sighn up it is in the very top right hand side i am in the uk but you will be auto linked anuyway
Feb 27, 2011 | Yahoo Messenger
My Ps3 network isnt working
You're getting a weak signal from the router. Several things can cause this problem, including interference from other devices. Make sure the PS3 is not located too far from the router.
Also, make sure you're on a secured network. I've noticed when I reset my router to the default settings (unsecure) the connection to my computer that's hooked up to the wireless network turns on and off constantly. This doesn't happen when I secure the network.
Jul 12, 2009 | Sony Computers & Internet
I have ps3 network connected to a working wireless modem router it will take about 5 mins to download game setting then it will play the game for 10 mins and it says you have been sighned out of ps3...
verify your signal strenght (its recomended to be about 60 per cent), and your internet connection - maybe its oscilating and causing the connection drops.
Jul 12, 2009 | Sony PlayStation® 3 (60 GB) Console
Loud clunking noise when i turn a corner both sides rear
check the sway bar kinks for play both rear wheels will have to even ramps work good if you have them if the is any play in the links it wil rattle also check for play in the bushings that the bar goes threw tis will also give you the noise you complain of
May 28, 2009 | 1998 Lincoln Town Car
Laptop Aspire 5672 problem...
SOUND S LIKE MOTHERBORD WEN BAD NOT GOOD SIGHN
Oct 09, 2008 | Acer Aspire 5500 5570-2609 Laptop
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
