Question about Qca Spas Majestic Series Aruba Xl Hot Tub
Qca Spa pumps and blower will not come on, water down to 35º f
I have a 10 year old QCA Majestic series Spa. The water temp. is down to 35º. The keypad was alternating these messages "ECON, ICE, FLO, COOL" and the pump1, pump2 and blower lights were all on though none of them were running. The pressure switch on the heater was seeping water and when touched broke. I placed a jumper wire in place of the pressure switch and powered up the tub. The keypad then displayed "ECON, ICE, COOL" but not "FLO". The pumps and blower still did not come on though the lights were lit. After a minute or two the whole spa power down and now will not power up. The main breaker and the GFI are not tripped. Any advise would be greatly appreciated. Ken
    Sniper:
  • 92 Answers
If you have FLO showing, the Heater will not function... Get the pressure Switch replaced... the the system will see the right pressure, and then turn on the heat...
Posted on Jul 31, 2014
    Habit-Forming:
  • 77 Answers
Ken,
You need to contact a hot tub technician/engineer as you clearly have issues.
'ICE' means that the water temperature is too low and therefore the pumps will be turned on to prevent freezing within the plumbing. Depending upon the spec and settings, the heater maybe disabled during 'ICE' condition.
'ECON' is Economy Mode. If you have a mode button, keep pressing it until you see 'Stan' on the display. This will put the system back into the standard mode.
'FLO' means that there's insufficient flow of water through the heater, or non at all. 1) Check the water level - top up if low. 2) Ensure that all jets are open and flow water - if they don't you may have a pump issue. 3) Remove the filter(s) and see whether or not this clears the fault, if so clean or replace the filters.
'COOL' is displaying because the set temperature is much higher than the current water temperature.
As I mentioned at the start, you really should get someone to take a look at your hot tub. You may have a few issues that need resolving.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 17, 2010
Draining a QCA 8-person jacuzzi
Hello, there is no drain plug. You will have too siphon it out with a hose or a sump pump.
May 19, 2014 | Qca Spas Majestic Series Aruba Xl Hot Tub
HAVE A 2001 STANDARD SERIES POWER TO SPA BUT NOTHING COMES ON
I was just wondering if anyone knows how much water the QCA Majestic Spa holds ???? It doesn't tell you in the directions!
Sep 06, 2012 | Qca Spas Dream Series Dream Master Hot Tub...
My qca spa is surging on pump 2. I know I have no air in the system, but it surges and pulsates to the point it is loud. the inlet is clear, there is enough water in the spa. Can it be the pump? I have a...
Your best bet is to contact their fantastic support team and they will help you by phone.
Sounds like you may have an obstruction in the line or a problem with an inline component
such as the old-style wave motor (in spas that are about 10 years old or more). Sounds like
the pump is actually trying to work, so would not blame this problem on the pump until other components on that second pump line such as a possible wave valve are checked.
Jun 23, 2011 | QCA Spas Jewel Series Amethyst Hot Tub
Spa water is overheating and get a HL error code
This is a problem in your board or something is jumping the safety circut. You should have someone look at this to be sure that no other problems have come from this. Good luck.
Dec 18, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Hello! the pump on our qca majestic hot tub
If you live in cold weather and are not using it much lower your thermostat. If the freeze control kicks on (at about 38-40degrees) it will constantly try to heat the spa to where you have the heat set when the air temp is low. Hope this helps.
Oct 28, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Filter for QCA Aruba xl
QCA has used 4 different sized filters in their tubs through the years.
  • c-4326 4-15/16" x 13-15/16" 25 sq ft
  • c-4950 4-15/16" x 13-15/16" 50 sq ft
  • c-4995 4-15/16" x 23-5/8" 95 sq ft
  • c-5397 5-5/16" x 17-13/16" 80 sq ft
you will need to measure the inside height and diameter of housing and see which one will fit best.
Jan 30, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Qca Spas Majestic Series Aruba Xl Hot Tub Logo
389 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
